Welcome to the North American Subaru Impreza Owners Club Tuesday October 17, 2017
Old 10-06-2017, 01:57 PM   #11451
salvi
Member#: 188132
Samurai Jack - I've tried every possible way to reset the system according to the instructions, but no go.
I'll have to drain and fill with the proper ATF fluid for the Power Steering.
We have only driven it about 5 miles after swap.
salvi is offline   Reply With Quote
Old 10-09-2017, 04:01 PM   #11452
ubaldeboi
Member#: 475754
Just got my saabaru with v8 ej207 swap at a steal price. Problem is my area does emissions testing via obd2 port. Now i have to go through some pain to get it to pass inspection
ubaldeboi is offline   Reply With Quote
Old 10-09-2017, 04:19 PM   #11453
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
just swap Ecus with an emissions friendly tune on a wrx ecu
Gigs90 is offline   Reply With Quote
Old 10-09-2017, 09:35 PM   #11454
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 18G 6sp RA
In NY your ecu and vin numbers have to match, in the case of a new ecu the dealer has to encrypt it to match the vin. I hope you got the original ecu also when you purchased the car. The original ecu can idle the car but not so well due to the different fuel injectors on the STi motor. If you need a stock 05 wrx ecu let me know, I have a good spare I can sell you for $100, pm if you want the ecu or have questions.
D-Rodman is offline   Reply With Quote
Old 10-10-2017, 09:47 AM   #11455
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
yes emissions are a tricky battle because they vary immensly from state to state and country to country. apparently people near me have told me they passed with a jdm ecu & catless. they just had all the readiness monitors set to force pass. plugged in, everything was a-ok, away he went.
Titter is offline   Reply With Quote
Old 10-10-2017, 11:15 AM   #11456
PHruska
Member#: 214589
2002 V8 wrx wagon
Has anyone had any issues with running Learningview/Romraider/EcuFlash on windows 8.1?
I tuned the car back in 2013 (02 w/ v8. Tuned by Ron @phatbotti).
The car recently has been getting wonky AFR's at cruising/idle. Bouncing from 14.1 to 15.3 and such. Its about time for spark plugs/timing belt etc. but wanted to hook up a computed and read a random CEL that came on briefly yesterday.
I no longer have the windows 7 laptop i used to tune the car but do have one running windows 8.1.
I downloaded Learningview and got nothing. I downloaded ecuflash and romraider and got a little. Romraider logger doesnt show a com port connection BUT was reading off the ECU for a few minutes before it automatically stopped.
I have java updated (i think only 64bit?), enabled .Net 4 or whatever that enables .Net 2.0.
Computer is running windows 8.1, 64 Bit. Using Tactrix 2.0
Any ideas?
PHruska is offline   Reply With Quote
Old 10-10-2017, 11:17 AM   #11457
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Windows 8 is just pure trash
I have only done logging on a windows 7 laptop for that reason and licences are only like $50 now for 7 Pro
Old 10-10-2017, 11:21 AM   #11458
PHruska
Member#: 214589
2002 V8 wrx wagon
I do not disagree. I unfortunately only have the one computer running 8, and is also running Solidworks so i dont want to go back to 7.
I am ready to throw my entire laptop out the window if i cant figure this out.
Old 10-10-2017, 11:42 AM   #11459
Bansheeboy11
Member#: 182415
1999 RS
Yeh 8 is trash, i bought one of those cheap netbooks and threw Win 7 on it for use with the cars, its been great so far.
Bansheeboy11 is online now   Reply With Quote
Old 10-10-2017, 12:08 PM   #11460
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Agreed. Have a base tune put on your ECU so the car will run & pass emissions.
- You won't have AVCS
- You will have minimal boost, like 6 - 8 psi
Once you pass emissions, just swap in the JDM ECU with the proper tune for the engine. It only takes a few minutes to do the ECU swap
Samurai Jack is online now   Reply With Quote
Old 10-10-2017, 01:07 PM   #11461
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I'm about to do this as my admin machine for my home lab and ecu logging as well
Old 10-10-2017, 03:04 PM   #11462
PHruska
Member#: 214589
2002 V8 wrx wagon
Edit:nvm, Getting 0 degrees of VVT on either side. Guessing that the reason is something other than the wire shielding being compromised. Going to have to dig a bit deeper. Wonder if crank sensors failed or AVCS solenoids both failed. Between the fluttering AFR, the not stable idle RPM and 0 degrees of AVCS Id say I have some work cut out. Going to start with IACV gasket then keep digging. Its almost time for plugs and a timing belt anyway.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
