Welcome to the North American Subaru Impreza Owners Club Sunday November 3, 2024
Old 06-11-2008, 03:17 AM   #1
maramaralula
Member#: 96050
2005 EP Hatch Rrraw!
World Rally Blue
Default worry about stock block reliability @ 23psi boost even with a good tune
hey guys i need some opinion... i think i'm changing my turbo plan
right now i have this
i wanted this:
but after seeing this:
i changed my mind...
here's why...
I overlaid the 3 graph
confusing huh??
so to make it clearer i did some photoshop:
you see???
I love torque, especially when it peaks at 4000 rpm. Dom 3 doesn't get me close to the torque of the TD06-20G + meth
380+ wtq on mustang i think its pretty crazy... so i think I'm not going to do the bigger turbo
The thing is i only want to fill up with 91... once and a while if i have to add meth + water is no big deal for me.
what do you guys think? I think you'll feel torque way more than hp, especially on the street.
I kinda worry running 23psi though... stock is 14.5 psi, that's 8.5 psi over stock, even with a great tune do you think the stock STI block should
be ok?? Don't want the engine to break.
I know I'm just being anal... but think about it the STI engine is designed for 300hp/300wtq crank and 14.5psi. Now 332whp/382wtq on mustang,
which is about a freaking 450hp/500tq crank (assuming about 25% AWD drivetrain loss) @ 23psi. THAT'S 150HP AND 200LB-FT OF TORQUE OVER STOCK, IN
THIS CASE THE EJ257 IS RUNNING OVER 150% OF ITS DESIGNED POWER OUTPUT.
considering physics, and plain common sense... the engine life must be greatly shortened!!!
if it is shortened, i just want to know by how much is its life shortened. My STI is now at about 35,000miles... been running Stage 2 since
15,000. If i do this turbo + meth upgrade now, the engine life will not pass 50,000 miles right?? Then i'll have to get an upgraded block.
What do you think????
thanks to Stames_wiltz and POPOFF for their dyno graphs.
maramaralula is offline   Reply With Quote
Old 06-11-2008, 03:32 AM   #2
Remnex
Member#: 83790
You'll be perfectly fine. There are people running 35Rs on pump + meth with no issues on the stock block.
Quit being a vagina.
Remnex is offline   Reply With Quote
Old 06-11-2008, 03:34 AM   #3
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
It really depends on how you drive / have driven it.
If you don't flog it all the time, it could easily pass 50k.
I'd also look around for dom3 charts with meth. They seem to spool about the same... the dom3 won't have the huge torque peak, but will definitely give you much more top end. Remember, that kind of torque is fun, but in the end it causes alot more stress on the motor (provided both setups have the same redline).
fujiillin is offline   Reply With Quote
Old 06-11-2008, 07:22 AM   #4
MattPersman
Member#: 139385
20g on meth is a nice street setup. won't set any records, but nice feel and driveability. after driving it for a while I would imagine like most people you will be wanting more. I would suggest going with at least the Green, if you do not have a ton of money invested in your setup now, consider a rotated 30r. you can add meth whenever you want
MattPersman is offline   Reply With Quote
Old 06-11-2008, 09:39 AM   #5
Brady12
Member#: 80923
2008 FXT (XT Sport)
"You want to play you have to pay."
Always take that in to consideration when going for big numbers. The tune has a lot to do with it, but its not going to save your clutch, and other tranny components. A 35R on a stock block will get you gobs of power at the end of your redline, think 4k and on. Unless you go with a built engine, with a higher compresion ratio, which would help with the lag.
I would never go that route again, it was a headache, things were always beraking, or needing upgrading. If you have deep pockets, then have at it. To me the Subie lost her routes when going in that direction, which is a fast accellerating rally car, not a drag racer. When you start going into the laggy area, you have gone too far in my opinion. Our cars have a short redline, and you want to make use of all of it. That 39 is fun to play with, an EWG does wonders, with the propper boost control. That said a 20g, or a green will do the same with a great tune and out the lag. You can bennifit from a long power band all the way to redline.
-You will need a great tuner
-EWG
-Better boost control
Thats just my 2cents
Brady12 is offline   Reply With Quote
Old 06-11-2008, 11:46 AM   #6
sutter2k
Member#: 92467
08 STI
What about Dom 3 EWQ w/meth ? Dom 3 on 91 pump is not really exercising it.
sutter2k is offline   Reply With Quote
Old 06-11-2008, 12:22 PM   #7
starbux
Member#: 166874
2008 WRX
Red
You may want to consider a different frame of mind:
Cars are an expensive hobby that ALWAYS lose money.
starbux is offline   Reply With Quote
Old 06-11-2008, 12:49 PM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
that dom 3 is most likely faster then that 20g. cobbs dyno is a heeeeeeeeeart breaker of epic proportions. those are differnt dynos so its hard to compare these cars. if you want to make 320-350 wheel on pump with a resonable tune do a 20g plus meth. or even a green with a really conservative tune.
godforbid67 is offline   Reply With Quote
Old 06-11-2008, 02:15 PM   #9
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
I love how people always compare boost pressure between turbos especially stock to like a 20g. Stop comparing pressure and start looking at flow. Both at 20 psi aren't going to push the same flow and make the same power. Just like the comment about stock being 14.5 and 23 psi being 8 psi over stock! You could push 23 psi on a vf39 all day and the turbo would go before the motor would even sweat a drop. 14.5 psi from a 20g will probably make more power then 23 from a vf39. Theres plenty of motors that handle 100-300% more power then factory form. I dont think you'll have to worry about a 20g on a motor with only 35k miles... Tuning is everything
project_skyline is offline   Reply With Quote
Old 06-11-2008, 02:21 PM   #10
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Yes but are you going to pay for the block if it pops? 35R on 93 and METH is like 450-480WHP. You want to push that all day your going to blow the engine maybe not right away but a stock block takes one good detonation on its done. Hell a built engine can pop just as easy under that load.
I think the OP is to stuck on the plots. Well I mean just look at the plots on this page he is comparing. Go find a few guys at a Subbie meet and ask for a ride in the different setups Ive never seen a Subbie owner turn down the chance to show you what the cars got
4ST-AIR is offline   Reply With Quote
Old 06-11-2008, 02:22 PM   #11
CatfaceType-R
Member#: 81102
iwitarsa..it's good to see that some people(like yourself) actually read up and see that these setups never last long..they rarely do, if you look over time at the ratio of engine failure to long daily driven succes...it's pretty astounding, they almost all fail within 30,000 miles(as you predicted) most don't make it 20,000 miles
CatfaceType-R is offline   Reply With Quote
Old 06-11-2008, 03:17 PM   #12
Remnex
Member#: 83790
No, I wouldn't pay. However, I have seen people with stock blocks pushing this power for 20 - 30k miles without issue. And they beat on their car relentlessly.
You're right though, one major det and the motor is more than likely done. I'm not negating that. What I am saying is that if you can get the setup you want know and can rock it for 30k+ miles without issue and when the motor does finally go, you should have plenty of money saved for pistons and other things rather than just doing pistons now.
Makes more sense to me.
Old 06-11-2008, 03:24 PM   #13
vlady
Member#: 77997
dirty blue
Thank you! Good to read something with some sense in it...
vlady is offline   Reply With Quote
Old 06-11-2008, 04:46 PM   #14
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by Brady12 View Post
"You want to play you have to play."
It's a fairly simple concept, isn't it?
flycaster is offline   Reply With Quote
Old 06-11-2008, 11:07 PM   #15
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
-EWG
Wow, beautifully said.
zeropsi is offline   Reply With Quote
Old 06-11-2008, 11:16 PM   #16
phuhs04
Member#: 161270
2007 STI
BLACK
LAG= Enemy of Subarus- i dont care how you drive if you are driving above 4000 all day long thats great good luck with the new motor in a few months- the most power with the least amount of boost the better w/o running lean
phuhs04 is offline   Reply With Quote
Old 06-12-2008, 03:23 AM   #17
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
Subaru Stars
-EWG
seriously. you want moderately large numbers out of your subie, be prepared to buy/ rebuild a motor. The main reasons I did not go with an 18g for my 03 wrx: 1) Cost 2) possibly needing a new motor/tranny/clutch/all 3 very soon 3) cost 4) 90,000 miles 5) glass tranny 6) cost.
Seriously, like the previous statement, you wanna play be ready to pay. Most of the people that pay to play enjoy every minute of it, even while going broke. If possibly spending thousands of dollars to repair your broken dream doesn't get your juices flowing then dont do it. be a *****. like me.
but seriously you have an sti. Get a great tune. drive it how you want to. itll either brake or it wont.
howfast? is offline   Reply With Quote
Old 06-12-2008, 03:35 AM   #18
invisibleSTi
Member#: 123019
2005 WRX STi
PSM (Sliver)
IDK mang it's all a toss up. I went to go build my motor and found two cracked ringlands and a cracked VF39 (big surprise) and I was making 280 whp and 350wtq on the bay area's heartbreaker (mustang dyno @ GST).
I went forged pistons and rings and threw in some Cossie rod bearings and ARP headstuds and called it good for a built block. Seems to be handling the 360whp/380wtq just fine. Nice thing is I have room for a bigger turbo than my FP 20G 8cm w/porting.
I say go built or go home
invisibleSTi is offline   Reply With Quote
Old 06-12-2008, 05:34 AM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Originally Posted by iwitarsa View Post
The thing is i only want to fill up with 91.......once and a while if i have to add meth + water is no big deal for me.
i want 330whp / 380tq
You answered your own question with your plots.....a turbo in the 44-56 lb/min range isnt gonna get you that on 91 octane, which you show with the dom3 on pump.
Then you show a 20g + meth that is giving you exactly what you want...which shows that a 44lb/min turbo CAN give you what you want with meth.
However, the dom3 + meth will still give you the same (maybe more) low end torque plus gobs more up top....you'd probably be looking at 380/380 or 400/400 with the dom3 on pump+meth.
Both the dom3 and 20g only have about 200rpm worse lag than the vf39 in your comparo. The dom3 will outperform the 20g everywhere on meth.
I did 375/375 with my Green + meth.
It goes like this:
- if you are solely gonna use 91 octane get the 20g. On 91 octane the larger turbos will only net you 15-30whp. On pump gas boost levels the 20g is at better compressor efficiency and the bigger turbos are at worse.
- if you are gonna use 91+meth anything in the 49-52lb/min range (Green, gt3071, gt3076, dom2/2.5/3) will out perform the 20g by 30-60whp on meth and have the same spool...
- anything larger then you start sacrificing the low end more and more.
You also have to consider that if you DONT go with a 3" turbo inlet hose, 3" turbo inlet, tgv deletes, and stay tmic you will sacrifice spool. The 2.4" inlets and fmic will make you spool later.
You also have to take into account your headers (stock, equal, or unequal) and your method of boost control (stock, EBCS, manual, or external gate w/ ebcs or manual).....all these things will play a part in your spool and all of them played a part in the plots you posted above.....you cant merely compare dyno plots based on turbo alone you have to take the whole setup into account.
Old 06-12-2008, 10:46 AM   #20
Brady12
Member#: 80923
2008 FXT (XT Sport)
Here's another idea, hit that search tab. You'll find it to be very usefull. Learn from what others have done. You need to put some serious research in this my brotha. Do not just start adding things and work as you go, have a game plan.
Talk with some of the vendors out there. They can help you come up with a game plan, and help you achieve your goals. Again use the search tab, and head over to the vendor review section.
Do not go in to this with iffy thought, you need to be committed and ready pay for what you want.
Good luck
Old 06-12-2008, 02:26 PM   #21
GRUMPY514
Member#: 112285
2014 BMW 535i
Alpine White
Dom III is hands down the best turbo on that list.
Why no Dom III + Meth? Much more potential in that turbo than the stg 2/20g
GRUMPY514 is offline   Reply With Quote
Old 06-12-2008, 03:29 PM   #22
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Brings up another cardinal rule of high boost setups
Boost doesn't kill engines, Detonation does
Now with Meth, some crazy people run 30psi with 91 + meth. I spike to 27psi ish in 5th gear pulls
So I'd say with 23 psi you've got plenty of room for error! Remember the stock MAP sensor maxes out though so you can only run 22psi and still have fuel cut, or upgrade the MAP sensor.
But yeah, if you want torque, if you want flat and fat ginormous powerbands that make max HP from 5k-k, you need massive boost. No way around that.
I mean, look at that 4.5k-redline MAX HP powerband on the 20g+meth car you graphed
verc is offline   Reply With Quote
Old 06-12-2008, 04:36 PM   #23
maramaralula
Member#: 96050
World Rally Blue
what causes detonation then??
Old 06-12-2008, 04:43 PM   #24
Phatron
Member#: 36033
CEO PhatBottiTuning
http://en.wikipedia.org/wiki/Engine_knocking
while i understand what you are saying, i dont really agree with it. Although boost doesnt directly cause detonation it plays a major part in engine failures. Take a vf39 for example, you can only hit 16psi at redline and only make 300whp.....now take a Green/Dom3 that you can hold 26-27psi on at redline and make 400whp.....a knock event at 16psi/300whp power levels is not as bad as a knock event at 27psi/400whp levels. Having more air/fuel in the motor at higher hp levels (IE higher boost) the worse your detonation will be......at higher hp levels the amount of fuel/air is much higher in the motor, thus the severity of the secondary detonations will be that much worse.
In our cars its a fact that higher boost = more hp = higher cylinder pressure = more engine failures
The stock motor may withstand 500 high rpm detonations ~300whp and only 50 ~400whp.....
Very good advice. Wish i had the MAP sensor, may have saved my motor.
Old 06-12-2008, 07:17 PM   #25
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Comments like these make me wonder who's tuning your cars. 400whp can easily be obtainable with an EJ25 and be very reliable with a good tune. ****, the EJ20 that was in my 02 WRX has supported 310awhp 285tq with a Blouch 18G for a long time now with stock transmission and internals...and she's pushing about 130k on the odo at this point. The transmissions in these cars are also not "made from glass" like everyone loves to say. It's all in how you drive!
I think you'll be just fine pushing those types of numbers with an EJ25. Personally I'll be shooting for higher...
Steve.804 is offline   Reply With Quote
