Welcome to the North American Subaru Impreza Owners Club Wednesday June 18, 2025
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-23-2015, 09:02 PM   #226
drifterx
Member#: 25128
2005 Baja turbo
Ha, told you man
drifterx is offline   Reply With Quote
Old 05-19-2015, 07:36 PM   #227
nxwrxfx
Member#: 92011
02 EJ207 STi HTA68
05 EJ257 Baja STi 18G-XT
Baja Modders!
I have huge news on the front of an actual Stainless Steel 6-line brake line kit!
I've been in contact with the Operations Manger over at Techna-fit, and they have confirmed fitment of their SUB-1125 6-line kit for our Bajas!
I'm ordering a set this evening, and should have them installed in a few weeks if all goes as planned. Stay tuned!
nxwrxfx is offline   Reply With Quote
Old 06-02-2015, 10:27 PM   #228
nxwrxfx
Member#: 92011
02 EJ207 STi HTA68
Just responding to confirm that Technafit's SUB-1125 6-line kit fit like a glove on my '05 Baja Turbo!
Also paired with Hawk slotted rotors and Stoptech pads. Feels great!!
Old 06-11-2015, 02:30 PM   #229
starr-backsport
Member#: 257651
2006 5mt BAJA-T
Black black baby
I am assuming someone here knows an answer to this... will a 2006 baja-T wiring harness / ECU be plug and play with a 2007 wrx motor?
Looking at buying a baja-T that has a 2007 wrx motor w/ 35k miles simply bolted up to the transmission and motor mounts but still needs to be finished. Just trying to figure out if it will be worth the time and effort of buying this project or if its going to get complicated quickly requiring a wire merge, tune or having to buy a wrx ECU.
-Cory
starr-backsport is offline   Reply With Quote
Old 06-14-2015, 12:29 AM   #230
vthoma11
Member#: 423482
2005 Baja turbo
Carbon
Default Baja turbo HELP
I am new to the Subaru family. I purchased a 2005 Baja turbo last week. I would read a few posts on switching stock with sti turbos and tmic but it was really basic info. Any insight would be greatly appreciated. What all needs done to achieve this
vthoma11 is offline   Reply With Quote
Old 08-19-2015, 08:15 PM   #231
DigginBahazzzz
Member#: 417164
06 baha
blk
Default lowering my baha
does anybody no what springs to use to lower my baha?
DigginBahazzzz is offline   Reply With Quote
Old 11-23-2015, 06:24 PM   #232
starr-backsport
Member#: 257651
2006 5mt BAJA-T
Black black baby
Search for 2000-2004 lower springs for the OUTBACK on ebay. There are a couple different options.
For my own question... does my 2006 baja turbo have a catless up pipe? I know I have read that in 2006 subaru made that change. Not sure if the baja fell in that category though being that it is a bastard child. Any ideas? There is a sti uppipe local to me for a good price right now.
Old 11-29-2015, 01:13 AM   #233
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
It will likely depend on the build date if it does or not. The easiest way to tell is to look at it.
Patrikman is offline   Reply With Quote
Old 12-07-2015, 08:38 PM   #234
twilloo
Member#: 435665
Default headers
They will fit
twilloo is offline   Reply With Quote
Old 12-09-2015, 12:34 PM   #235
starr-backsport
Member#: 257651
2006 5mt BAJA-T
Black black baby
To be honest... I don't know how to tell the difference between them without actually looking down inside it. Do catless ones still have a temp sensor?
Old 12-09-2015, 02:25 PM   #236
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
Yes it will have the EGT air fuel ratio sensor. All baja turbo's have a catted up pipe.
illegal2.2 is offline   Reply With Quote
Old 12-09-2015, 08:54 PM   #237
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
They fit. Www.putphoto.com/sti2nr
Sent from my SM-N900P using NASIOC mobile app
2.5 turbo hyped is offline   Reply With Quote
Old 12-10-2015, 11:51 PM   #238
subie baja
Member#: 435929
Default 2006 baja turbo power steering
The shaft on my power steering pump squeaks and moves in and out. I called the dealer and they said that 2006 turbo models cant be rebuilt and a new pump is $500. Looking to take it out in a couple of days, is this year different or is it because it is turbo it cant be rebuilt? Help, lol
subie baja is offline   Reply With Quote
Old 12-13-2015, 03:24 PM   #239
starr-backsport
Member#: 257651
2006 5mt BAJA-T
Black black baby
illegal 2.2: thanks for the reply. I'll go take a closer look. My baja has an 07 wrx block in it so I'll just need to check to see if they kept the baja up pipe or not.
Sweeeet! Glad you are still on here sean. Miss your loveable jackassery on the facebook group.
Old 02-29-2016, 06:53 PM   #240
bdover9876
Member#: 302497
2005 Baja Turbo
Red Garnet Pearl
Originally Posted by drifterx View Post
*Cough* RIT dye works on our carpets,
Did you pull the carpet out to dye it? Also has it faded at all since you did it? I'd love to get more info on how you did it.
bdover9876 is offline   Reply With Quote
Old 03-09-2016, 12:08 PM   #241
meat_WRX
Member#: 96919
2004 sti
black
so what model/year fitment Downpipe are you guys running?
I keep seeing brands but no one says what it was intended for? ( i could have missed it) 02-07 wrx or 05-09LGT / 08-14 WRX?
Also, I dont see any, but who knows what FMIC piping is best routed to fit the Baja? I assume 05-09 LGT/08+ WRX, but its possible i assume wrong.
Thanks in advance!
meat_WRX is offline   Reply With Quote
Old 03-09-2016, 04:22 PM   #242
234herk
Member#: 392388
2005 Baja Turbo 5MT
TD05-18, DW850's
TurboXS Downpipe for 2002-2007 WRX/STi fits perfect. Model (WS02-DPC)
234herk is offline   Reply With Quote
Old 04-15-2016, 03:08 AM   #243
Patrikman
Member#: 234499
2004 Outbrat XT
Thanks in advance!
I have the Xceleration Baja specific dp.
Old 08-21-2016, 10:12 PM   #244
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
So I feel like I already found this answer before but now have come back across it trying to hook up my A/C finally. Using the Baja A/C line, it is way too tight I feel like and the threaded nipple with plastic cap hits into the STi TMIC.
I am not sure if this is an intake manifold difference(that seems to ring a bell) so the TMIC is pushed towards the firewall a bit more causing this problem. Or are there some Baja turbo owners with STi manifolds and TMICs that still work?
2.5 turbo hyped's engine bay looks like it has a diff A/C line on it that is up farther.
Maybe I'll try bending the intercooler brackets to get more room? If it should all fit no issues I'll see if that is the problem.
I'll try and snag a pic tomorrow.
Thanks
Ben
Old 09-29-2016, 06:51 PM   #245
korrec26
Member#: 455559
Default I have trouble with my 03 baja
Originally Posted by ascott13 View Post
it's a helix catless downpipe for an 02 - 07 WRX fitment. as far as i know, the only downpipes that are different are the new WRX's and the 05+ Legacy GT's since their turbo's are mounted a bit differently.
also, does anyone know if there is a basic stage 2 open source map for the baja around? i can find one for just about every other turbo subaru except the baja...
Need to reply to post my thread
korrec26 is offline   Reply With Quote
Old 10-07-2016, 01:48 PM   #246
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Subscribed.
ebo03 is offline   Reply With Quote
Old 11-27-2016, 09:46 AM   #247
Zadok
Member#: 38360
2006 Baja Turbo 5MT
Atlantic Blue Pearl
Does anyone know if the white line KTA124 rear link kit from the legacy will work. I have an 06 turbo 5mt and the rear link is frozen and I can't adjust the toe. I would just rather replace it with something stronger than the factory part.
Zadok is offline   Reply With Quote
Old 01-15-2017, 01:41 PM   #248
roorallday
Member#: 295051
Default What are those?
What size & manufac. Are those and you are running them with a custom set of bc racing coils? Please advise.....did they break the bank?
roorallday is offline   Reply With Quote
Old 01-15-2017, 01:53 PM   #249
roorallday
Member#: 295051
Default Hey 2.5 hyped turbo
WRONG!!! BCracing and I worked together to make a setup that increased the payload of the baja and rode smooth as glass on forest service roads at 80 mph.
Call up Import image racing and tell Josh you want the same setup Sean Fillner has on your baja.
The strut cartridges are 50mm longer so you can do a 2" lift rather than lower it and they use 14k swift springs on all 4 corners.
This setup makes the oem setup feel like jalopy garbage trash clown car suspension.
So did you have to get new axles. And this raised your baja 2"....is your baja an 05, would this work on a 06 do you know?
Old 02-16-2017, 02:14 PM   #250
Bill Irwin
Member#: 462923
Just bought my first Baja last week. 2005 Turbo Silver/Silver with 59,000 miles. Will be needing to replace tires soon, good to see one with raised white letter tires...
Bill Irwin is offline   Reply With Quote
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
