Brakes & Suspension Forum sponsored by The Tire Rack |
09-19-2006, 11:59 AM | #1 |
Member#: 117101
Vehicle:2007 Chevy Colorado Blue |
Alignment Needed After Install Rear Subframe Lock Bolts?
Would anyone recommend getting a new alignment after installing rear subframe lock bolts?
09-19-2006, 02:04 PM | #2 |
Member#: 1725
International
Vehicle:2002 Subaru Forester SG silver |
Technically, they could throw off your rear alignment. The rear subframe has a decent amount of give and installing them would line the subframe up and change your current settings. The idea behind them is that you have them installed when you get your alignment. Remove them for daily cruising. When you reinstall them for a track day, it brings all the alignment angles back to your alignment spec and locks them in. Naturally, you could also just leave them in after your alignment an not worry about the changes in alignment spec due to subframe bushing deflection.
09-20-2006, 12:12 AM | #3 | |
Member#: 117101
So it's a good idea to realign. I kinda thought so but wanted some expert input. Thanks.
09-29-2006, 09:20 PM | #4 |
Member#: 123057
NESIC
Vehicle:2016 WRX silver |
Did you notice and NVH from installing these bolts? If you did them yet. Mine should be hear Monday.
09-30-2006, 11:48 AM | #5 |
Member#: 1725
International
Its more of a "lawyer clause" from Whiteline because these do lock up the rear subframe, introducing more stress and vibration than it was normally designed for. Most people run with them full time but its just something to be aware of.
I'm installing Rear Subframe Lock Bolts | bjcarter2 | Alaskan Impreza Club Forum -- AKIC | 3 | 03-28-2010 11:49 PM |
02-03 wrx sedan whiteline rear subframe locking bolts | anthonyrb98 | Drivetrain | 3 | 12-15-2006 07:50 PM |
Whiteline Rear Subframe Lock Bolts | el~sharko | Car Part Reviews | 7 | 12-20-2005 09:53 AM |
Rear Subframe Lock Bolts - NEW | HorsePowerForBrains | Private 'For Sale' Classifieds | 2 | 01-04-2005 02:16 PM |
Whiteline rear subframe lock bolts | SillyAssKilby | Transmission (AT/MT) & Driveline | 26 | 02-26-2004 10:37 AM |
