04-22-2009, 11:17 AM | #1 |
Member#: 164038
International
Vehicle:2013 WRX with too many parts too list |
Hoses from turbo to BCS to 44mm EWG????
So this is what im thinkin....The fitting from the turbo is smaller that the fitting on the BCS....The fitting on the BCS is WAYYYYY smaller than the EWG fitting. So I have to use inline reducer fittings that have really small holes. Almost as small as my pill. I think these inline reducer fittings might be affecting boost controll What you guys think?
04-22-2009, 12:31 PM | #2 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
I think you shouldn't try to run an ewg with a stock solenoid. I've tuned them, but it's not the best way.
04-24-2009, 09:59 PM | #3 |
Member#: 164038
International
04-24-2009, 10:19 PM | #4 |
Member#: 114730
SWIC
Then you shouldn't have a pill. Also if you're going to ask about vac lines to your bcs, it would be nice to tell us which one you have. It is easy to hook a prodrive to an ewg. Just use the line that fits the prodrive and stretch it to fit the ewg. I've done it.
04-24-2009, 10:23 PM | #5 |
Member#: 155819
Vehicle:2004 Impreza WRX PSM |
Lots of lube or wd40 haha
04-24-2009, 10:24 PM | #6 |
Member#: 155819
Seriously tho....that's what I used, it'll stretch like hell
04-25-2009, 07:24 PM | #7 |
Member#: 143149
Vehicle:2006 gmc envoy stealth |
a stock boost control system on a subie has some nice reducers made of plasic. I reused them with 3/16ths and 1/8th vac tubing. My tial 38 mm is plumed with a Grimmspeed bcs using a few stock adapters and some red silicone tubing.
Deadbolt TD05H-20G Turbo and P&L Mortorsport 44mm EWG kit | kwan_1104 | Engine/Power/Exhaust | 14 | 07-07-2009 11:59 PM |
90* hose from turbo to IC issues` | nation1979 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 06-26-2009 10:12 PM |
WTB: STi RED SILICONE ELBOW HOSE from turbo to y-pipe intercooler | adjasont | Private 'Wanted' Classifieds | 4 | 05-20-2009 12:09 PM |
WTB: T connector and hose from turbo to T | bwco | VIC Private Classifieds | 5 | 04-10-2008 03:06 AM |
