Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 11-08-2017, 08:39 AM   #1001
wessingd
Member#: 477116
2016 WRX Premium
Just got the MAP stage 2 kit installed yesterday. Before that my 2016 wrx was bone stock..all I can say is WOW, what a night and day difference over stock. Driveability is 100x better than stock, I can actually drive it without jerking all over the place. Power feels very solid almost all the way to redline.
If anyone out here is debating between the muffler/muffler delete, please do yourself(and anyone living with 5 miles of you) by getting the muffled version. I was debating forever and ended up getting catless with mufflers, and boy am I glad I did any louder it wouldn't even be close to suitable as a daily(at least for me).
Tune seems very solid. I have had a few knock events(highest of -2.81, but DAM has remained a constant 1) and have emailed some logs to Ian, hopefully I hear back from him soon. To anyone on the fence about purchasing the kit just get it over with and pull the trigger, I can guarantee you won't regret it.
wessingd is offline   Reply With Quote
Old 11-08-2017, 09:08 AM   #1002
lawadm1
Member#: 439406
2016 WRX Premium 6MT
Black - MAP Stage 2
So you're going to spare us the battle with the turbo bolts/studs? That's the best part. And if you didn't have any problems with them then you suck.
lawadm1 is offline   Reply With Quote
Old 11-08-2017, 09:33 AM   #1003
wessingd
Member#: 477116
2016 WRX Premium
I took it to a local performance shop for install as I don't have the time, 3 hours to install everything and knowing it was done properly give me peace of mind But I did ask the tech if he had issues w the J-pipe removal and he said no problems at all, my car is a 16 w 29k miles.
Old 11-08-2017, 09:52 AM   #1004
mishapopa
Member#: 393629
2015 WRX
Agreed with everything but to be honest the tune I see as a temporary get-by. I ended up doing EGR and TGV deletes as well as a MAP TMIC and a Perrin charge pipe and getting a proper e-tune cleared up all the knock and concerns.
You want more night and day difference? Do your engine and tranny mounts
mishapopa is offline   Reply With Quote
Old 11-22-2017, 03:56 AM   #1005
wessingd
Member#: 477116
2016 WRX Premium
For anyone wondering what the catless muffled version of this kit sounds like, here is a little clip of my car. The video just doesnít do justice to the sound, but it can give you an idea.
Old 11-22-2017, 08:55 AM   #1006
maperformance
Member#: 141043
2015 WRX
Love it!
MAPerformance Stage 2 Kit- 2015+ WRX - YouTube
maperformance is online now   Reply With Quote
Old 11-22-2017, 09:28 AM   #1007
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Hey Misha, do you happen to have any logs comparing before and after the TMIC install? I'm curious about the efficiency of that MAP unit. Thanks!
sth36 is offline   Reply With Quote
Old 11-22-2017, 09:29 AM   #1008
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Also, how's the rebuild going Ian? Haven't seen an update on the shop car in quite some time. Hope that's a sign that things are going well and you boys are staying crazy busy.
Old 11-22-2017, 09:35 AM   #1009
maperformance
Member#: 141043
2015 WRX
Yeah, it's been hectic for me lately, but it's all together! Currently have 6k miles on the build.
Final numbers so far on 93 octane:
Old 11-22-2017, 10:29 AM   #1010
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Ian,
Any Black Friday deals on the MAP stage kits?
gn4rwhals is offline   Reply With Quote
Old 11-22-2017, 10:52 AM   #1011
maperformance
Member#: 141043
2015 WRX
Indeed
Originally Posted by gn4rwhals View Post
Ian,
Old 11-25-2017, 02:31 AM   #1012
hibby50
Member#: 360213
Pretty strange readings from my AP tonight. I've been running the stage 2 tune with MAP catted j-pipe and MAP intake for about a week now. Aside from the first day where I got fine knock learn of -4 and a Feedback knock of -2, I have stayed at -1.41 and 1.0 DAM for an entire tank of gas.
I put 20 bucks of shell 93 in, and things were going the same until a drive i had tonight. I did a hard pull from 1st and got a fine learn of -4, the DAM dropped to 0.875, but the weird part is the feedback knock was at 0. Dam then rose to 0.9-ish before i made it home, but the fine learn was still hitting 4 every time I was in 2nd at low rpm.
I was under the impression that it was like a chain of events. If you get feedback knock it'll change the fine knock and if you get too much fine knock itll change the DAM. So i'm a bit confused how my damn could drop and my fine knock learn could be so high when no feedback knock was even registered.
I'm gonna grab some logs tomorrow if it's still happening.
Edit: also what's the target boost for the latest revision? I hit 22.8lbs on that pull and it was just under 40 degrees out
hibby50 is offline   Reply With Quote
Old 11-26-2017, 01:53 AM   #1013
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Depending on what knock monitor is active you may not see any FBK.
The only time my DAM dropped it registered FKL and it will/did take multiple cycles of driving in that RPM range to unlearn it.
Old 11-27-2017, 09:19 AM   #1014
maperformance
Member#: 141043
2015 WRX
Did the knock occur during the WOT pull? Or was it between shifts? FKL will always repeat the scenario as it's trying to "re learn" that specific RPM range that it detected the knock. If this does continue, I would like to have some logs sent in sir.
Old 11-27-2017, 08:53 PM   #1015
Mattfetch
Member#: 462030
2017 WRX
CWP
I was also wondering what the target boost was for the stage 2 tune. I was hitting a little over 19lbs today
Mattfetch is offline   Reply With Quote
Old 11-28-2017, 08:57 AM   #1016
maperformance
Member#: 141043
2015 WRX
Target boost is 20 psi.
Old 11-29-2017, 08:50 AM   #1017
hibby50
Member#: 360213
I'm not sure where it knocked, the strange part was the FBK stayed at 0 despite the DAM and FKL changing, but I believe the gas I got was bad. I ran the tank empty and filled up at my normal BP station and reset the ecu learning and i haven't seen more than 1.41. I did take some logs but it was during the relearn and there were no major knock events. Not sure what cause the almost 23lbs of boost either. I'm keeping my eyes on the AP though.
Old 12-08-2017, 04:11 AM   #1018
Raptoreye45
Member#: 478896
Question Looking at buying
Hey guys was wondering if anyone has a sound clip of the catless muffler delete version. Just curious as to how loud it really is versus the cat less muffler version. Thanks
Raptoreye45 is offline   Reply With Quote
Old 12-08-2017, 07:35 AM   #1019
wessingd
Member#: 477116
2016 WRX Premium
I can tell you that the muffler delete version will be obnoxiously loud and your neighbors will hate you. I have catless w mufflers and itís plenty loud.
Old 12-09-2017, 09:35 PM   #1020
Stanley Yahtzee
Member#: 466470
2018 WRX
how safe are these numbers? ive heard that over 350wtq is bad for a stock engine. but ive also heard that a stock engine should be able to hold 22-23 psi boost reasonably well and you said this tune only goes to 20.
Stanley Yahtzee is offline   Reply With Quote
Old 12-11-2017, 01:28 PM   #1021
lawadm1
Member#: 439406
Black - MAP Stage 2
I have the catted w/ mufflers version, and the neighbors still let me know they can hear me leave in the morning. I think it's the perfect sound, but that's just my two cents.
Old 01-05-2018, 01:19 PM   #1022
maperformance
Member#: 141043
2015 WRX
Super over due, but we now have different tip options for our cat back!
We now have options for a single wall, straight cut tip, and a double wall slant tip, both offered in polished or burnt tip!
Old 01-05-2018, 01:26 PM   #1023
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
The double-walled tips look nice!
YungBoba is offline   Reply With Quote
Old 01-05-2018, 04:52 PM   #1024
maperformance
Member#: 141043
2015 WRX
Yeah, those are my favorite too
Old 01-05-2018, 06:31 PM   #1025
Stanley Yahtzee
Member#: 466470
2018 WRX
i like the middle one, it will go with my gold wheels im going to get in the spring. but how thick is that color on there? like how long will it stay looking gold like that? any special way to clean/treat it so it lasts longer?
