Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 10-28-2009, 01:54 AM   #1
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
Default 09 WRX Motor in an 02 WRX
Hey all,
I recently had a complete 09 WRX Long block (EJ25) land in my lap for pretty cheap, and I am wondering if this will be an easy swap into my 02 WRX (replacing an EJ20). Primary concerns are the wiring harness, Tranny, intake manifold, etc...
If there is already a thread for this, please let me know, as I am fairly inexperienced when it comes to complete motor swaps... I am simply looking for the information on doing the swap. The actual swap will be done at a performance shop who will be doing the build for me. I am simply looking to find out what parts will be needed for the build, as I dont want to waste time at the shop and/or waste the time of the shop
Any information at all is a help! Thanks!
Nitrousspeed is offline   Reply With Quote
Old 10-28-2009, 03:13 AM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Your ECU won't run it, the dissplacement is too different.
Everything else is fine as long as you don't abuse it.
Come to think of it, the wiring is probably different, the years are soo far apart, post in the 2.0L sub-forum, maybe you'll have some luck there.
On a side note if you use the shortblock and your heads, it will work, but it will run like ****.
Why would you want to do such a thing. Sell the later model engine, get an older model engine, and..............................done.
DHRDAN is offline   Reply With Quote
Old 10-28-2009, 05:18 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
if you use the block the ecu doesn't care about displacement.
done about a dozen 2.0/2.5 combos. they are all running fine.
you will need 2.5 head gaskets.
Old 10-28-2009, 09:55 AM   #4
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
Its a complete long block with the heads. I just want to make sure that they are compatible, and find out what parts I will need...
Old 10-28-2009, 10:03 AM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
You won't get to use the avcs if you plan on using the stock 2.0 ecu.
If you do plan on using the 09 ecu, you will need the harness and pedals (for dbw).
Or go standalone and you can use the dbc on it.
Nuke209 is offline   Reply With Quote
Old 10-28-2009, 10:39 AM   #6
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
Seriously, guy.
If you were being honest when you say that you are inexperienced in motor swaps, you really shouldn't be searching the boards. It will give you just enough information to make you dangerous, but not enough to do the swap.
The mechanical and electrical expertise need to pull this off would be nothing short of a custom shop. Rather than surf the boards for fitment answers you need to seek out a shop that has done this before and meet face to face.
At the rate this is going you will have spent thousands of dollars and will most likely have an iffy engine that won't run right. Trust me, take it to a shop and have it done right.
TEK112 is offline   Reply With Quote
Old 10-28-2009, 10:48 AM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Wow this thread fails in so many ways. People, if you don't have a clue don't post. The 09 longlock will bolt right into your 02. If you want working avcs you will need an ecu and harness that will control it.
Old 10-28-2009, 11:02 AM   #8
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
Originally Posted by TEK112 View Post
Seriously, guy.
Im not doing the physical swap, Im having Forged Perfromance, the new home of Scott Siegle do the swap for me. But so I dont waste the time of the people in the shop and have my car sitting in the shop for too long waiting to order other parts, I want to make sure that I have all the nesessary parts for direct bolt up. Its not a matter of me being a master mechanic to do the swap, I am searching the boards to make sure that they have everything they need! And regaurdless of whether or not I have that expertiese, maybe some people are trying to learn... Besides the point, this way Im NOT spending thousands of dollars on this project... Im just trying to get educated on what is needed!
Old 10-28-2009, 11:04 AM   #9
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
[quote]Wow this thread fails in so many ways. People, if you don't have a clue don't post. The 09 longlock will bolt right into your 02. If you want working avcs you will need an ecu and harness that will control it...[quote]
Thank you... I am keeping the drive by cable, I prefer the direct connection to my foot... So with that said, I shoudl be able to keep my stock ECU and they can protune the car with the new block?
Old 10-28-2009, 11:08 AM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by Nitrousspeed View Post
And as for you, if you dont have anything with some proper input, the stay the **** off my thread... Forums are here for the spreading of knowledge and helping other people out. If you dont feel like doing so, then you should not post... I appreciate your final words about the bolt up, but no need to be an ass about it!
Calm down big guy, people in your thread are giving you bad advice, that's who my comments are directed at, not you.
Old 10-28-2009, 11:11 AM   #11
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
Yeah, as soon as I wrote that, I realized where that was directed and edited my comment. Sorry about that...
Old 10-28-2009, 11:28 AM   #12
TEK112
Member#: 218140
You flew off the handle way too easy. Take a deep breath.
In your first post you were asking for "an easy swap." Plus, didn't mention you had a shop involved.
My answer was to help you. You didn't give enough information when you posted the first time. If you don't appreciate the kind advice, don't blow up on people, just ignore it and move on.
You recognized yourself that you need a shop involved. You are doing research and that's great. It's a good thing to educate yourself, but seriously. Go back and read your first post. How do you think it sounds? It's sounds like half of them where someone jumps in without help and there are too many posts where some goes "I did this and now nothing works."
My post was intended to save you the hassle if you have never done this before.
Old 10-28-2009, 11:32 AM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
If that's the case, then just drop the block in. You just wont be able to run the avcs, that is all.
Old 10-28-2009, 11:36 AM   #14
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
Ah, I see where you ya got that... no no. Ok, yeah, I needed to clarify... Thats what I get for posting at 2 AM... So lets start this over again...!
Old 10-28-2009, 11:44 AM   #15
TEK112
Member#: 218140
No problem buddy...
Old 10-28-2009, 03:49 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
making this work well....ya gotta get the AVCS to work so ya gonna need to get an 09 ecu to work or I'd get some sort of stand alone EM that will control the avcs
Old 10-28-2009, 04:13 PM   #17
Nitrousspeed
Member#: 183192
2013 STI
World Rally Blue
Why do I have to have AVCS? (Again, Im not 100% knowledgeable on this... )
Old 10-28-2009, 04:21 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
You don't have to have the AVCS working. You won't have variable cam timing if you don't. If you do get it working, it'll run a little nicer at lower speeds and spool the turbo a bit faster.
wrx motor in an 89 gl wagon rusty89wagon Subaru Conversions 5 11-12-2006 04:26 PM
05 WRX tranny in an 02 WRX, need some advice GottaREX Transmission (AT/MT) & Driveline 3 10-16-2006 08:51 AM
04 STi motor into an 02 wrx Smoby Service & Maintenance 1 08-28-2006 10:35 PM
Who has blown their motor or built a motor in their 02 + wrx STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-20-2002 10:05 AM
Anyone think about a US spec WRX motor in an RS? RacerinLSL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-27-2001 08:48 AM
