10-03-2018, 11:51 AM | #1 |
Vendor Sales Rating: (0)
Member#: 490792
NWIC
Vehicle:2006 Legacy GT |
Sunwest Certified Subaru Motors
Here at Sunwest, we take pride in the Subaru engines that we build. We offer a variety of packages to suit your needs:
Subaru EJ20 / EJ25 Packages: EJ20/EJ25 Non-Turbo Short Block - $1,295 (FREE shipping to lower 48) / $300 core deposit 01313_fBPJGgp41hi_1200x900 by Sunwest Automotive, on Flickr Long block - $2,795 (+shipping) / $600 core deposit 00B0B_jqQ4ldFImMS_1200x900 by Sunwest Automotive, on Flickr EJ20 / EJ25 Turbo Short Block - $1,395 (FREE shipping to lower 48) / $800 core deposit 00L0L_kcFqY6TcVWI_1200x900 by Sunwest Automotive, on Flickr Long Block - $2,995 (+shipping) - this is a Custom Build (we need your heads to finish the build) 00U0U_9YAUfaf6FwY_1200x900 by Sunwest Automotive, on Flickr All our Subaru Short blocks include: -New NPR Teflon Coated Hyper-eutectic Pistons -New King Rod and Main Bearings -New Pin Bushings -Crank is ground and polished -Rods are reconditioned on both ends Additionally, our Long Blocks also include: -Complete gasket set (including 6-Star multi-layer head gasket) -New valves and valve guides -New PCI timing kit installed -New Altrom OEM Water pump installed -All Long Blocks are pre-ran on our SIM test machine to give an accurate reading of oil pressure, cylinder compression and engine load 0924181446 (1) by Sunwest Automotive, on Flickr Machine Work Done: -Engine and heads are cleaned, all bolt holes checked and repaired if needed -Surfaces are checked and milled if needed -Blocks are bored with deck plates to mimic the cylinder distortion of an assembled motor -Blocks are bored and honed with a computer controlled diamond hone -Rods are reconditioned and new pin bushings are installed -Crankshaft is ground and polished -Deck Surface is CBN milled on a Rottler Machine 20181001_144054 by Sunwest Automotive, on Flickr Because of how we bore and hone the block halves, we have dramatically reduced, almost eliminated, the ever so common piston slap in our stock rebuilds. We also offer Blueprinted Performance Builds that include: -STI Nitrated Crank -Manley H-Beam Rods -Manley Forged Pistons -ARP Head Studs -Block halves are bored and honed bolted together in addition to the deck plate -Block halve are lined bored, if needed, to set main bearing clearance to std Short Blocks - $2,495 (FREE shipping to lower 48) / $800 core Long Blocks - $3,995 (+shipping) / Custom Build (we need your heads to complete the build) **THIS BUILD HAS BEEN DYNO-TESTED AT 500-550WHP** FORGED SHORTBLOCK by Sunwest Automotive, on Flickr MENTION THIS POST AND RECEIVE A 5% DISCOUNT OFF YOUR FIRST ORDER!! *We also do EA series and EJ22* To learn more about Sunwest and our operation visit our website at: http://www.sunwestautomotiveengines.com/index.html And watch our videos at:
