Welcome to the North American Subaru Impreza Owners Club Saturday April 21, 2018
Old 03-20-2017, 10:40 PM   #2351
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
Talking FT Fabrication with "REAL" stainless steel !
Originally Posted by nvmylh View Post
wow how thick is that flange? Looks 3/4" from the photo! haha, nice work though!
IDK , but I know this shop did not cut any corners in making the front pipe. Here you go! some more photos.This is before the Cerma Krome Coating.
I don't know what happened to flickr, the pictures got smaller for some reason. weird?
ZURCALED12 is offline   Reply With Quote
Old 03-20-2017, 11:44 PM   #2352
ZURCALED12
Member#: 309754
Ice Silver Metallic
Well the tips mike shipped are FAKE!!! They already rusted bad!! This Sucks Big Time
Old 04-07-2017, 07:56 PM   #2353
ZURCALED12
Member#: 309754
Ice Silver Metallic
Smile Finally Coated YES!!
Old 04-09-2017, 08:44 AM   #2354
rotaxmax3
Member#: 301212
06 Impreza 2,0R
Crystal Grey Metallic
Why didn't they make the flange for the donut thicker?
rotaxmax3 is offline   Reply With Quote
Old 04-09-2017, 08:57 PM   #2355
ZURCALED12
Member#: 309754
Ice Silver Metallic
Wink
Because that is where the SUBARU design comes in with the two springs one on each side of the flange with nuts & the bolts!
I am not sure why it's made that way? I am guessing the OEM pipes are designed that way to make sure the pipe flexes with acceleration.
Old 04-10-2017, 08:23 AM   #2356
rotaxmax3
Member#: 301212
06 Impreza 2,0R
Yes I know how it looks there, but why wasnt it made thicker ? I'm just imagining that skinny bit of metal will buckle under the load of the springs ?
Old 04-10-2017, 09:29 AM   #2357
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Based on the pics I assumed the pipe was stainless. Is that not the case, or why are you spending extra money to coat stainless?
Nothing happened to Flickr, you posted the wrong links - those are mobile links. Remove the "_m" from the end of the file name and magically they'll be the correct size.
https://farm3.staticflickr.com/2832/32918247653_d226d9f881_z.jpg
https://farm4.staticflickr.com/3931/...99b824bf_z.jpg
https://farm4.staticflickr.com/3818/...cb910b3b_z.jpg
That's pretty brutal. Fortunately you can easily find real polished stainless tips from a variety of sources dirt cheap, so it shouldn't be hard to fix the problem.
The Subaru flanges are not designed that way, and Subaru certainly wouldn't design flex into the system by using weak flanges.
As an example, on my older Impreza's midpipe, the inlet flange (where those same spring-loaded bolts are used) has a flange made from similarly thin steel. However, it's a stamped flange, with a ~1/4" lip all the way around, which gives it the strength it needs. Your flange, without that lip, and with the bolt holes right at the ends of the flange (not sure why they did that ), is going to flex like crazy.
I don't have a pic of the back side of the flange to really show the lip, but you can see the rolled edges of the flanges - that's because they're stamped.
Old 04-12-2017, 08:28 PM   #2358
ZURCALED12
Member#: 309754
Ice Silver Metallic
I see what you mean, I will ask the guy who build it for me, I cerma kromed it because I was concerned about the corrosion from the winter salt up here. The highway dept. heavily salts the roads and highways uphere. The sound that I get from this exhaust is amazing.
Old 04-12-2017, 08:46 PM   #2359
ZURCALED12
Member#: 309754
Ice Silver Metallic
Smile The Replacements Tips!
Old 04-13-2017, 08:42 AM   #2360
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
So let's see some installed pics!
Old 05-07-2017, 12:32 AM   #2361
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Default i want it
Originally Posted by brette808 View Post
Still have my header and catpipe for sale if anyone's interested!
check inbox or pm me
ssssssantimonio is offline   Reply With Quote
Old 05-27-2017, 07:00 PM   #2362
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by [email protected] at WI!
Not sure if anyone is interested but i picked this custom UEL manifold up 4 ish years ago. Some kid had it on his 07 impreza and i picked it up thinking i would use it, but its just sitting. From what i remember its a perrin turbo manifold and the collector has been cut and rotated. Any interested? 150 picked up or 180 shipped
Matt515 is offline   Reply With Quote
Old 06-11-2017, 01:48 AM   #2363
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Dibs. Would you send to canada?
R2L0S4
Old 06-12-2017, 08:59 PM   #2364
Matt515
Member#: 241492
2006 Forester, RBP
R2L0S4
Pmed.
Old 08-03-2017, 10:03 AM   #2365
one_slow_imp
Member#: 457990
2011 Impreza
Still for sale? I'd take them shipped to MN
one_slow_imp is offline   Reply With Quote
Old 10-02-2017, 02:58 AM   #2366
ZURCALED12
Member#: 309754
Ice Silver Metallic
[IMG]The last pipe by gusto395, on Flickr[/IMG]
Old 10-02-2017, 03:07 AM   #2367
ZURCALED12
Member#: 309754
Ice Silver Metallic
Old 10-02-2017, 03:08 AM   #2368
ZURCALED12
Member#: 309754
Ice Silver Metallic
Old 10-02-2017, 03:10 AM   #2369
ZURCALED12
Member#: 309754
Ice Silver Metallic
Old 03-19-2018, 05:04 PM   #2370
JaveStack
Member#: 353552
2006 Impreza 2.5i
Default Mike is back on the radar
Well, given that this thread has basically been a rage-fest since Mike disappeared, it is probably worth noting that he is back on the grid trying to make good on his past deals and rebuild bridges with the Subaru community.
He has started giving refunds in payments to those that were left with nothing to show for their down payments (or building them product). Given that I paid nearly $800 in down payments for a full exhaust, getting a refund (regardless of how long I waited) makes me willing to forgive the past.
Mike no longer accepts down payments, he will only accept money for product ready to ship. So that takes care of the issue that created so much drama with previous customers. If you've read this thread, you know Mike makes some of the best product in the business, and I have yet to see one person complain about the quality or sound. If he's got what you need in stock, I would highly suggest giving him a try.
http://rallisportautomotive.com/
JaveStack is offline   Reply With Quote
Old 03-19-2018, 09:39 PM   #2371
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
BWX is offline   Reply With Quote
Old 03-20-2018, 04:43 PM   #2372
rotaxmax3
Member#: 301212
06 Impreza 2,0R
I got a partial refund from him, as well as a tactrix openport cable he sold in a garage sale as downpayment. I told him that I consider his debts to me to be paid.
I think he's serious about paying everybody back, and the part of not selling stuff before its made backs it up.
But I'm still a bit hesitant to tell anyone to buy stuff from him...
Old 03-21-2018, 09:20 AM   #2373
lpxltt
Member#: 395574
2007 OBS
As an owner - one of the last to actually receive a product - I am going to have to disagree with you on this. Within 6 months the coating on the cat section was completely gone and by the end of year one I had a small crack and leak where the manifold flange met the pipe. When I inspected it, the reason this happened was because the pipe wasn't cut evenly. Where it was leaking it had extra weld built up to compensate for it.
I had it fixed at a local shop but they didn't promise it was going to last because of the previous bandaid a this winter it has started to leak again. I don't know if they will be repairable again due to the lack of material.
I didn't catch this mistake when I first installed the headers. They looked great, they sound awesome but for my money I'm going to with Inferno Fabrication next time I need a quality set of headers for an N/A.
lpxltt is offline   Reply With Quote
Old 03-21-2018, 06:33 PM   #2374
blk6s
Member#: 200057
2013 Impreza 2.0i
RalliSported RomRaided
Hello,
I'm sorry to hear about your problems with the header I built. Although I don't do the ceramic coating myself (I have a local pro do all my ceramic coating) I am happy to have them recoated for free. I'm not quite sure about the cracking issue you described, but my technique for the primaries is bringing the pipes close to flush with the flange, then use a carbide burr to make a 45 degree angle where the two would otherwise be flush. I then fuse the two with a TIG torch, this gives it that nice radius to where the exhaust pulses first enter the header. Almost all other headers have a sharp step at this juncture, which may be inconsequential for a 2.5i header, but still always bugged me. Again, I am happy to repair the header and have it recoated for you free of charge. If you would like, I can make you a "loaner UEL header" to run while I repair your header. You wouldn't have to send your damaged header in until after you have the loaner in your hands.
No fabricator in the world (not even Inferno Fab) can guarantee that their header will last forever and never ever crack. The most we can do is stand behind our product and address any problems that should arise, which is exactly what I plan to do. I don't care if the header I made was last week or a v1 from seven years ago, I put my heart and soul into each and every header I ever made and stand behind every one. If given the opportunity, I will do everything in my power to make it right.
Thanks,
Mike
blk6s is offline   Reply With Quote
Old 03-22-2018, 01:41 PM   #2375
lpxltt
Member#: 395574
2007 OBS
Originally Posted by blk6s View Post
Hello,
Thanks,
Mike
Mike,
I might take you up on the offer once I address a couple of other issues with the vehicle. I don't expect them to last forever but I did email you as soon as I saw the coating starting to crack off the cat and you offered to re-coat them for free back then but communications broke down in getting them back to you. This was before the flange issue as well.
I'm all for the forgive and forget thing and the fact that you took the time respond to this post in short order hopefully means you are on the right track in redeeming yourself.
I'll be keeping an eye on this thread and will probably reach out this summer to discuss the repair once I have some down time.
Good luck and I wish you the best.
RalliSport Racing HF Cat Kramer3608 Normally Aspirated Powertrain 20 02-16-2015 01:27 PM
Support the Rallisport Racing 2.5i build GEE-OTTO Normally Aspirated Powertrain 18 02-16-2015 01:25 PM
It's finally time for the ice racing! see red Mid West Subaru Owners Club Forum -- MWSOC 19 11-07-2011 11:35 AM
i finally cracked opened the motor i blew at the last race... giveme5bux Texas Impreza Club Forum -- TXIC 11 07-01-2007 01:27 PM
Ultimate-Racing 785CC final map impressions RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-24-2003 04:18 AM
