Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 12-01-2017, 09:38 AM   #1
Kyle_132
Member#: 469152
Default Bad motor mounts on 17 wrx?
So as of recently Iíve been experiencing knock readings generally starting off in first and shifting to second. Obviously this isnít knock the engine isnít under any load. However, Iíve also noticed that I can feel my engine shake getting off the car in high load. It just seems far fetched due to the car only having 10k and only having a pro tune and intake. Just wondering if anyone else has had any motor mount issues so early in the cars life. I want to upgrade them if I have to since Iím going to do downpipes egr/tgvs and boost controller in a week or two.
Kyle_132 is offline   Reply With Quote
Old 12-01-2017, 09:44 AM   #2
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Maybe check the pitch stop brace? The earlier FAs has a really weak brace that Subaru issued a bulletin on, but even the revised piece is only 2mm instead of 1mm. Long shot but it's possible it ripped off. It's right under your intercooler so it should be easy to inspect.
sth36 is offline   Reply With Quote
Old 12-01-2017, 09:50 AM   #3
Kyle_132
Member#: 469152
Yeah Iíve heard of those going bad imma check that out when I get the chance too
Old 12-01-2017, 10:01 AM   #4
Chuckable
Member#: 447566
2017 WRX
Bad motor mounts are possible but not likely. Iím betting itís the tune. If you can, revert back to stock and see if you get the same phenomenon.
Chuckable is offline   Reply With Quote
Old 12-01-2017, 10:35 AM   #5
Kyle_132
Member#: 469152
Well Iím going back to my tuner in a week or so...and Iím planning on getting retuned since Iím doing other stuff. The readings Iím getting very well could be just the weather change. Itís colder in the morning at this time of year and thatís when I see it more the car was tuned in very hot weather like 87 or 86.
Old 12-01-2017, 10:35 AM   #6
Kyle_132
Member#: 469152
I live in Florida lmao
Old 12-01-2017, 10:36 AM   #7
ericdet
Member#: 327563
2018 Civic Type R
CW
I'll second that it is likely the tune. In regards to the motor mounts though, I've seen quite a few threads about missing bolts from motor mounts on the new generation. To finding them in the undertray to completely missing.
ericdet is offline   Reply With Quote
Old 12-01-2017, 11:16 AM   #8
Chuckable
Member#: 447566
2017 WRX
Me too, also with a tuned 17 WRX. Whoís your protuner?
Old 12-01-2017, 11:18 AM   #9
Chuckable
Member#: 447566
2017 WRX
Good to know ericdet, had no idea some were not tightened at the factory. They look like a pain to reach, too.
Old 12-01-2017, 11:59 AM   #10
mishapopa
Member#: 393629
2015 WRX
first time i hear about this
regardless, the stock motor mounts and trans are made of chewing gum, i suggest replacing them to perrin or groupN. best 2 mods i've done, and i've done a lot of mods. a lot of people on these forums seem to underestimate the difference beefier mounts make. not an easy installation (engine mounts) but so, SO worth it.
mishapopa is offline   Reply With Quote
Old 12-01-2017, 03:33 PM   #11
Kyle_132
Member#: 469152
Iím probably going to change the mounts regardless Iím tuned by mgw~ machines gone wild in Miami
Old 12-01-2017, 05:42 PM   #12
Chuckable
Member#: 447566
2017 WRX
Sort of off topic at this point, but how do you like them?
Old 12-01-2017, 09:10 PM   #13
Kyle_132
Member#: 469152
Theyíre pretty solid Mikey tunes down there sometimes. From what Iíve been told theyíre better with the EJ platforms and 4g63/4b11. The fa20 is still new to them but their tunes are still pretty solid yet generally more conservative on the FA20s than the other engines. Which I honestly donít mind my wrx is a daily
Old 12-01-2017, 10:03 PM   #14
Chuckable
Member#: 447566
2017 WRX
Yes, conservative is good. 10 extra hp on a street car if youíre sacrificing reliability just isnít worth it.
Old 12-02-2017, 10:22 AM   #15
Kyle_132
Member#: 469152
I completely agree..
Old 12-03-2017, 03:55 PM   #16
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
Which did you choose for your motor mounts? I have group N pitch and tranny mounts and I like em
RussianTiny is offline   Reply With Quote
Old 12-10-2017, 03:51 PM   #17
cdhissong
Member#: 479011
2015 STI
my 2015 sti broke a motor mount around 26K but it was replaced under warranty. I only launched the car maybe 10 times. only mod was COBB stage 1. was disappointed in the broken mount but at least the dealer fixed it without any questions.
cdhissong is offline   Reply With Quote
Old 12-11-2017, 10:38 AM   #18
mishapopa
Member#: 393629
2015 WRX
I have GroupN for all the mounts except the motor mounts are Perrin. I hate dealing with the cross member studs and simply like Perrin's design more. Also they're polyurethane so they'll last and are a little stiffer than GroupN motor mounts.
