Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 04-14-2016, 10:06 AM   #1
joshua_15wrx
Member#: 411847
2015 WRX Premium
WR Blue
Lightbulb Crawford V3 AOS - 2015 WRX - Install Tips
Just installed the Crawford AOS V3 on my 2015 WRX. A few things...
1) The hose clamps they send you are total pieces of s*hit. You will need 10 #6 and 2 #8 clamps. I got a 2 pack of the #8 at Lowe's and a 10 pack of the #6 at Home Depot. Both stainless steel and much better quality.
2) The instructions Crawford provides are somewhat helpful. I found an install thread here at NASIOC that was much more helpful. Crawford also has an install video that, to my surprise, it's different than the .pdf instructions. Use all 3.
3) You will need a LOT of patience. Attaching the new hoses and securing them with the clamps is a very frustrating process. Having a bunch of tools certainly helped a lot. Having someone to help you and provide lighting is a must.
4) If you are planning on getting a brake master cylinder brace, get the Perrin not Cusco version. The Cusco version will interfere with the AOS due to the screw (that goes to the cylinder) being too long.
5) When installing the coolant lines, keep the radiator cap on (closed). Also have the new hose nearby such that you can put it on the coolant line as soon as you remove the OEM one. This will help you avoid wasting coolant and the consequent mess.
6) The primary air hose (thickest one) that goes from the top of the AOS to the turbo inlet is too long. I had to cut ~3 inches so that it fit properly. Also do not secure it to the manifold (using tight-wraps / straps) until you have connected all the hoses to the AOS. Trust me...
7) When you remove the intercooler, clean the inside of the inlet and the charge pipe as well. You will find a nasty oil film on it. Don't panic, this is why you got an AOS for.
8) Once you're done take the car for a spin and make sure it goes up to normal operating temperature. Inspect the coolant lines for leaks and make sure all other lines are secure.
9) This mod is not for the faint of heart. If your mechanic skills are lacking, let someone else do it. I would rate the difficulty of the install at a 4 out of 5.
Best of luck! Let me know if you have questions or if you need help with the install around the Cincinnati area. Cheers!
joshua_15wrx is offline   Reply With Quote
Old 04-14-2016, 11:02 AM   #2
Cisco Kidd
Member#: 418558
2015 WRX
Got to install mine, what was time it took you roughly
Cisco Kidd is offline   Reply With Quote
Old 04-14-2016, 11:20 AM   #3
joshua_15wrx
Member#: 411847
2015 WRX Premium
WR Blue
Net time, like 3-4 hours. Get the hose clamps in advance and you should be all set.
Old 04-14-2016, 11:39 AM   #4
Cisco Kidd
Member#: 418558
2015 WRX
Yes I have already ordered hose clamps Did you feel any need to replace the provided hoses w any of better quality to prevent any collapsing as some have mentioned w one of the specific lines? Although Crawford says that is normal and not of concern. This along w an EGR delete is definitely worthwhile.
Old 04-14-2016, 12:43 PM   #5
joshua_15wrx
Member#: 411847
2015 WRX Premium
WR Blue
For peace of mind and longevity I would advise to get better clamps.
Initially I started the install using their clamps. When I was almost done one of them (going to coolant line) broke while tightening. That's why I got better ones and replaced them all.
Old 10-02-2016, 10:46 AM   #6
1sikRX
Member#: 418222
Can't you explain what size clamps you had to get gonna be doing this install soon, thanks.
1sikRX is offline   Reply With Quote
Old 05-05-2017, 01:43 PM   #7
djemzine
Member#: 361609
2015 WRX CVT
WRB Pearl
Just bumping this thread to see if the V3 AOS is heated by coolant, like the IAG?
djemzine is offline   Reply With Quote
Old 05-08-2017, 10:09 AM   #8
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
Why didn't you just look at the install instruction, maybe see if coolant lines are involved?
uofime is offline   Reply With Quote
Old 05-09-2017, 08:39 PM   #9
Supple1
Member#: 316143
It is heated by coolant
Supple1 is offline   Reply With Quote
Old 07-22-2017, 07:57 PM   #10
Crawford Performance
Member#: 42075
Correct, it is heated by coolant but it is also in a location where it does not get a cold air blast from the hood scoop like our V1 and V2 AOS.
After 3 years of use / testing on this Dual chamber AOS we will be deleting the coolant lines on our next manufacturing batch. We have found that there is no need for heating our Dual Chamber AOS to keep the sludge buildup from happening inside the unit.
Our Dual Chamber V3 for the BRZ has been on the market now for 5 years without any coolant lines and without any sludge buildup issues. Our new Dual Chamber V3 for the EJ platform does not have any coolant lines as well and also does not have any sludge buildup.
Crawford, Quirt
Crawford Performance is offline   Reply With Quote
Old 07-22-2017, 08:27 PM   #11
Bigfella
Member#: 444734
I've being running my V3 on my XT with no coolant lines connected for just over 1 year and it doesn't have any condensation problems.
I live in a climate which is probably similar to CA, so I cant say if it would be the case in other climates.
My unit is also relocated back to were the LHD brake master cylinder lives.
Bigfella is offline   Reply With Quote
Old 07-23-2017, 10:47 AM   #12
Member#: 42075
This is good to hear and totally expected from our Dual Chamber AOS.
Old 07-24-2017, 02:44 PM   #13
documentarian
Member#: 382402
15 wrx
Crawford, Quirt
Is there any chance that you might provide your customers with the option to get it with or without the coolant lines? I live in a place that gets pretty cold in the winter and was interested in purchasing one of your v3's specifically because it has coolant heating, keeps the oem pvc valve and the ease of installation.
documentarian is offline   Reply With Quote
Old 07-24-2017, 08:08 PM   #14
Member#: 42075
At the moment we have hundreds of the DIT units in stock that have coolant lines so you should be good on ordering one. That said, if we feel there is a need for coolant lines in a climate like yours then we will add them back into the manufacturing process instantly
Team Crawford
Old 08-22-2017, 06:34 PM   #15
lowbee
Member#: 254317
2011 STi
Is the a link to more information about the Dual Chamber design of v3 and why it is superior to v2 ?
A few pics would be nice
lowbee is offline   Reply With Quote
Old 08-22-2017, 09:07 PM   #16
Member#: 42075
Here is a link to some info on our website; https://crawfordperformance.com/blog...-oil-separator
One of the best things about the dual chamber design found on all our V3 AOS is there is no need to take it off to have your car smoged. Our Dual Chamber V3 retains all the original smog components and they are still located in their stock locations.
The install time is easily 50% less so the install cost will also be 50% less.
FYI, we are having a Group Buy at the moment with the potential for a 30% discount on the retail price. https://forums.nasioc.com/forums/sho...6#post45295716
Old 08-22-2017, 10:24 PM   #17
lowbee
Member#: 254317
2011 STi
So I read the installation instruction and please let me know if my understanding below is correct...
  1. Port 4 double as the oil return line as well as vent from Crankcase
  2. This V3 AOS provide NO AOS function for the potential path from the 2 valve (rocker) cover vents to the intake duct on a EJ engine
Old 08-22-2017, 10:42 PM   #18
Member#: 42075
That's correct, the port that comes from the PCV valve is also where the de-atomized oil returns to the crankcase.
The ports you are speaking of that go to the valve covers on an EJ motor are not a vent for the valve covers as you stated. This is where the air enters the motor so it can vent out the center crankcase vent, with the system connected this way there is no moisture buildup within the motor or any of its venting hoses as it is all sucked out through the PCV valve and through the other side of the crankcase vent which goes to the intake tube.
QC
Last edited by Crawford Performance; 08-26-2017 at 02:55 PM. Reason: clarity for an EJ motor
Old 08-22-2017, 10:53 PM   #19
lowbee
Member#: 254317
2011 STi
....The ports you are speaking of that go to the valve covers are not a vent for the valve covers as you stated. This is where the air enters the motor so it can vent out the center crankcase vent......
Thanks for the quick response. So those 2 valve cover ports are inlets to the motor only and under no condition does the flow reverse ?
Can you help me understand why other AOS and dual catch can setup put AOS function on those 2 ports back to the intake duct ?
I want to believe you but I just need a little more help before I put a deposit down
Old 08-22-2017, 11:08 PM   #20
Member#: 42075
Your welcome,
If you have a broken piston then there could be more crankcase pressure than can make it out the block vent, in this scenario air could change direction and come out the valve covers. On our V3 AOS for the FA motors we have these lines going through a second chamber within the AOS just in case, but we have never seen any oil enter this second chamber.
Almost all the other AOS units on the market followed our hose routing on our V1 and V2 units as we were the first company to design a specific AOS system for the Boxer.
If you purchase our AOS and it does now work as stated then we will be happy to return your moneys.
QC
Old 08-22-2017, 11:55 PM   #21
lowbee
Member#: 254317
2011 STi
....If you purchase our AOS and it does now work as stated then we will be happy to return your moneys....
That's good to know. Last couple of questions
  1. What is the capacity of the AOS ? How much oil can it hold ?
  2. Does the oil only drain back to the pan when engine is off ?
Old 08-23-2017, 12:10 AM   #22
Member#: 42075
I am not sure of the capacity as it is not designed to hold oil, rather separate the oil mist from the air.
The oil drains back whenever the PCV valve is open, which is whenever there is manifold vacuum. While making boost the PCV valve is closed.
We have been using our Dual Chamber V3 AOS on our boosted BRZ for almost 5 years now, it is also used on the DIT platform that has been out for the same amount of time. Our Dual Chamber V3 system / concept has been working fantastic with zero issues.
QC
Old 08-23-2017, 12:34 PM   #23
WRXTACY
Member#: 15339
2015 CWP WRX
Flex Fuel tune by Phatron
will this AOS fit with the Cobb Flex Fuel kit? the fuel lines are different.
also the AOS will come with the new high pressure hoses to prevent them from collapsing?
thanks
WRXTACY is offline   Reply With Quote
Old 08-23-2017, 12:50 PM   #24
Member#: 42075
thanks
Correct, my car has flex fuel which is the one I designed the AOS on, so fitment with the flex fuel lines is good.
And the one hose that sees vacuum has been replaced with a high pressure hose to prevent collapsing which has been seen on a handful of installs. FYI,My personal car still has the original style hose which has been on it for 40K miles now.
QC
Old 08-23-2017, 04:35 PM   #25
WRXTACY
Member#: 15339
2015 CWP WRX
thanks for the quick responses...one last question before I put my deposit in for the group buy... will this fit if I have a Process West Verticooler? thanks
