08-16-2009, 01:02 PM | #1 |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
Intakes Do Not Cause A Cel, Bovs Dont Make You Run Rich
In 90% of cases, the above statements are true. Hopefully the fact that its in caps and is the thread title will get this noticed.
If your intake gives you a CEL, its either a poorly designed or BIG MAF intake (that you havent tuned for), or you did something wrong during the install. A bov, will only give you a TINY temporary rich spot WHEN IT VENTS, it will not cause a constant rich condition, because when its closed, its closed. Just like stock. (unless it leaks, which wont cause you to run rich either) The problems with intakes have largely been eliminated over the past several years, and BOVs, well, they never made you "run rich" to begin with. Both are myths and misconceptions that for some reason after multiple FAQs and threads explaining things in detail, just wont go away.
08-16-2009, 02:02 PM | #2 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Air fuel ratio charts during bpv full-to-off throttle excursions?
Air fuel ratio charts during bov full-to-off throttle excursions? thanks.....waiting.....I have no opinion either way (since BOV's cost money) but would like to see data so we can judge based on something real. jack |
08-16-2009, 02:05 PM | #3 |
Member#: 175615
Vehicle:2005 STi Black Stg. 2 |
If I get an untuned intake that causes a lean condition and then a bov to make me run rich will it even out?
08-16-2009, 02:07 PM | #4 |
Member#: 132038
South East
Vehicle:funk er chicks serious bidness |
This calls for another video.
08-16-2009, 02:15 PM | #5 |
Member#: 88618
SCIC
08-16-2009, 04:28 PM | #6 |
Member#: 175615
08-16-2009, 04:34 PM | #7 |
Member#: 154494
Vehicle:2007 WRX TR - 18g'd Satin White Pearl |
What BOV can make the best Pshshshshshhhhhhhhhh noise?
08-16-2009, 04:53 PM | #8 | |
Vendor
Member#: 155450
Datalogs It goes about .2 to .5 rich for 3 lines or less. And the log is sampling I want to say 4 times a second. So its under a second. For day to day driving, even hard driving, it makes no difference. Around a race track, only those with enough skill for there to be no other problems will see a difference. On the drag strip, again, 90% of people arent fast enough (driving wise) for it to matter. |
08-16-2009, 04:53 PM | #9 |
Vendor
Member#: 155450
08-16-2009, 06:06 PM | #12 |
Member#: 143022
RMIC
Vehicle:2005 modded S4 |
so Defiant, are you saying that really there is no harm running a bov?
08-16-2009, 06:26 PM | #13 |
Member#: 189748
how can i get the turbo sound in my 2.5i? can i weld a BOV on my exhaust?
lolwut |
08-16-2009, 07:03 PM | #14 |
Member#: 196517
NESIC
Vehicle:2007 n00b rocket urban grey metallic |
DefiantAutospeed has made a defiant thread
08-17-2009, 01:11 AM | #15 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Defiant, what you say about intakes may be true for turbo cars, I have no idea.
However, there are a number of intakes available for the NA cars that will screw over the MAF badly enough to peg the A/F Learning and throw a CEL. There's a bigger number of intakes that will only cause about a 15% error, which isn't quite enough to trigger a CEL but is enough to cause other problems. An intake, any intake, without tuning is NOT a safe thing to do on a MAF-based NA. |
08-17-2009, 01:27 AM | #16 |
Member#: 108547
SWIC
Vehicle:2017 Tundra 1794 Lifted, Armored, Muddy AF |
08-17-2009, 01:27 AM | #17 |
Member#: 108547
SWIC
08-17-2009, 01:28 AM | #18 | |
Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
If it's functioning properly, then there will be no harm. I speak for Dave, because he pays me to do so. He doesn't yet know that he pays me for such assistance, but he will when he gets the bill.... |
08-17-2009, 02:08 PM | #19 | |
Member#: 70395
08-17-2009, 02:16 PM | #20 |
Member#: 143022
RMIC
intake and exhaust make wrx run rich? | rextacy_Jess | Newbies & FAQs | 4 | 12-15-2008 12:40 PM |
calling all vf39'ers with pinks DO YOU RUN RICH? | SleepinCreppin02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 01-19-2006 06:49 AM |
bov making me run rich | WEBZ090909 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 04-14-2004 03:44 AM |
Which intakes do not cause cause flat spots and make the car run lean? | LqSilver | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 25 | 01-01-2004 10:09 AM |
Does a BOV make you run rich? | yayitzian | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 04-04-2003 03:03 PM |
