Welcome to the North American Subaru Impreza Owners Club Thursday February 22, 2018
Mid Atlantic Impreza Club
Old 06-13-2005, 02:09 AM   #1
AzNStiImpreza
Member#: 17181
2015 Subaru WRX
Red / 2012 RR Evoque
Default WRX power steering resevoir pump
anybody have a WRX power steering resevoir???
it is much needed, because... i neet it.
if you do let me know, and name your price.
the closer it is to free, the better
sanQ,
vu
AzNStiImpreza is offline   Reply With Quote
Old 06-13-2005, 08:30 AM   #2
agterlik
Member#: 41626
SPB We make people
quit teh internet
haha you overlooked getting this as well .....did you atleast remember to get the power steering lines beforehand? Hopefully you can find a cheap used resevoir....otherwise you are gonna pay $70ish for a new one like this sucker did.
agterlik is offline   Reply With Quote
Old 06-13-2005, 10:14 AM   #3
CaptinMorgan97
Member#: 57634
2005 STI
Man yesterday pissed me off.
**NOTE** He needs the reservoir not the pump.
Yea no reservoir.
The lines came with the engine luckily.
The 04 WRX tranny has a stud in the bell housing going to the engine. The 03 WRX engine has a stud in there as well in the same location. Had to take 3 hours to get the tranny off again and drill that sucker out.
Vu. You still need a trailing arm nut and bolt. Donít forget that one.
CaptinMorgan97 is offline   Reply With Quote
Old 06-13-2005, 11:38 AM   #4
AzNStiImpreza
Member#: 17181
2015 Subaru WRX
Lachute Subaru - "we are sending you everything, all you need is the stock airbox, and the maf senser"
me - "ok"
turns out, i'm missing a power steering reservoir, fuel pump controller, and God knows what else when i get everything in place. . . this is exactly why i went to lachute and not other vendors for a wrx driveline. . . i didnt want to deal with sourcing missing parts. . . well. . guess not.
so please, anybody with a power steering reservoir, let me know. thanks.
Old 06-13-2005, 01:03 PM   #5
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
If you order it new it comes with the cap, so donít order it separateÖ and on that note, I have a cap if you get one used which doesnít have it
Also, donít start the motor without fluid running the pump otherwise youíll burn it up. I too sat around waiting for my reservoir and ran both lines into a bottle of power steering fluid. A little make-shift but at least you can start and run the motor and continue with the swap without burning the pump.
Howís it going by the way?
xcntrk75 is offline   Reply With Quote
Old 06-13-2005, 02:40 PM   #6
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
ur gonna have to get the rs line welded to the wrx line after where they screw on
ImprezaRSfan! is offline   Reply With Quote
Old 06-13-2005, 03:31 PM   #7
AzNStiImpreza
Member#: 17181
2015 Subaru WRX
we've only worked 2 Friday nights, on saturday night, and 2 sundays on the car, with a lot of fooling around. but so far we've gotten most of the WRX on the car except the front axels, and the driveshaft.
wiring hasnt started, other than the fact that i've hacked the wrx harness that i have already so it is engine standalone whatever. still dont know if i did it right. i tried to be as safe as possible. most guys said they have about 30 splices, including lachute, but it seems like i have more than that. i dunno. . .
im gonna need some big help when it comes time to do the fuel pump controller. the mechanic at Lachute tried to explain it to me, but his english was rather poor and i couldnt understand a damn thing.
vu
Old 06-13-2005, 04:25 PM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Dude the fuel-pump controller is fairly easy. I installed mine up by my ECU on a 12Ē whip as it only required one new wire to be ran part way back as opposed to mounting it in the rear where two new wires must be ran. Also, if you donít have the plug/wiring, donít worry. I cut the plastic surround off of my unit then soldered the wires directly with heat-shrink. You can also try using spade-connectors but I found it to be too tight of a fit which risks shorting between terminals. Much saver to solder individually if you donít have a plug:
Old 06-13-2005, 04:36 PM   #9
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
nice mounting it there, mines in the rear
dude is that what ur wiring looks like after ur swap? that uhh godly stock looking
Old 06-13-2005, 04:41 PM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
You mean like this:
or possibly like this:
What's wrong with it?
Old 06-13-2005, 05:10 PM   #11
AzNStiImpreza
Member#: 17181
2015 Subaru WRX
yea, i got to look at xcntrk75's car in person, and his wiring is the best i've seen. it looks like the car came with the motor stock. it is pretty gangster if you ask me.
Old 06-14-2005, 05:32 PM   #12
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
well i dont care about the wiring under the hood, mine looks like that too, but down by the ecu, thats where i did my splicing, so its really "thick" down there, yours looks stock tho.
Old 06-14-2005, 11:45 PM   #13
AzNStiImpreza
Member#: 17181
2015 Subaru WRX
can somebody give me directions on how to wire up the fuel pump controller???
thanks =)
04 wrx Power Steering pump 04wrxGreg Private 'Wanted' Classifieds 4 06-04-2010 11:29 PM
WTB: WRX power steering lines and resevoir bottle with hoses!! Never_Satisfied1 Private 'Wanted' Classifieds 0 02-20-2009 02:50 AM
looking for: power steering resevoir xtian MWSOC Private Classifieds 2 07-10-2008 02:39 AM
WTB: ss clutch hose, power steering resevoir verendia Tri-State Area Private Classifieds 0 03-10-2008 10:45 PM
WTB: WRX power steering fluid resevoir Mumbles New England Impreza Club Forum -- NESIC 5 08-15-2004 04:15 PM
