Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 08-29-2007, 04:14 AM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default 02 Bug eye with Gt35 R Turbo, 2.5 Short block, Ecutek
This car has stock 02 WRX heads and a 2.5 L short block
The car runs the Ultimate Racing Gt35 R kit and is using the cold air intake that comes with the turbo kit. Its a stock size maf tube.
We tuned it to 20 psi when the MAF was maxed out and in need of a larger MAF, etc.
Car was on ecutek.
It will be interesting to see when the customer comes back with a big maf and then activates his alcohol injection.
AL
Dyno Flash is offline   Reply With Quote
Old 08-29-2007, 04:33 AM   #2
Bilyk WRX
Member#: 89058
2003 WRX 9.33/151mph
EJ257+PT7675 840whp
nice results for 20 PSI
cams, valves, springs - all stock?
Bilyk WRX is offline   Reply With Quote
Old 08-29-2007, 04:50 AM   #3
STimo
Member#: 110273
450 whp 30R STI
[email protected]
You should start dynoing on the same settings all the time... Everytime i see a chart it has a different smoothing factor, etc.. Makes it harder to judge, it'd be alot better if it was all the same.. What's the reason for running different smoothing settings on every other car??
STimo is offline   Reply With Quote
Old 08-29-2007, 11:43 AM   #4
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Moving the smoothing from 0 - 2 does not have a signficant effect on the apperance of the chart. Never the less, I will pull another dyno sheet with xero smoothing and post within the next day or so.
AL
Old 08-29-2007, 11:49 AM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
stock 2.5L internals?
wcbjr is offline   Reply With Quote
Old 08-29-2007, 02:07 PM   #6
Silver Ra
Member#: 123143
03 wrx 08 forester
98civic k24/k20 02 Rsx
wow 20 lbs on that high compression engine, im at 17lbs with a 30r i wont dare go over it without forged pistons
Silver Ra is offline   Reply With Quote
Old 08-29-2007, 03:44 PM   #7
IMPORTEDCARS
Member#: 56945
08 STI Base Model
Low compression CP pistons. We have a larger MAF we will\ be installing and raising the boost and turning on the meth injection. Stay tuned.
-George
IMPORTEDCARS is offline   Reply With Quote
Old 08-29-2007, 03:57 PM   #8
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Can't wait to see it. Great job by ICS and Al.
-Steve
WRX4eva is offline   Reply With Quote
Old 08-30-2007, 03:00 PM   #9
XS_WRX
Member#: 61519
2004 Subaru WRX
cammed,built,35R'd WRSTi
engine bay shots?
XS_WRX is offline   Reply With Quote
Old 08-30-2007, 03:06 PM   #10
KOERLONIOUS
Member#: 120129
Nice numbers..
KOERLONIOUS is offline   Reply With Quote
Old 08-30-2007, 10:07 PM   #11
JohnBowler
Member#: 38430
Default This is my car?
Car was on ecutek.
AL
Al - did you get the alky back yet? Did you open up the MAF yet?
JohnBowler is offline   Reply With Quote
Old 08-30-2007, 10:30 PM   #12
IMPORTEDCARS
Member#: 56945
08 STI Base Model
Im picking up the MAF tomorrow @ 2 p.m
-George
Old 08-31-2007, 01:42 PM   #13
JohnBowler
Member#: 38430
-George
Forgot to ask you when I had you on the phone...did you get the alky kit back yet?
Old 08-31-2007, 02:24 PM   #14
mannslayer
Member#: 94978
-George
Is it a custom piece, how much bigger than stock? I am going to have this same problem with my UR35R.
mannslayer is offline   Reply With Quote
Old 08-31-2007, 02:28 PM   #15
JohnBowler
Member#: 38430
It is an Ultimate Racing stock size MAF that was bored out to 72mm.
Old 08-31-2007, 03:50 PM   #16
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
What Tranny?
STiBottom is offline   Reply With Quote
Old 08-31-2007, 04:36 PM   #17
JohnBowler
Member#: 38430
Default tranny
Originally Posted by STiBottom View Post
What Tranny?
Jap spec STi NA 5 speed with strengthened internals and a 4:44 rear end. Adam from Z1 hooked me up. This was supposed to go into his car but he sold it and I was the beneficiary and it is a very rare piece. So far, it has held up very well. I have been driving this car daily with well over 400hp for a long time now but I very, very, very rarely stress the tranny.
Old 08-31-2007, 05:10 PM   #18
JohnBowler
Member#: 38430
Was told by George this morning that the car was actually at 18 psi, not 20 when the run was made that yielded 409whp.
Old 08-31-2007, 05:20 PM   #19
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
AL: Why does this car make such good power uptop even tho it has stock wrx heads..........you sure it doesnt have a ej257 longblock LOL
Old 08-31-2007, 05:26 PM   #20
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Yea it has a complete Ej257 in it.. Heads, cams, and CP OEM compression pistons. The only thing that it didnt have working was the AVCS.
Old 08-31-2007, 05:47 PM   #21
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
So it's a complete 257. Not Wrx heads.
JMK508 is offline   Reply With Quote
Old 08-31-2007, 05:53 PM   #22
JohnBowler
Member#: 38430
Correct. I didn't have any head work done, but they are STi heads.
Old 08-31-2007, 06:58 PM   #23
Paul
Member#: 56203
00 RSTI Coupe
i knew something wasnt right.LOL
nice car!
Old 08-31-2007, 07:19 PM   #24
JohnBowler
Member#: 38430
nice car!
So I've been told...
Old 09-06-2007, 02:02 PM   #25
JohnBowler
Member#: 38430
Default New dyno
Ok Al, time to post the new dyno. The car is finished and you put the bored out MAF in it so I am expecting a much higher HP number than the previous dyno sheet. Prove me right.
2.5 short block with 2.2 heads? Zero92828 Normally Aspirated Powertrain 7 05-02-2009 05:22 PM
2.5 short block in a 02 wrx blkhatch Newbies & FAQs 6 09-30-2008 03:49 PM
03 wrx with 2.5 short block and sti 6 speed platinum03wrx/sti Private Vehicle 'For Sale' Classifieds 0 09-19-2007 08:02 AM
02 bug eye with 2.5l hybrid swap quarter mile flon3y Proven Power Bragging 11 01-03-2007 05:13 PM
