Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 01-30-2007, 12:26 AM   #1
Digitalfiend
Member#: 54823
2008 STI
Default One-step colder plugs
I'm thinking about replacing my spark plugs before my HPDE/lapping season begins in May and, now that I've gone AP stage 1, I was wondering if I should consider the NGK one-step colder plugs.
Here is my problem though: I've read so many differing views on whether one-step colder plugs are worth it or even make an appreciable difference on a near stock car. From what I've read with one-step colder plugs, they can help with detonation when running the car at higher stress levels (like road racing.)
Most people I've talked to say that the NGK one-step colder plugs would be OK and somewhat beneficial for a stage 1/2 car. Unfortunately, to confuse matters for me, a tuner commented that he has had nothing but problems with iridium plugs on modified cars; specifically poor running, misfires, etc. Firstly, I find this a bit strange, since the STi comes with iridium plugs. Secondly, he mentioned that he's personally seen copper plugs produce more power.
The one clear point he did make (and I somewhat understood) is that the NGK plugs are gapped to .030, while the stock plugs are gapped to .028 (or .026.) Will this be something that I need to be concerned about? Can anyone help clear things up for me?
Thank you in advance.
Edit: I'm in the process of reading through the FAQ and links to STi related info.
Digitalfiend is offline   Reply With Quote
Old 01-30-2007, 04:58 AM   #2
Engmus
Member#: 115645
I've been running the Denso Iridium one step colders for forever now. No problems, no CELs, no Misfires. Just a steady, clean idle. check the gap and you will be fine.
Engmus is offline   Reply With Quote
Old 01-30-2007, 03:08 PM   #3
Digitalfiend
Member#: 54823
2008 STI
Thank you for the reply.
Old 01-30-2007, 08:26 PM   #4
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
Yep same here. denso iridium one step colder. i have a stage 4 wrx. i have had no problems.
Rexwagon03 is offline   Reply With Quote
Old 01-31-2007, 12:59 PM   #5
Snitt
Member#: 36361
1980 Yugo
Definitely not a Golf R
I have run NGK platinum one step colder plugs for about 30K miles now with no issues. They have survived the cold Ohio winter and hot Ohio summer.
Snitt is offline   Reply With Quote
One step colder plugs worth it? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-26-2018 12:03 PM
NESIC opinion needed: One Step Colder Plugs in vf34 set-up? The Modaholic New England Impreza Club Forum -- NESIC 13 04-05-2005 02:33 AM
Purpose of one step colder plugs? sneeky Service & Maintenance 16 01-14-2005 05:15 PM
One step colder plugs? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-01-2004 05:08 PM
One step colder plugs? What gap? munkis Normally Aspirated with bolt-on Forced Induction Powertrain 18 06-12-2004 08:48 PM
