09-20-2008, 03:22 PM | #1 |
Member#: 65728
Vehicle:2007 STI SWP |
Corpus Christi: Help, I can't get my IC back on my 07 STI
Hey guys,
Its rediculous I know but I can not get my IC back on to my 07 STI! If anyone knows some tips or tricks please let me know! If you are able to stop by I am located off of Ennis Joslin in corpus christi. -Ryan
09-20-2008, 03:31 PM | #2 |
Member#: 23676
NESIC
Vehicle:. |
remove the drivers side bracket altogether
Start by getting the hose onto/close to onto the turbo outlet Then wiggle the TMIC outlet into the tb hose. It will likely fold in on the bottom, use a screwdriver in from the top to pop it out. its POSSIBLE to punch a hole in that hose, but its fairly difficult to damage, so be semi careful Once you have these 2 hoses on, pull the TMIC towards the pass fender and tighten the turbo outlet to elbow hose clamp Then tighten the clamp in the hose to the throttlebody, tighten the clamp closest to the throttlebody first. Pull the TMIC down towards the throttlebody till the hose bottoms out, then clamp it. NOW, Reinstall the drivers side TMIC bracket, using the 2 bolts on the top of the manifold. Leave them plenty loose so you get lots of play with the bracket. Get the 2 bolts STARTED in the side brackets on the TMIC. DONT TIGHTEN THEM YET Once they are both started pretty well, maybe 1/2 way in. THEN tighten the drivers side bracket on the manifold. Then tighten the 2 bolts on the sides of the TMIC down. /reinstall |
09-20-2008, 03:51 PM | #3 |
Member#: 117016
TXIC
Vehicle:2006 STi Obsidian Black |
I usually put a little silicone spray lubricant on the inside of the hoses and it really helps them to slide back on. I find it really helps with getting the elbow hose back on the turbo. Good luck!
09-20-2008, 04:16 PM | #4 |
Member#: 65728
Hmmm...I can get the turbo hose on now no problem, but the TB hose is a PITA!
09-20-2008, 04:24 PM | #5 |
A. Moderator
Moderator Member#: 21095
TXIC
Vehicle:RIP KTH & LMFH '09 Crystal red Tintcoat |
If you got a 90 degree hook, you can get the throttle body hose on. Start out trying to wiggle the bottom part of the hose, then work your way up. If you do have KY lube, it helps too.
Mika |
09-20-2008, 04:34 PM | #6 |
Member#: 184412
TXIC
Vehicle:1989 Jeep Wrangler Cherry Red |
When you are done and are bored feel free to come out here. I'm stuck at home until I get my injectors in the mail. 210-445-9402. I'm out by 37 and 77(kingsville)
09-20-2008, 04:56 PM | #7 |
Member#: 4415
TXIC
Vehicle:2001 2dr RS STM 92/94 Confused SVX LSL |
Looks like Davenow knows what he talking about, and some silicone spray lube would'nt hurt either. I'd go by and help you out, but I'm at work till 10:30.
09-20-2008, 05:58 PM | #8 |
Member#: 65728
Thank you davenow! I took your advice and removed that bracket. I also used a 90 degree bent awl type of tool and got the TB on pretty quickly after that!
09-21-2008, 12:07 AM | #9 |
Member#: 59871
TXIC
Vehicle:2004 STi - Silver FPGreen,FMIC,Wisecos,MSPT |
Shoot, I replied in your other thread about this. Your location says Pensacola. If I knew you were in Corpus, I would have swung by and gave you a quick hand.
can't get door cards back on | fl4tsc | Car Audio, Video & Security | 23 | 12-17-2008 12:42 PM |
I can't get my strut back on my car, help? | Gso2k | Brakes, Steering & Suspension | 10 | 07-10-2008 12:43 AM |
Can't get a base map on my car? Voltage? | kakarotoni | AccessPort | 2 | 06-20-2008 12:43 AM |
Am i retarded? Can't get airbox cover back on | mc2 | Legacy Forum | 5 | 02-03-2007 02:45 PM |
