03-28-2001, 02:11 PM | #1 |
Member#: 3774
Vehicle:04 STi Silver |
Best way to make tranny last ?
I have a 2000 RS turbo'd and im starting to get a little worried about my tranny going in the future. What is the best way to prevent this from happening other than babying the car? And what are the options for new tranny or strengthening it. I will be running about 7psi.
thanks
03-28-2001, 02:17 PM | #2 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
Never, ever speed shift. Especially not the 1-2 shift.
Double-clutch it. |
03-28-2001, 02:56 PM | #3 |
Member#: 4106
what's mentioned above + redline shockproof oil. it looks like banana milk and i've used it on several cars and it actually has fixed some existing problems !
zaidoun |
03-28-2001, 03:06 PM | #4 |
Member#: 3389
Vehicle:07 STImpreza Satin |
Drive like Miss Daisey is in the back seat.
Ken |
03-28-2001, 03:06 PM | #5 |
Member#: 80
If you fully intend not to baby the car, I don't really see what can help you.
Even professional racers have to take care of their machinery. Otherwise it may not last long enough to take them across the finish line at all, much less finish first. It's not like they're all using transmissions which are simply incapable of breaking either. Don't slam into 2nd gear. If you have an electronic boost controller, adjust it to ramp up boost gradually from 3000-5500 rpm (period of max torque in your powerband). Above all, *do* baby the transmission. Better safe than sorry. -Edwin |
03-28-2001, 04:58 PM | #6 |
Member#: 72
Vehicle:2008 BMW Z4M Coupe White |
Colin - when is it best to double clutch - only when you're driving hard or all the time?
I'd never heard of double clutching until today. I started practicing at lunch dropping down from 4th to 3rd to 2nd, takes some getting used to. - Richard. |
03-28-2001, 07:48 PM | #7 |
Member#: 420
SCIC
Vehicle:2001 Cr-V Silver |
All the time. Sometimes, if I'm impatient I'll 1-2 with a single clutch release - but I double-dip .90 of the time. I have 43k on the original clutch, too.
03-28-2001, 10:56 PM | #8 |
Member#: 2916
SCIC
Vehicle:02 duburu arr exu |
slip it in neutral, get behind the car, and start pushing your way to work
03-28-2001, 11:05 PM | #9 |
Member#: 4124
Vehicle:1999 Impreza 2.5rs Rally Pearl Blue |
Drive that car like a bat out of hell! then when everything goes to ***** bitch to comstumer service and have them pay for parts! if you creative enough they will trust me!
03-29-2001, 10:12 AM | #10 |
Member#: 4728
Vehicle:2002 WRX Silver |
Don't Drive it EVER!!
What is the best way to make a cast in order to make a fiberglass mould? | BrysImpreza | Interior & Exterior Modification | 1 | 02-20-2006 10:21 AM |
Whats the best way to make my 2002 have 300hp? | 2002bugeye | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 11-04-2005 07:46 PM |
What is the best way to lost the last of the gut | koolaid | Off-Topic | 16 | 11-23-2003 01:08 PM |
Best way to drain tranny fluid? Level or raised? | Cjchaps | Transmission (AT/MT) & Driveline | 2 | 03-16-2002 01:33 PM |
Best way to make WRX brakes stiffer? | jamz | Brakes, Steering & Suspension | 4 | 10-28-2001 08:52 AM |
