Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 04-24-2003, 08:37 PM   #1
philip_g
Member#: 32906
Default ECU neutral switch wire is triggering my alarm
my alarm keeps going off for no reason, the code each time is the hood pin- which runs to the ECU wire.
any ideas? I'm thinking it's possibly a bad diode, when I check continuity one direction I get nothing, then gong the right direction I get kind of a broken connection, not sure if this is normal or not. Maybe I need a bigger diode
philip_g is offline   Reply With Quote
Old 04-24-2003, 09:38 PM   #2
netZ
Member#: 5743
2007 Kia Optima
gold brick
Default Re: ECU neutral switch wire is triggering my alarm
sup,
couple of things to check:
1) check your hoodpin is it rusted or maybe it's not working properly when the hood is closed, try disconnecting your hoodpin temporarily and see if the ecu is triggering your alarm
2) check your neutral wire connection to be sure it's not touching ground
3) are you leaving your vehicle in gear when you arm the alarm?
netZ
netZ is offline   Reply With Quote
Old 04-24-2003, 11:14 PM   #3
philip_g
Member#: 32906
No hoodpin, too lazy
Yes, it's in gear sometimes when I arm it, I can't leave it in N all the time. When I arm the alarm it should bypass that input if it's grounded, it should only go off if the situation changes right? so maybe that points to a bum diode?
no way for it to be grounding elsewhere. I checked again tonight to be sure
Old 04-25-2003, 08:43 PM   #4
philip_g
Member#: 32906
maybe I'll just ground it to the chassis for testing to see what's up
Old 04-26-2003, 01:06 AM   #5
netZ
Member#: 5743
2007 Kia Optima
gold brick
ground the hood pin cable? then your remote start won't work.
try replacing your diode and see if the diode is the culprit.
netZ
Old 04-26-2003, 01:16 AM   #6
philip_g
Member#: 32906
it won't work but it will tell me if it's a problem with the diode/ecu or with the alarm brain, if it keeps going off that way.
2005 Neutral safety switch, where is it? WhiteNite Car Audio, Video & Security 18 01-15-2013 06:43 PM
02-03 neutral switch and reverse switch the same as 04????????? fastlanerex Transmission (AT/MT) & Driveline 3 11-25-2008 04:00 AM
How should I wire the trigger wire for the SafeIjnection? R0DENT Water/Methanol Injection, Nitrous & Intercooler Cooling 5 10-03-2006 05:38 PM
ECU neutral wire brunetmj Electrical & Lighting 2 01-23-2003 09:38 PM
GM keyless triggers my alarm! CosmoTheCat Car Audio, Video & Security 9 09-17-2001 11:10 AM
