Currently waiting for stephen (iatuning) to come back from.vacation (mans a wizard).
I had my car done at a local shop, everything was not put on properly, figured that out after overbposting instantly and leaking air from a coupler. All the crap was loose and/or hanging and ziptied.
Met up with a few buddies and fixed everything up and re-routed the vacuum lines properly. After putting everything back together, we took out the car for a drive and it held the boost to 19-19.8 lbs after about 5 pulls.
After deciding to try a launch from a dead stop. The car overboosted and went straight into limp mode. Haven't held boost since and it just goes straight from 17-24 in an instant. You can hear the wastegate open around 23 lbs of boost. I'd post logs but I am currently at work, I'll post when I can.
I am using cobbs ebcs, tial 38mm wastegate, and a grimmspeed up pipe.
