04-02-2017, 04:17 PM | #776 |
Member#: 462676
Hey guys, new to the forum. I have a 94 Impreza L 1.8, and I'm looking to convert it from NA to Turbo. Anyone have any suggestions? It only have 87k miles on it so I want to upgrade it and play with it
04-22-2017, 11:28 PM | #777 |
Member#: 466480
Best info on turbos I have seen so far. Thanks
05-25-2017, 11:45 PM | #778 |
Member#: 468254
Thanks for this post. I'm currently in the decision making process for Turbos and this list is going to help be greatly! Thanks again.
--Steve |
05-25-2017, 11:57 PM | #779 |
Member#: 457410
International
Vehicle:1991 Legacy RS RA White |
Get a TD04. You don't want much boost on a N/A as compression will be higher, run wastegate pressure and enjoy till it goes pop
05-29-2017, 05:36 PM | #780 | |
Member#: 468462
10-07-2017, 02:55 PM | #781 |
Member#: 475736
Thank you so much! I’ve been looking for this for forever
10-07-2017, 07:02 PM | #782 |
Member#: 144241
+ 1 for borg warner!
11-14-2017, 06:52 PM | #783 |
Member#: 477719
Vehicle:2013 Sti Black |
Big help, thank you guys !
12-20-2017, 11:26 AM | #784 |
Member#: 479468
Vehicle:2005 WRX STI blue, black |
Extremely useful thread! I wish I had this information when I was shopping around earlier this year. I decided on the Blouch TD06H-20G knowing pretty little about my car, but ended up with good results! The spool time is lengthier than the previous ebay nameless turbo (which was expected) but I've been loving it, and still have room for better performance with a couple better mods!
12-27-2017, 01:09 PM | #785 |
Member#: 479495
Need some help with my turbo
Hey, first post, so if anyone can help, it would be appreciated. I have an 02 WRX with an upgraded/replaced turbo that has some pretty serious lag, it really starts coming on at about 4000-4500 RPM, and I want to see what I can do to get that down to something more streetable. Bought it with quite a few upgrades including fuel pump, injectors, intercooler, 4 inch downpipe, 3 inch exhaust, etc. Supposedly has 18 psi boost, but boost gauge is in atmospheres instead of psi, turbo was supposedly ceramic coated, but have not pulled it off to verify. Turbo is an ihi turbo but I can't find the manufacturing numbers, exhaust housing numbers are R5 E1 17 3CG. Not sure what those mean, and I have spent the last 3 hours looking at forums and wbsites trying to figure it out. Any help or direction would really be appreciated, thanks!
02-15-2018, 05:26 PM | #786 |
Member#: 482163
great info!
03-12-2018, 06:23 AM | #787 |
Member#: 483250
i love subarus
03-12-2018, 01:06 PM | #788 | |
Member#: 476023
Vehicle:2004 Impreza WRX 1997 Legacy Outback |
Do you have a front mount intercooler? If so, taking that off and putting back the top mount should alleviate some lag. |
03-12-2018, 01:07 PM | #789 |
Member#: 476023
Has anyone messed with a VF38 twin scroll before? Can hardly find info.
03-12-2018, 01:28 PM | #790 |
Member#: 385256
NESIC
Vehicle:'18 Giulia QV '21 Giulia Q4 |
03-12-2018, 02:07 PM | #791 |
Member#: 476023
Has anyone made a hybrid build on one or just trash them and move on to get a VF37 or 36? I came across one for 100$ and I couldn't pass it up. For my 04 WRX the compressor housing from the 38 isn't going to work and I don't really want to swap a VF43 compressor housing on there because the compressor wheel will be to small to fill the void. I've been looking at VF54 billet wheels and that would fill the void but I feel like the turbine shaft will be to short for the wheel to mount. Just seeing if any one has made a hybrid 38 really and what they did and what was pushed out of it.
04-14-2018, 10:14 AM | #792 |
Member#: 484631
Help needed in the north east uk..!!!
Hi to my fellow subaru owners far and wide..!!
I’ve a problem and after much searching in the uk fear I’ll have to cast my net further to solve it..!! I’ve a reasonably good condition 18 year old Forester , rebuilt and modified to an approx safe 350 bhp BUT my VF23 turbo has just expired so it now sounds like 2lb of nails in a tumble dryer..!! As the car is mapped to run that turbo it makes sense to replace it like for like but there doesn’t seem to be any in the uk.!! So chaps am casting my net over the pond to see if any of you guys have one out back sat doing nothing that you’d sell me..?? obviously needs to be in good working order and good for another 30/40 k miles.. If I’m in the wrong place please redirect me.!! Many thanks |
04-14-2018, 09:47 PM | #793 |
Member#: 165695
There must be more than a few shops around you that can rebuild this thing, so why not go that direction instead? It'll save you a lot of time and headache down the road with warranteed work instead of buying at best a second hand unit that may possibly put you in the same predicament or worse.
04-15-2018, 07:47 AM | #794 |
Member#: 484631
Hi mate.. thanks for input but blades scored the intake chamber.. doubt it would refurb tbh... I’ll keep searching otherwise I’ll change and remap.. again..!!
That model offered particularly good low down pull and progressive power thro the range..didn’t run out of steam pulled happily off the clicks.. |
04-15-2018, 10:22 AM | #795 |
Member#: 86389
Vehicle:2011 WRX Hatch WRB |
I feel like your best bet would be a post in the Classifieds section of the forums.. post up a WTB (Want To Buy) and see if anyone has one for ya.
04-19-2018, 11:29 AM | #796 |
Member#: 484874
Vehicle:2006 Subaru STi WRB / Gold |
Awesome info, thanks.
05-02-2018, 02:46 AM | #797 |
Member#: 132389
BAIC
Wrong thread. Sorry guys.
Last edited by neg_matnik; 05-02-2018 at 05:51 PM. Reason: Posted in the wrong thread |
05-02-2018, 04:52 PM | #798 | |
Member#: 457410
International
https://www.trademe.co.nz/motors/car...79fc00cced12b3 Works out to be 170 pounds, but shipping might make it expensive |
05-12-2018, 07:05 AM | #799 |
Member#: 484672
great info, it deffinately helped me out. You could try this https://carcbradios.com/
05-12-2018, 11:49 AM | #800 |
Member#: 485880
Vehicle:04 Forester XT Silver |
newbie who needs help
First off let me say that this is a great thread with lots of good information and I appreciate the time it took to put together to help us all out.
About me. I am a total newbie who just got his first Subaru. I have a 2004 forester xt with a blown wrx turbo in it and I am looking for a replacement turbo. the car is stock for now so there is no mods or tuning done. My goal is to drive it this year as a daily driver and work out any/all kinks I find with it. once I have it running well and the suspension and brakes are setup I will being engine mods. The goal for this car is to be a fun car for the weekends with the family and camping and biking trips or car show/club meets. My question is what is a good stock wrx turbo that I can put in to replace the current one? and where can I get a good deal on a new one? thanks for all the help in advance. |
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever | pepperjack | News & Rumors | 74 | 07-14-2015 07:07 AM |
is there a Subaru turbo list? | housedj | General Community | 8 | 03-18-2009 12:48 PM |
subaru forum list | 949 | General Community | 10 | 11-01-2005 11:32 PM |
Subaru wish list | carrera | News & Rumors | 9 | 06-19-2002 08:45 PM |
('93-'01) Subaru Mailing List | rubadub | Impreza Forum | 3 | 08-18-2001 02:40 PM |
