Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 05-05-2003, 12:48 AM   #1
Reset
Member#: 11118
2002 2.5 TS
Aspen white
Default Parts need to swap drum to disk on 2002 TS?
What is the Parts need to do drum to disk swap on 2002 TS
any 2002 TS owner have done this?
Reset is offline   Reply With Quote
Old 05-05-2003, 03:47 AM   #2
tora
Member#: 5851
17 Ford Escape SE
Blk
Reset, it may be different for the TS but should be the rotor, caliper, backing plate, mounting bracket, e-brake cable and possibly the hubs.
tora is offline   Reply With Quote
Old 05-05-2003, 08:00 AM   #3
codger
Member#: 13486
06 Legacy GT wagon
There are a few ins and outs to it. The ebrake is a pain to hook up, there is some uncertainty as to the setting on the proportioning valve, the holdback valve may present a minor problem, so in theory some issues about front rear bias.
Several people have done it with no major ill effect. If you do it put in SS lines at the same time, much easier then than later. A big advantage IMO is the ability to install SS lines and a bigger choice of grippier WRX pads all around, like Axxis Ultimate. So if you bother at all, go all the way.
Oh yeah, insurance can be an issue. If you have an accident, your insurance company can claim you were "tampering with your brakes", especially if brake failure (unlikely) is the cause. Best to get a licenced mechanic to do it anyhow.
Try searching this forum, keyword drum, any date, lots more info.
Jim
codger is offline   Reply With Quote
Old 05-07-2003, 01:25 AM   #4
Reset
Member#: 11118
2002 2.5 TS
Aspen white
I have got rotor, caliper, backing plate, mounting bracket, and hubs from a 2002 WRX.
I think I still need e-brake assembly, front knuckle,and rear drive shift.....not sure can someone confrim please?
Old 05-07-2003, 02:35 PM   #5
linsavy
Member#: 11620
1997 GF4-STiV3 clone
You certainly don't need a rear drive shift (whateverthatis)
No front knuckle need (we are talking about rear brakes right?)
You just need e-brake assembly and ebrake cable and some brake pads.
linsavy is offline   Reply With Quote
Old 05-08-2003, 01:58 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Although I doubt anyone has done it you should get the Proportioning valve from a vehicle that had discs to begin with. Its not as simple as just bolting the new one up, so everyone ignores it.
Not only are the drums activated BEFORE the fronts but the amount of fluid sent to them is minimal. No one wants to look into it but Im fairly certain many who have performed this swap essentially disabled the rear brakes after the swap.
ciper is offline   Reply With Quote
Old 05-08-2003, 04:22 AM   #7
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
This is a very valid point, the rear discs are no good if the calipers never have enough fluid in them to clamp down.
US2JDM is offline   Reply With Quote
Old 05-08-2003, 06:41 AM   #8
codger
Member#: 13486
06 Legacy GT wagon
Ciper, I think we went over this before on this thread
Several people who have actually DONE this swap pointed out the immediate benefits they felt, in contradiction to the theory you are putting forward. I've also chatted with 4 or 5 other people who have done it, and none of them experienced the problems you continue to speculate about.
If you can show me that the split point and reducing ratio are different in the TS/OBS vs the WRX, and show me proof of the existence of a holdback valve in the TS/OBS (photo, part #), then you have something new to offer
Jim
Old 05-08-2003, 02:45 PM   #9
schnell
Member#: 14362
2002 TS Wagon
Midnight Black Pearl
I saw some posts on another board (will look for them) where the poster had checked part numbers and the proportioning valve was the same between drum/disc models. In fact I remember the post going on to say that the mechaninsm in the drum does the proportioning / fluid quantity job, thereby allowing the manufacturer to keep more parts consistent.
I too have spoken with a rally team mechanic who had a customer do the same swap in a '02 OBS. This customer did ice racing and commented on the better brake modulation with the discs.
But all the info in this thread is second hand or speculation. That being said, I plan on doing the swap in my TS.
Jason
schnell is offline   Reply With Quote
Old 05-08-2003, 11:29 PM   #10
codger
Member#: 13486
06 Legacy GT wagon
Ok, I found a link with part numbers: link
Looks to me like the main parts that are for WRX only are the vacuum booster assembly, the vacuum hose and the clip for the hose. The master cylinder assembly is the same part number for WRX or OBS: 26401.
Also, if you look around on the site to the diagrams of the various braking systems, there is no holdback valve evident.
Jim
Old 05-09-2003, 06:34 AM   #11
codger
Member#: 13486
06 Legacy GT wagon
Here's a link to another good thread on this topic. Toward the bottom of the first page, legacy777 posted a scan from the service manual. It summarizes the various Impreza braking systems; it shows various models having drums vs discs, or different size rear discs. However all models appear to share the same Brake Booster, MC, and Proportioning Valve, with the same split point of 285 psi and reducing ratio of 0.3. So more evidence that perhaps the New Age TS and OBS already have the correct MC for the swap. As I mentioned in an earlier thread, Subaru may find it simpler and cheaper to use one set of parts across all models, and adjust for bias by just sizeing the drum piston accordingly. This way we would get the same amount and pressure of fluid going to the rear brakes, and get the same or similar amount of ultimate rear brake torque.
Jim
Old 05-09-2003, 02:43 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
I dont mind to be wrong, now we have some good data on the subject. Personally I rarely trust when people say "I did it and it feels great."
Now with the additional information that the associated hardware is the same with the Disc and Drum equiped vehicles Im satisfied.
Realize none of my Subaru have drums, so my intent wasnt for my own benefit.
Old 05-10-2003, 08:30 AM   #13
codger
Member#: 13486
06 Legacy GT wagon
Ciper,
You certainly raised a valid line of enquiry. While I believe there are no issues within 2002 and 2003 swaps, at the moment there is no such tangible evidence for New Age/Old School swaps. We could test this in a number of ways though:
- are people who have done the swap wearing out and replacing rear brake pads at a typical pace?
- after pulling the ABS fuse, try several panic stops, past an outside observer. Look for abnormal front or rear lockup. Ideally compare between stock four wheel disc, stock drum/disc, upgraded 4 wheel disc. Might want to try this on gravel to avoid flat spotting, or use some tires you really hate
Jim
Old 05-10-2003, 10:13 AM   #14
spt_impreza
Member#: 3004
JIm,
great information......if you get anymore links etc please send them my way as I may not catch them.....
BTW- with that info my brake sway is looking better and better everyday.......
spt
spt_impreza is offline   Reply With Quote
Old 05-10-2003, 12:04 PM   #15
codger
Member#: 13486
06 Legacy GT wagon
Me too. Those WRX rear brakes in my garage have been gathering dust for way too long. As soon as my SS lines come in, it's goodbye drums.
Jim
Old 05-10-2003, 12:12 PM   #16
spt_impreza
Member#: 3004
Jim
ya me too kinda...I will be ordering my SS lines next monday and than I should have both by that weekend and then its just installing them
spt
Old 05-11-2003, 12:49 AM   #17
Reset
Member#: 11118
2002 2.5 TS
Aspen white
Jim
I not sure about '02 OBS
But my '02 TS need some more parts other then WRX rear brakes to do the swap.
the shop tell me I need the whole e-brakes kit for WRX disk, and some parts supposs to go though the backing plate is too big
Old 05-11-2003, 05:45 AM   #18
codger
Member#: 13486
06 Legacy GT wagon
But my '02 TS need some more parts other then WRX rear brakes to do the swap....
Yes you do need more parts. I made sure to get the whole shebang from a WRX: everything past the axle, including the e-brake cable.
Jim
How long should rear drum pads last on a TS? poison Brakes, Steering & Suspension 11 06-20-2008 01:31 PM
Swap Drums for Disks hhedberg Subaru Conversions 5 06-18-2006 06:25 PM
Need to replace front rotors/pads on 2002 OBS - Need Advice! mekkon Brakes, Steering & Suspension 6 04-24-2006 06:16 PM
Want to do FWD to AWD? Drum to Disk? I have the parts keirnna Private 'For Sale' Classifieds 7 08-16-2005 04:39 PM
Roof rails on 2002 TS Kal Service & Maintenance 0 11-20-2001 04:10 PM
