#1 |
Member#: 460045
![]() I've been getting a code for a cylinder 2 misfire, wondering if boost leak could be a factor. I have thought the car has been sluggish. Now it's sputtering at around 3500rpm/16psi (hence the misfire)
It's an 05 saab 92x, with Blouch 16g turbo upgrade, STI TMIC, 1000cc injectors, fuel pump, exhaust etc. Its a factory auto transmission as well. The car isn't as fast as I thought itd be. I know turbo lag is real, it just seems more than that to me Any way to check for boost leak? |
#2 |
Member#: 460045
![]() Just thought I'd mentioned it's obviously shop tuned as well. And I have a boost control solenoid installed
#3 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
![]() Step #1 - Go back to your tuner
Step #2 - See Step #1 What? No CEL code? So many things could cause a misfire. |
#4 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
![]() i had a problem like that, the car would stop reving if I went into boost. no cel light or anything.. anways it ended up being the coils 2 of the 4 went bad but it took like a long time to figure it out
#5 |
Member#: 460045
![]() Yea I'm getting a cel, it comes and goes. I'm gonna check the coils and plugs
#6 |
Member#: 460045
![]() My gas mileage dropped quite a bit too. I was at 22 a couple tanks ago, now averaging 17.6. Mostly highway
#7 |
Member#: 460045
![]() Just found a huge fuel leak
#8 |
Member#: 460045
![]() Pouring out of the injectors on both sides. Bad O Rings??
#9 |
Member#: 477704
![]() I'm having a similar problem with my stb and thinking it might be an air leak... such a pain trying to trouble shoot. Best of luck!
#10 |
Member#: 503227
NWIC
Vehicle:2009 Impreza WRX Sterling Silver |
![]() Not to bring this back from the dead but what was the solution to your problem?
