Welcome to the North American Subaru Impreza Owners Club Wednesday March 26, 2025
Old 05-25-2024, 01:53 PM   #1
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
Default Bad clutch slip?
New problem: Had the car at the dealer for some other maintenance work. The test drive by the tech noticed "really bad" clutch slip. The whole assembly has about 50k on it with 300whp from last year's bolt-ons and tune. It kind of answered why it felt like lately the car was falling flat at highway acceleration (namely in 3rd and 4th gear) with an rpm jump initially, and then would feel like it would stagnate, despite still gaining speed. Is this common? And if I now need a new clutch ***128548;, what have folks gone with for aftermarket?
striktlysubie is offline   Reply With Quote
Old 06-01-2024, 10:12 AM   #2
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
No suggestions?
Old 06-01-2024, 03:52 PM   #3
stoich68912
Member#: 350291
If RPMs increase disproportionately from speed most likely clutch is slipping and needs replaced. It's a wear-n-tear item, so yeah pretty common to need replacement at some point. Just depends on how its driven and if its spec'd for the appropriate power output.
My 07 sti was on the stock clutch for about 120K, most of that on 93oct tune and bolt ons. Went flex fuel and the clutch went south quick on high E fuel. Replaced with ACT HDSS w/ resurfaced FW. Happy and holds great.
stoich68912 is offline   Reply With Quote
Old 06-07-2024, 08:35 PM   #4
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
^ Thanks for that feedback.
Old 11-27-2024, 09:12 PM   #5
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
The car is now in the shop to get the ACT HD clutch kit put in, as well as a slew of other work done to it. Fingers crossed....
Old 11-27-2024, 11:50 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
For the future, my usual clutch test is:
3rd gear, up at least a slight grade, RPM's 3000RPM or so, mash the gas.
If the tach jumps up but little or no real speed change, the clutch is slipping. You may also smell "hot brake" smell which is the clutch.
The gear reduces mechanical advantage.
The RPM's gets you near max torque.
The hill makes it work harder.
Old 11-30-2024, 08:01 PM   #7
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
Indeed, thanks. My burnt clutch smell was heavy.
Old 01-01-2025, 06:06 PM   #8
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
The car has the new ACT HD clutch with oem TOB and oem fork, so this issue seems resolved now. Other issues, not so much.
