Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 11-21-2017, 08:42 AM   #1
scotte30m3
Member#: 409636
2015 WRX
Default The factory muffler tips hang awkwardly low...
The factory muffler tips hang pretty low on my 2015 WRX, does any one know if swapping the hangers with GrimmSpeed adjustable hangers will have any effect on raising the tips?
scotte30m3 is offline   Reply With Quote
Old 11-21-2017, 09:22 AM   #2
absolutezero
Member#: 432684
2016 WRX Limited 6MT
WRB / "Stage Whatever"
Do you have the regular exhaust or the STi Performance Exhaust that was an option from the dealer?
I had the STi Performance Exhaust and it did hang a little low. I ended up getting an aftermarket setup but I have heard that people have used Kartboy hangers to lift up the tips and had good success with it
absolutezero is offline   Reply With Quote
Old 11-21-2017, 09:38 AM   #3
scotte30m3
Member#: 409636
2015 WRX
It’s the standard exhaust... I like the way the tips look they just hang too low.
Old 11-21-2017, 12:35 PM   #4
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I agree, the stock and the STi exhaust hang stupid low. It definitely takes away from the aesthetic. So with that said:
Our adjustable hangers offer stock height (same as KB) and extended length. They will help to increase the height that your stock exhaust hangs because they will not sag or move around as much as the stock hangers do. However if you're looking to raise the tips a significant amount (an inch or so) our hangers are not going to do it for you. I do not know what the elimination in deflection is, but its probably on the scale of around a quarter inch.
With that said: I might bring my car to an exhaust shop and have them adjust the hangers to raise the exhaust up. It should be relatively inexpensive. And at the same time I would still recommend the exhaust hangers to keep everything from potentially moving around too much and causing contact somewhere on the exhaust system, chassis or bumper.
Hope this helps!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 11-21-2017, 01:22 PM   #5
IndecisiveS12
Member#: 463349
2017 WRX Sport
World Rally Blue
people have been using these hangers. instead of using the first hole, you actually flip it upside down and use the 4th and 3rd hole (they're closer than the 1st and 2nd).
For clarification, the top is where that space in the hanger is.
I was going to do this myself and I actually bought two for the rear hangers, but then when I changed to ETS Axlebacks I found out that ETS actually addressed this gap/sagging issue when they created their axleback so I didn't end up using the hangers.
https://www.amazon.com/uxcell-Vehicl...exhaust+hanger
T-WRX has a video on it
as does Jobber (LastHumansGarage)
IndecisiveS12 is offline   Reply With Quote
Old 11-21-2017, 03:57 PM   #6
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Wow that's clever, I designed these hangers and I never even considered that. Thanks for the info!
So if you were to attempt this with our exhaust hangers it should raise the exhaust by nearly 3/4in, which is about how much I'd move it up in the first place. The spacing looks the same as the ones you linked, so I'd wager they would work exactly the same.
OP, if you do end up attempting this with our exhaust hangers please let me know, as I'd definitely like to see it. I'd do it myself, but I don't think I still have a stock exhaust to try it with.
Good lookin out guys, very clever!
Chase
Engineering
Old 11-21-2017, 06:08 PM   #7
scotte30m3
Member#: 409636
2015 WRX
Chase
Engineering
I put my ETS “quiet” exhaust back on the car, but the drone is killing me... so I’m looking at my options.
1. One option is putting the stock axle back on and doing a boost activated cut it out at the mid pipe with a hob switch to turn it on and off as necessary. (Hence why I want to fix the saggy stock exhaust)
2. Another option is doing a boost activated cut off and force one side to be closed when not under boost to act like a helmholtz resonator.
3. Option is to leave it alone and deal with the drone...
Old 11-21-2017, 10:04 PM   #8
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
Subscribed. I put the yellow hangers on but my tips are no longer centered and I didn’t think it made much of a difference. I was actually contemplating the GS hangers...
RussianTiny is online now   Reply With Quote
Old 11-22-2017, 12:17 AM   #9
GlarryHoodDIT
Member#: 460907
2016 WRX
Phatron Tuned
4. Resonator in the midpipe. Cheapest and easiest option.
GlarryHoodDIT is offline   Reply With Quote
Old 11-22-2017, 08:03 AM   #10
scotte30m3
Member#: 409636
2015 WRX
The ETS “quiet” exhaust has a resonator already in the mid pipe. 😐
Old 11-28-2017, 12:43 PM   #11
wrbrexx
Member#: 461037
2016 Subaru
World Rally Blue
Add another!
wrbrexx is offline   Reply With Quote
Old 11-29-2017, 10:46 AM   #12
scotte30m3
Member#: 409636
2015 WRX
Chase
Engineering
I just ordered the Grimmspeed Hangers...
I’m going the boost activated exhaust cut out and stock muffler route. (For now)
Old 12-03-2017, 03:59 PM   #13
RussianTiny
Member#: 387467
2018 WRX Limited
You guys who have installed the hangers is your exhaust still centered? I didn’t unbolt anything when installing the hangers.
Old 12-10-2017, 10:26 PM   #14
scotte30m3
Member#: 409636
2015 WRX
Just install the OEM mufflers with the Grimmspeed hanger... worked great.
Hint, the driver side hanger needs to be facing outward (or writing on the hanger toward the rear bumper) and the passenger side needs to be facing inward (or writing away from the the rear bumper).
Working on getting some pics posted.
https://photos.app.goo.gl/ocfuCBz13HEbGd5M2
https://photos.app.goo.gl/KQMSZsvOCzKidNrn2
Old 12-11-2017, 01:37 PM   #15
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Hint, the right side hanger needs to be facing outward (or writing on the hanger toward the rear bumper) and the left side needs to be facing inward (or writing away from the the rear bumper).
Thanks for the post and the pictures Scott. That really does look nice, and help out with the look of the OEM exhaust. I might just have to try this with the 2018 WRX we just picked up!
Chase
Engineering
Old 12-11-2017, 04:07 PM   #16
scotte30m3
Member#: 409636
2015 WRX
Chase
Engineering
While you’re at it go a head and make a boost activated exhaust cut out on a Hobbs switch... so you can turn it off and on at will, 😝
I’ll let the board know how it works out!
