Welcome to the North American Subaru Impreza Owners Club Sunday May 27, 2018
Old 12-07-2004, 12:43 PM   #1
sneeky
Member#: 44639
STi
the 35 awaits you...
Default Purpose of one step colder plugs?
did a bunch of searches and couldn't figure out the exact reason why people use them. also would it be benefitial for me to put them in my '04 STi with 21k and switching to a green setup in the spring (w/ all supporting mods obviously). tia.
chris
sneeky is offline   Reply With Quote
Old 12-07-2004, 12:49 PM   #2
dream
Member#: 37003
2015 WRX
Interested in this info aswell.
dream is offline   Reply With Quote
Old 12-07-2004, 01:17 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 12-07-2004, 01:23 PM   #4
sneeky
Member#: 44639
STi
ok... so should i switch them or not? i understand that you can go one step colder from 70-100hp increase, but is it a smart idea to go with the NGK's or should i replace them with stock for my upcoming setup? thanks again.
chris
Old 12-07-2004, 03:37 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
Helps remove heat from the combustion chamber (I think they say about ~20% of the heat leaves via the plug/cylinder head). Let's say you pull another 100C out of the combustion chamber, that's going to help with detonation considerably.
I'd only go one step colder, if you blast through the gears at least once a day to burn off the "fouling". If you have the luxury of driving like a mad man and race a lo,t you can look into 2 steps, but only take one step at a time, and then assess your fouling level. If you think avoiding det robs you of power, try fouled plugs--you'll really feel slow.
Plan on inspecting your plugs carefully after a change, and changing them more regularly until you know how they are performing. One step colder is not a huge change from the perspective of the plug, so just keep an eye on them. Read up on "reading spark plugs" too. You need to look way down inside the plug where the insulator meets the threaded case. Heat transfer occurs between the insulator and the cylinder head through the threads, that's where the fouling begins. Keep old plugs for reference.
Old 12-07-2004, 06:27 PM   #6
sneeky
Member#: 44639
STi
thanks bboy, good info. so would these be the proper plugs for my STi?
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=16602
chris
Old 12-07-2004, 09:03 PM   #7
2phless
Member#: 69343
1998 TransAm cnvrtbl
I installed DENSO IKH22-5345 plugs and they are fine. They are 1 heat range cooler. Some people bark about them but I've had no issue. If nothing else its a cross reference number. I was told from the NGK rep on the phone that there is not a colder NGK plug out yet for the STi but there will be. That was a month (+) ago.
2phless is offline   Reply With Quote
Old 12-07-2004, 11:09 PM   #8
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
chris
A simple search using "LFR7AIX" reveals all the necessary info you require.
http://forums.nasioc.com/forums/show...hlight=LFR7AIX
Wombat North is offline   Reply With Quote
Old 12-07-2004, 11:22 PM   #9
rich728
Member#: 40328
2004 WRX STi
BSP #728
Can i use the 2.0L how to guide on scooby mods for my 2.5L to change the plugs???
rich728 is offline   Reply With Quote
Old 12-07-2004, 11:28 PM   #10
2phless
Member#: 69343
The 2.0 plugs have different depths. Shallower.
Old 12-08-2004, 03:04 AM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
The proper plug is in a post to the sparkplug FAQ as I remember. It's exactly the same as the stock plug but has a 7 instead of a 6 for the heat designator.
The part number you quote does not look correct, it's in like the 4-5th post on the FAQ.
Old 12-08-2004, 02:01 PM   #12
bboy
Member#: 56468
04 Improved STI
Dirty White
LFR7AIX-11 for the STi 2.5L turbo, one step colder.
I noticed I did not include an important point about colder plugs: engines don't start as easily when cold. So, if you live in a very cold climate, think twice about going colder than stock. You can always go back to the stock, you are not going to hurt your engine with colder plugs (hotter plugs is a different story).
Old 01-10-2005, 09:21 AM   #13
root
Member#: 55854
2004 STi
Blue/silver
This seems to be implied, but I'd like to specifically ask, will colder plugs reduce EGTs to some degree?
root is offline   Reply With Quote
Old 01-10-2005, 10:27 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
WRONG
By NGK definition, the ' -11' plug is the WRONG one for the STi or the WRX, according to the FSM for both the STi and WRX.
Old 01-11-2005, 08:19 AM   #15
root
Member#: 55854
2004 STi
Blue/silver
I'm confused. Are there multiple versions of the LFR7AIX plug? Is there a LFR7AIX and a LFR7AIX-11? Is the LFR7AIX from sparkplugs.com right or wrong for the STi?
Old 01-11-2005, 12:53 PM   #16
sparkplugs
Member#: 79003
The "-11" at the end of an NGK plug shows a different gap setting than the standard plug. NGK doesn't make a "-11" in the "7" heat range. bboy gave a great description of the heat range purpose. Too cold of a plug, and they'll just foul out, too hot of a plug will cause engine damage. You'll want to go one step colder than stock for every 75-100hp you increase in mods.
NGK's online catalog shows a stock plug with a "5" heat range and a different reach. According to NGK's tech, this recommendation is wrong. The stock plug is ILFR6G, one heat range colder is the LFR7AIX.
sparkplugs is offline   Reply With Quote
Old 01-14-2005, 04:15 PM   #17
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Al_Smokemcrack is offline   Reply With Quote
Which of these NGK Iridium one-step colder plugs should I buy? lotarg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-01-2010 12:54 PM
does anyone around have a set of one step colder plugs? OvrClkdPmp Mid West Subaru Owners Club Forum -- MWSOC 0 01-15-2006 06:53 PM
One step colder plugs? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-01-2004 04:08 PM
One step colder plugs? What gap? munkis Normally Aspirated with bolt-on Forced Induction Powertrain 18 06-12-2004 07:48 PM
One step colder plugs worth it? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-27-2003 12:01 AM
