Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 12-14-2017, 02:14 AM   #51
Scoobman20
Member#: 388015
Tacked and ready for test fitment. Now I just need to figure out how the heck I'm going to weld those runners onto the merge collector.
Scoobman20 is offline   Reply With Quote
Old 12-14-2017, 02:56 AM   #52
ForesterinRHD
Member#: 479178
Bm! K. Bkm. B. K
ForesterinRHD is offline   Reply With Quote
Old 12-15-2017, 12:21 AM   #53
immortal
Member#: 408776
15 WRX EFR 7064
Will you be able to get the intercooler pipe on to the top there at that angle?
immortal is offline   Reply With Quote
Old 12-15-2017, 12:57 AM   #54
Scoobman20
Member#: 388015
Haven't moved the angle of the outlet since the test placement of the turbo. I think I had it that way to clear the everything in the front but there will definitely be somewhat of a bend. If too much I may have to adjust it and rework the wastegate bracket. We will see during the test fit.
Old 02-04-2018, 06:12 PM   #55
Scoobman20
Member#: 388015
Well back to the drawing board. Turns out I did not fully account for how far forward the oil pan is. Looking back at grimmspeed's photos it looks like they had to move the turbo a lot closer to the radiator fan than I thought. So I need to recut and re-tack the headers. I also need to adjust the outlet angle due to the new position. Luckily I think I will now have room for the standard efr bracket. Will post more pictures when fitment is done along with the charge pipe roughed in.
Old 02-07-2018, 10:32 AM   #56
Scoobman20
Member#: 388015
Okay good news and bad news. After a day under the car test fitting I was able to finally get a satisfactory placement. I also got the charge pipe roughed in. Luckily the Cobb intake only needed a 3" coupler and it was good to go. I will need to extend the j-pipe about 2.5" and weld on the v-band flange. Definitely going to need a turbo blanket to present the fan housing from getting too hot. Bad news is I was so busy I forgot to take pictures when I had the charge pipe in.
Old 02-07-2018, 01:31 PM   #57
WRXTACY
Member#: 15339
2015 CWP WRX
Flex Fuel tune by Phatron
awesome progress!
WRXTACY is offline   Reply With Quote
Old 02-07-2018, 02:31 PM   #58
playslikepage71
Member#: 395882
2016 WRX
That's the benefit of having a FARO arm or laser point cloud scanner and chucking the OE parts in CAD
playslikepage71 is offline   Reply With Quote
Old 02-07-2018, 05:03 PM   #59
fredrik94087
Member#: 337075
2015 WRX Stg3 SOLD
Very impressive effort so far.
I am going to share a word of caution. You will need a larger intake than 3" if you plan on running more than 24 psi. I am not a boost expert, but I can tell you that my MAF, with a 3" intake, was limited to 24psi. When I went over that, I threw a code.
fredrik94087 is offline   Reply With Quote
Old 02-10-2018, 10:51 PM   #60
Scoobman20
Member#: 388015
You maxed the voltage or the calculated load limit for the ecu?
Old 02-11-2018, 10:50 PM   #61
fredrik94087
Member#: 337075
2015 WRX Stg3 SOLD
I maxed the MAF voltage.
Old 02-12-2018, 05:58 AM   #62
ericdet
Member#: 327563
2018 Civic Type R
CW
It must be a tricky MAF setup. I've seen 75MM MAF's support a couple hundred more WHP.
ericdet is offline   Reply With Quote
