Welcome to the North American Subaru Impreza Owners Club Monday March 19, 2018
Old 11-04-2014, 05:17 PM   #301
nj kiter
Member#: 241501
okay i pulled the oem high pressure line off and realized that the fitting will not work, it is too short and will not reach the threads. i looked through this whole thread, and some people mentioned welding a an fitting onto the oem hard line down by rack. But i never read someone actually committing to this, if their a reason i should not weld on a fitting to the oem hardline? i like the idea of having an oem fit on the rack with the seal than having the an line attached to it.
nj kiter is offline   Reply With Quote
Old 11-04-2014, 05:32 PM   #302
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Don't bother trying to weld/braze a fitting on it...too hard to get it right the 1st time and not enough length to redo it again
These are the fittings from rack line to male 6AN and male 6AN to PS Pump
WRX & STi Rack side •14mm x 1.5 Male Bumpsteer with O-Ring ...... Earl's fitting part # EAR-991954
WRX PS Pump side •16mm x 1.5 Male with Dowty Seal Washer This may not be correct for 04-07 STi
....... If you have a 04-07 STi PS Pump get the MSI Power Steering Pump Adapter Kit from www.rallysportsdirect.com and use the 6an fitting they offer for the kit too
- rallysprotdirect part #MSI MSISUB01-00-030 and MSI GR-AN920-06
dangerousatom is offline   Reply With Quote
Old 11-06-2014, 11:55 PM   #303
nj kiter
Member#: 241501
Okay i got a little mixed up from the get go because some people use a female fitting off the power steering line under the up pipe, and other people / manufactures replace that line and run their braided line all the way to the power steering rack? And the fitting that goes directly into the steering rack is what you stated above (ear-991954, 14mm x 1.5). Sorry to ask again, i just want to make sure i get this right the second time around, i had everything i need except for something to connect my line to my steering rack.
Old 04-08-2015, 08:31 PM   #304
Member#: 265430
2005 OBP WRX STi
IG/FB - seriousblacksti
I have a 2005 STi and bought the Techna-Fit line. I know it is intended for use with the WRX only. From what I've gathered in this thread and a few others, one of these 4 adapters they sent:
will work to get me from the pump to the line.
Then I just need to buy one of these:
or the Earl's equivalent,
Which will attach to the fitting on the short hardline coming off the rack, seen here:
Is that correct?
STiSomeday is offline   Reply With Quote
Old 08-08-2016, 12:49 PM   #305
Member#: 346321
Default 2002 and EJ205
Doing this in an 02 wrx this weekend or maybe sooner depending on when i can get parts. I will post pics, and install info. This is because I swapped the engine to an EJ205 and want to use the power steering pump that was on the new engine which hooks up slightly differently than the normal USDM 02 wrx power steering pump. If anyone has any insight or info for this specific application please let me know! I will let you know how everything works out
jadedjeff1 is offline   Reply With Quote
Old 09-12-2016, 06:46 PM   #306
Member#: 97043
08 STI
02 Z28 - project
..... sub'd for reference
imma_stocker is offline   Reply With Quote
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 03:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 10:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 01:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 10:58 PM
