Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 02-23-2018, 08:43 PM   #1
TurboQueef
Member#: 86700
2005 STI
FP Red:[email protected]
Default Innovate MTX-L Plus eating sensors
Good day, I installed a MTX-L Plus in late July.... in my winter vehicle... car was in storage until late October.. I have 5K miles on it sense installing the MTX and have gone through two sensors.
The MTX-L is installed in my 04 Forester XT (4EAT), I am running 14.7 AFR in normal cruise and 12/1 WOT with Meth/water 50/50. The sensors read fine for couple thousand miles and then it acts up... It goes into CAL mode when engine is running then offers E8 error code.
Anyone else having issues with this model ?
BTW.. I have one of the first wideband units (LM1) in my STi and it never has issues like this.. The sensors last several years unless I run leaded fuel through them...
Tnx.
Jeff
TurboQueef is offline   Reply With Quote
Old 02-24-2018, 09:12 AM   #2
point78
Member#: 344329
2008 Wrx, 6mt
Mines been fine for couple years.
50/50 meth summer, 75/25 winter. 25psi pump91
point78 is offline   Reply With Quote
Old 02-26-2018, 11:10 AM   #3
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Yes. I have an MTX-L. And am now going to have to get my 3rd sensor. I have read about other people having issues with them as well.
I had a bosch 4.2 that originally came with it die. It started reading erratically around stoich but was OK when lean or rich. I dont think it ever 'died' though.
I upgraded to a 4.9 and it died recently. It started with a little bit of fluctuation then reading a little lean all the time before reading E8. now its totally borked and reads E2 all the time.
The 4.9 started dying after I cleaned some salt out of my engine bay. I have a suspicion that moisture or soap might have gotten in it, however I never sprayed the sensor itself.
If I had to do it all over Id get an AEM, because on top of it all wtf is the harness hard wired to the gauge???
86Dreams is offline   Reply With Quote
Old 02-26-2018, 12:18 PM   #4
TurboQueef
Member#: 86700
2005 STI
Hummm, not good. I am trying to work with innovate to understand the problem. I have an old LM1 on my STi and have had no issues. Considering you tried different model sensors, I am suspecting something in the gage is off
Old 02-26-2018, 06:22 PM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
LSU 4.2 or 4.9 sensor? Mounting location/orientation?
Innovate updated the firmware in the controller for 4.9 sensor a while back.
Interesting read: http://www.nzefi.com/bosch-lsu-wide-...-applications/
Airboy is offline   Reply With Quote
Old 02-27-2018, 02:07 AM   #6
subaru_gc8
Member#: 29292
2004 WRX wagon
Tnx.
Jeff
Ive heard of the innovate 1 gen stuff needing lots of calibration, but yeah I have a lc2 on my toyota and had to go through the calibration process like a few times to get it right
although on my subaru I have a plx and that thing has run without problems for the last 3 years
Old 02-27-2018, 06:13 AM   #7
TurboQueef
Member#: 86700
2005 STI
Good info, thanks...
4.9 sensor located in the top of the downpipe maybe 6 inches back from the turbo exhaust housing.
Through discussion with Innovate the thought is perhaps the sensor is too close to the Turbo and it is taking too much heat. This is in conflict with the interesting read you linked up (unless the exhaust temp is over 1796F that is).
I am considering moving the sensor down the pipe a foot or so and using the heat sink I got with my LM1 (which has never failed a sensor unless I ran leaded fuel).
Another point Innovate made is if the power wire used from the switched 12V power source is not capable of handling 2 amps (this is the sensor heater demand) then the sensor can fail over time. Mine is using 12G wire so this is not the case for me.
Old 02-28-2018, 03:56 AM   #8
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
I have read that before, the O2 sensor should be at least 18 inches from the turbo outlet, even though all the downpipes have the sensor fitting right in the bellmouth, and that is where mine is at. They do sell O2 sensor spacers/coolers designed to keep a wbo2 sensor from burning out but they are around $60.
bobjr94 is offline   Reply With Quote
Old 08-04-2018, 12:04 AM   #9
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I run my sensor at the end of the downpipe, still hot enough and any sound/oscillation from the turbine blades will be a little weaker with the sensor further back. Many dyno tuners clip their sensor into the end of the tailpipe and it works perfectly fine. I don't see being further back causing an issue, especially if your exhaust has no leaks.
Old 08-04-2018, 07:58 AM   #10
TurboQueef
Member#: 86700
2005 STI
I had sensor mounted in the rear O2 bung, fried there too... Innovate sent me a new gauge, sensor and heat sink a couple weeks ago.. They suggested I mount it back at top of downpipe using the heat sink.. so far so good.
