04-08-2013, 12:49 PM | #1 |
Member#: 276443
TXIC
Vehicle:2005 2.1 stroker WRX OBP |
Idle issues
Ok so sometimes ONLY at idle i have the following problems.
1. One time only this happened. The car was a warm start and idle had dropped low to 500 then as it raised the boost gauge raised up to 1psi ish and then the car rev'd to 3k and then settled back down to normal idle of 1k rpms. 2. The cars idle ONLY at idle will sometimes jump a few 100rpms and hang there a bit and then drop back down. Usually once the car is fully warmed up it will do this. This is not constant but does happen daily. Iacv has been removed and cleaned with new oring installed. MAF has been removed and cleaned. Front O2 sensor has been replaced and Afs all read normal. An ecu reset has been done at every part cleaning or replacement. For those that do not know i have a built 2.1 stroker. Any info would be appreciated. |
04-08-2013, 01:55 PM | #2 |
Member#: 271518
Vehicle:2008 Spec b Diamond grey metallic |
Do you have a short ram or cold air intake? My wrx would do that on windy days only at idol.
04-08-2013, 02:01 PM | #3 |
Member#: 276443
TXIC
Cai.
If all parts list is needed i will post. Its long |
04-08-2013, 03:24 PM | #4 |
Member#: 160040
AKIC
Vehicle:2002 Bugi / 1993 L Symmetry Tuning |
its probably gonna blow soon.... sounds like bad rings, the engine is trying to keep compression, what was the break in procedure?
04-08-2013, 03:25 PM | #5 |
Member#: 276443
TXIC
Well doesnt that sound horrible. 7k on a built motor? And gonna blow?
Im gonna start with a Vacuum leak test |
04-08-2013, 03:30 PM | #6 |
Member#: 160040
AKIC
i think you worry to much, your on a custom built engine and worrying about a a 100 rpm bouncing idle, what injectors are you using, how old is the O2 sensor, boost leak also could cause it. the 79mm stroke in your engine is choppy anyway, are you cammed? what is the idle set to?
04-08-2013, 03:27 PM | #7 |
Member#: 276443
TXIC
Pretty sure it was started until normal op temp then killed and oil change.
I beleive was a hard break in. If its gonna blow up it would have then. Element ak would have exact details. |
04-08-2013, 03:33 PM | #8 |
Member#: 276443
TXIC
Idle set at 1k rpms. It can jump up to 400rpms and remained there a while and come back down.
750cc dw injectors. Brand new o2 sensor as of last monday. No cams. Stock heads |
04-08-2013, 03:39 PM | #9 |
Member#: 160040
AKIC
injectors may be culprit, DW aren't known for having the best idle properties when they get large. invest in some ID's maybe, also look at the tune, check on AC idle and fan switches ect. And check on the first response also, especially in fairbanks, try getting rid of the CAI and get a short ram, did you change the tube the MAF sits in after the tune??
04-08-2013, 03:38 PM | #10 |
Member#: 276443
TXIC
Boost leak should cause a lean or rich reading which i have not seen.
04-08-2013, 03:40 PM | #11 |
Member#: 160040
AKIC
04-08-2013, 03:42 PM | #12 |
Member#: 160040
AKIC
where did you get the new O2 sensor, i wouldn't recommend any of the cheap rockauto sensors online, you get what you pay for..
04-08-2013, 03:44 PM | #13 |
Member#: 276443
TXIC
Denso sensor. Stock replacement. I use opensource.
No tune afecting parts have been changed since the motor was built. |
04-08-2013, 03:47 PM | #14 |
Member#: 160040
AKIC
k well id look for leak even if the afr is right on and consider a short ram as opposed to cold air and look into changing the injectors
and look at the tune |
04-08-2013, 04:00 PM | #15 |
Member#: 117985
Who tuned your car?
04-08-2013, 11:26 PM | #16 |
Member#: 276443
TXIC
Paul element ak.
Gonna start with a heavier spring for the bov. May be opening early. |
04-09-2013, 02:35 AM | #17 |
Member#: 282043
Vehicle:04 STI WRB |
Post a short video for us if you can. I had a similar problem and after 3 different tunes. Problem solved.
