Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 04-15-2012, 01:05 PM   #3226
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i think your best bet is to get the 02/03 **** in and then finalize it. dont want to half ass it now then have problems swapping stuff with the engine all installed.
WhiteBgeye02 is offline   Reply With Quote
Old 04-15-2012, 02:05 PM   #3227
25rsti
Member#: 166324
damit! i hear ya. I just wish I didnt have to do all that crap. I bought the car thinkin it was a + having all the 05 STi **** in it. lol
Old 04-15-2012, 07:57 PM   #3228
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Originally Posted by blakjak00 View Post
I am currently running the Tomioka Downpipe with an old style Perrin Twin tip. USDM length. Bolts up just fine.. Ver. 8 longblock, headers to turbo all stock twinscroll.
Oh, and it is 3". My neighbors and my calipers can attest to that fact.
Then I'll assume they refunded me $100 because I can't read a set of cailpers, and my TXS rfl is a one off.
I can only verify my Tomioka TS downpipe I rec'd just over two months ago.
n2xlr8n is offline   Reply With Quote
Old 04-15-2012, 08:00 PM   #3229
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Look for my review of the product on here, EDO states the 2.75" pipes were a manufacturing error. Subsequent products are all 3".
FWIW, mine Recently purchased, btw) was 2.54" ID...and it fell 9" short of being "USDM" length.
$280 up a hog's arse.,,,but Edo is a nice guy
Old 04-16-2012, 05:45 PM   #3230
azscooby
Member#: 115297
2002 ej207 vf34
Seems that maybe EDO isn't sure themselves on these pipes. I plan on calling them when they have the new pipes in hand-get some hard facts. I will be buying one if it is at least 2.75" and usdm length.
On another topic - when I did my avcs pinning at the ecu I noticed that there was an "autospray" pin in the b84 connector.
Does anyone know if this pin can be used to trigger the IC sprayer?
I understand the jdm uses a different "autospray" switch.
Has anyone figured out if this pin could wired to the IC spray and then be set to spray under given parameters?
Living in AZ we need every bit of cooling we can get.
azscooby is offline   Reply With Quote
Old 04-16-2012, 06:00 PM   #3231
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
When I had my merge done by Brian at iWire, I asked if he could enable the IC Autospray. He was able to wire it in (but said it was a real pain in the ass and would charge a lot more for it next time). It works and sprays based on a variety of parameters from the ECU and goes through the 12L Spec C Tank very quickly.
For me up here in Canada, its not really needed because we dont get that hot but its nice to have the feature.
Zaider is offline   Reply With Quote
Old 04-16-2012, 06:38 PM   #3232
azscooby
Member#: 115297
2002 ej207 vf34
Huh, so if a wiring expert says it was a pain in the ass.....a weekend warrior like myself would probably be in over my head.
Any idea on what was done? I'm pretty good with wiring but not a guru by any means.
Old 04-16-2012, 07:04 PM   #3233
WRick
Member#: 86107
yeah there is a pretty complete section for the autosprayer in the ecu...
WRick is offline   Reply With Quote
Old 04-16-2012, 08:34 PM   #3234
Zaider
Member#: 154281
MBP
I honestly dont have any idea what was done. The reason that I sent it away to get merged is that Im terrible with wiring. I sent it away on a tuesday, it was there by wednesday, he sent it back thursday morning and I had it back here by the following Monday.
Old 04-16-2012, 09:38 PM   #3235
25rsti
Member#: 166324
Getting my complete 02-03wrx harness and other tidbits tomorrow!
Old 04-16-2012, 10:06 PM   #3236
SSAF
Member#: 301923
2002 02&09 WRX wagon
PSM & WRB
^ Tell me how your whole setup goes. Your experience is going to make my ej207 purchase decision.
SSAF is offline   Reply With Quote
Old 04-17-2012, 02:14 PM   #3237
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
okay ppl with and without twin scroll setups. any turbo. in third gear starting at 2500 rpms what kinda of rpm are you hitting full spool of 19/20 psi? i have the v8 TS vf37 and i dont think that i am hitting 20 psi target as early as i should.
she is all sealed up to 20 psi for the boost leak test. running the v8 sti tmic. running a three port from grimmspeed as well. only thing i can think of is that the 3" DP to 2.5" exh is killing it after it starts to build....
Old 04-17-2012, 03:10 PM   #3238
jhenry1983
Member#: 269361
2004 xt
03wrx Rallycar
Your dp is catted also , hurts you big time
jhenry1983 is offline   Reply With Quote
Old 04-17-2012, 04:12 PM   #3239
sk8boylou
Member#: 246669
2002 V8 EJ207 6pd
would if be dangerous to turn the crank gear by hand on one these imported motors knowing they might have sat for 3 or more years. I know the oil pump is ran off the timing belt i just dont want to damage this amazing motor. plus i checked to see if there was oil in the motor and it was full
sk8boylou is offline   Reply With Quote
Old 04-17-2012, 04:42 PM   #3240
azscooby
Member#: 115297
2002 ej207 vf34
White - I'm hitting full boost, 20 psi, at 3400 - on my vf34. It hit full boost at 3000 rpms on one of my pulls but he dialed it up in order to smooth things out. (tuner talk I don't fully understand)
Your experience with spool times is the main reason I haven't gone twinscroll yet - I'm afraid I'd be disappointed if I didnt make some significant gains.
I agree that your catted downpipe is probably part of the problem...
When are you hitting full boost?
Did that ROM I sent you help you out? I would think they would be similar tunes...?
Old 04-17-2012, 04:43 PM   #3241
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its catless. its a very old APS system that has a shorty DP, reduces to 2.5" or whatever at the end of the shorty. i plan to move the reducer farther back and putting about a foot more of 3" in plus a cutout to the side so i will spool when i really want to go. unless someone else has a better idea.
Old 04-17-2012, 05:20 PM   #3242
azscooby
Member#: 115297
2002 ej207 vf34
Oh, I missed that - I wouldn't think that would be that much of a restriction.
I wish I knew more about tuning to help you out -
Have you sent your tune to someone else to have a look?
Is your avcs working?
Old 04-17-2012, 05:36 PM   #3243
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
AVCS is defiantly working. im sure its something im missing hence why i am asking on here since the ej207 experts are on this thread!
Old 04-17-2012, 05:41 PM   #3244
WRick
Member#: 86107
btw, I've noticed in logs that the avcs seems to engage only after driving over 50 km/h, stopping completely with the car in neutral. ( after a fresh ecu reflash )
I've seen this with a few 207's...
Old 04-17-2012, 05:58 PM   #3245
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Can you explain this better, are you saying that your AVCS is only working above 31mph?
Maybe this is your problem, your AVCS is defiant!
OppositeLock is offline   Reply With Quote
Old 04-17-2012, 06:21 PM   #3246
sk8boylou
Member#: 246669
2002 V8 EJ207 6pd
I was just told to use a LFR7AIX spark plugs for the v8 is stead of the BKR7EIX what are you all using for your version 8? a local shop said the BKR7EIX is to short for the heads
Old 04-17-2012, 06:29 PM   #3247
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
unless someone pulled a switch-a-roo with USDM STi heads, they are wrong.
fastnoypi is offline   Reply With Quote
Old 04-17-2012, 06:37 PM   #3248
jhenry1983
Member#: 269361
2004 xt
03wrx Rallycar
I use the bkr ones no misfires at all
Old 04-17-2012, 07:39 PM   #3249
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
I use the BKR7EIX in my V7 as well. The first time I started the motor, it seemed a bit rough, tapping the gas a few times gave me popping backfires. I double checked the swap and discovered the connect to one of the coils came loose, possibly during the motor installation. Afterwards, the car idles smooth and no backfires, not even a bit of boxer shake to speak of. With the car idling, my wife even said: "Is the car even on? Aw, I'm gonna miss the shake"
-Jeff
efiniluvr is offline   Reply With Quote
Old 04-17-2012, 08:53 PM   #3250
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
no its after a fresh reflash, its either that or getting out of rough correction mod. i noticed it too. i figured it was because the car wasnt warmed up since it needs to be so warm for it to work i guess. all my logs include avcs advance coloumns so i know avcs is working. i guess it might be time to leave the tunign up to the experts and see how they get it to spool so damn fast!
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
