Welcome to the North American Subaru Impreza Owners Club Wednesday December 11, 2019
Old 10-22-2019, 08:17 AM   #501
AVANTI R5
Member#: 73805
Just noticed MHoward1 posted..o well I’ll hit post anyway
Dyno Test Of The 2020 Chevrolet C8 Corvette Reveals Huge Power Numbers
https://jalopnik.com/this-dyno-test-...-hu-1839225233
The folks at Motor Trend strapped the 2020 Chevrolet Corvette to a dynamometer to see if the 6.2-liter Small Block “LT2" V8 actually makes the stated 495 horsepower, 470 lb-ft. The websites findings?: “The 2020 Chevrolet Corvette C8 provided for all our testing produces more power than what Chevy claims.”
I’m always hesitant to write things like “Dyno proves that [insert automobile]’s horsepower numbers are underrated,” because there’s a lot that goes into horsepower certification, and there are quite a few factors that can cause results from one particular dynamometer to differ from those of another.
But Motor Trend, with input from its brilliant former Chrysler engineer and current technical director Frank Markus, discusses some of these concerns in the story.
Motor Trend conducted six dyno pulls on a production 2020 Chevrolet Corvette in fourth through sixth gears. Output ranged from 478 HP and 536 lb-ft at the wheels (that’s roughly 562 HP and 630 lb-ft at the crankshaft assuming a 15 percent drivetrain loss—note that Chevy engineers told Motor Trend that actual losses are lower) tested in sixth gear to 561 horsepower, 515 lb-ft of torque (or about 660 HP and 606 lb-ft at the crank assuming the same 15 percent loss figure) tested in fifth.
One possible explanation for the power discrepancy, Chevy apparently told Motor Trend, has to do with how the Corvette’s engine’s official power numbers were obtained. From the article:
The other explanation is that Chevrolet certifies most of its engines through the SAE, the Society of Automotive Engineers, which follows a strict set of rules and standards to determine the horsepower and torque ratings. In other words, the SAE acts as an independent party that’s present during the engine tests and is the one who determines the final output ratings. Their testing does not involve a simple pull from idle to redline, either. Rather, rpm are slowly ramped up and allowed to stabilize before accelerating further. This process results in significantly more heat generation than any single pull from our six dyno runs. For that reason, the engineers say, it’s not uncommon for single chassis dyno pulls to register higher output (and it is extremely unlikely any car will ever generate less than rated output).
The website even looked at the official SAE results:
A quick check of the SAE database reveals that the certification test of the 6.2-liter V-8 LT2 engine with the optional exhaust system took place at the Pontiac Engineering Center in Michigan on April 9, 2019. Jordan Lee, chief engineer of the Corvette’s engine, signed the certification on July 15—just three days before the reveal in Tustin. The engine was rated at 495 hp at 6,450 rpm and 470 lb-ft of torque at 5,150 rpm The vehicle code name 2020 Y2XX underwent three tests, and the power and torque graph looks similar to the one we had at the dyno.
Ultimately, Motor Trend isn’t sure why its numbers are so high, saying the dyno it used complied with the SAE procedure, and that this was the same dyno the team had used when testing a 2020 Ram 2500. The torque figure from that test, in case you are curious, wasn’t far from Ram’s claimed (but not SAE certified) peak figure. Still, despite a number of questions still unanswered, Motor Trend concludes that the Corvette tested does indeed produce more power than what Chevy claims.
This is all a bit odd, because if the Corvette’s engine is SAE certified to make 495 horsepower, then it’s supposed to make that much power—that’s a requirement.
As I’m not as well-versed in the area of power and torque certification as some, I called up Gary Pollak, a Program Manager at the Society of Automotive Engineers.
Pollak said when it comes to SAE certified horsepower, it’s “pretty tough to fudge the results,” and that “All production engines must be within 2 percent of the certification claim.”
He also said that automakers are allowed to claim an SAE certified horsepower number within 1 percent of the measured result—this might allow an automaker whose result was 499 horsepower to claim 500, for example.
“If somebody does run at that same kind of condition in 1349 and they see something that’s wider than that [2 percent] band,” Pollak told me, “they could make an appeal to SAE and we could actually re-test it and either revoke their certification or publish something...”
As for the numbers from the Motor Trend test, Pollak told me that this type of discrepancy is exactly what the SAE test procedure hopes to solve. “I’m not sure what conditions Motor Trend used, but the SAE standard basically tries to typify what the consumer would see” accounting for all relevant power draws, he told me, going on to say that while the dyno used in Motor Trend’s tests may have complied with the SAE procedure, “it’s all of the auxiliary conditions that they might not have accounted for.”
“There are so many conditions that are involved in the test...the numbers could be all over the map... It’s hard to compare from one dyno test to another,” he said. The SAE J1349 test, then, is meant to act as a sort of “datum” against which all engines can be measured so that they can be fairly compared. You can see the full list of SAE certified engines here. Among the engines on there is the supercharged 6.2-liter V8 found in the 2015 Dodge Hellcats.
That engine was rated at a peak power of 707 horsepower, and under the exact same conditions, the Corvette makes 495. Thus, it should be safe to assume that the Corvette’s motor is 70 percent as powerful.
But maybe it’s not safe to make that assumption? It’s easy enough to say simply “The test procedure was different,” but there’s always that chance that perhaps the test car really did have a more powerful engine. Motor Trend seems confident of this, though we may never actually know the truth.
Definitely check out their full story here.
How Much Power Does the 2020 Chevrolet Corvette Really Make? We Take it to the Dyno and Find Out
https://www.motortrend.com/news/2020...c8-power-dyno/
Old 10-22-2019, 05:56 PM   #502
rmbrady
Member#: 6228
2017 SS
I always thought the SAE certification just meant the engine had to make at least that much power, not that it was also the max it could make.
Not sure what the benefit of underating an engine is in this day and age, but BMW seems to consistently do it on their turbo motors.
rmbrady is offline   Reply With Quote
Old 10-23-2019, 08:33 AM   #503
TriAxis 6
Member#: 377862
2017 Z06/Z07 & Fozzy
Admiral Blue & CWP
Default Mid-Engined Corvette Program Reportedly Inching Towards Public Confirmation
Agreed, I assumed it was an “under worst possible case scenarios...bad gas, wear, temps, etc. The engine is guaranteed to make at least XXX HP” rating.
That being said, maybe a 5% upswing would be common, but the numbers being spoken about are blissfully confusing to me.
TriAxis 6 is online now   Reply With Quote
Old 11-08-2019, 07:06 AM   #504
AVANTI R5
Member#: 73805
Default Gm Releases Official Full Performance Stats For 2020 Corvette
Chevrolet Releases Full Performance Stats For 2020 Corvette Stingray
General Motors has released the full, official performance statistics for the 2020 Corvette Stingray, calling the car the “quickest in its history.”
We already knew the 2020 Corvette Stingray with the optional Z51 Performance Package would be able to accelerate from 0 to 60 mph in 2.9 seconds, but now Chevrolet has confirmed it will also complete the quarter-mile in 11.2 seconds at 121 mph. As a reminder, the Corvette C8‘s naturally aspirated 6.2-liter LT2 V8 engine is rated at 490 horsepower and 465 pound-feet of torque in base form and 495 horsepower and 470 pound-feet of torque with the optional performance exhaust.
Meanwhile, the base 2020 Corvette Stingray without the Z51 package will accelerate from 0 to 60 mph in 3.0 seconds flat and complete the quarter-mile in 11.2 seconds at 123 mph. We imagine the additional trap speed is due to the lack of a front splitter and rear wing, but the quarter-mile time likely remains the same between the Z51 and standard model due to the Z51’s superior acceleration. The Z51’s slightly quicker acceleration time comes from its shorter final drive ratio, stickier tires, electronic limited-slip differential and additional power and torque.
“The performance of the 2020 Stingray has far exceeded our expectations,” said Chevrolet vehicle performance manager Alex MacDonald. “Moving more weight over the rear wheels helps us get off the line quicker, but it’s the integration between the powertrain and chassis that really takes the performance to new levels.”
To achieve these claimed acceleration numbers, drivers must initiate a “performance launch” by putting the vehicle into Track mode, pressing the traction button (thereby putting the vehicle in Performance Traction Management mode for Magnetic Ride Control-equipped cars or Competitive driving mode for all others) and fully depressing the brake and accelerator pedal at the same time. When the revs climb to 3,500 RPM, they can then release the brake pedal and hold on tight.
GM says the standard eight-speed dual-clutch transaxle is a major contributor to the performance of the 2020 Corvette Stingray. Developed in conjunction with Tremec, the paddle-shift transmission was designed to provide “uninterrupted torque delivery” via smooth, lightning quick shifts.
Meanwhile, the standard mechanical differential is designed with “straight-line acceleration and dynamic handling” in mind and shares its common ring and pinion gear ratio of 3.55:1 with the Z51 Performance Package’s electronic differential. Compared to the mechanical diff, the eLSD is focused more on “ultimate control during track driving,” as opposed to straight-line acceleration. The mechanical diff has a final drive ratio of 4.9:1, while the effective final drive ratio of the eLSD is 5.2:1.
“The goal from the beginning was to design a transmission worthy of an exotic supercar that is fun to drive everyday,” GM’s global chief engineer of transmissions, Terri Schulke, said in a statement. “We achieved that goal by combining the best attributes of the LT2 and the DCT, and I think the impressive performance numbers speak for themselves.”
Old 11-08-2019, 11:24 AM   #505
Pre
Member#: 139693
No manual no sale.
Old 11-08-2019, 04:18 PM   #506
TriAxis 6
Member#: 377862
Admiral Blue & CWP
No manual no sale.
I’ve been saying that since day one
Old 12-02-2019, 12:48 PM   #507
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
C7 vs the C8
https://www.motortrend.com/cars/chev...-track-review/
The Corvette has long been the bad boy of the racetrack, the Bart Simpson of supercars. Rude, loud, cheap, unpredictable, and hard to handle; but fast and fun in its own brash way. Now, the Corvette has finally grown up. The C8 Corvette is more sophisticated, capable, and mature. And recently, we were honored with an exclusive 2020 Chevrolet Corvette Z51 track test at VIRginia International Raceway, driving the 911-beater in street and track alignment settings.
To our pleasant surprise, Chevy also supplied a 2019 C7 Grand Sport, which I consider to be the best-handling of all the C7 variations. At this test, Chevy required that a passenger ride along, and that victim was in fact Corvette lead development engineer Mike Petrucci.
If you're a follower of MotorTrend, you have heard my complaints about the way the C7 drives at the limit. Or more accurately, the way it drives over the limit of grip so suddenly. The car has the dubious distinction of being one of the only test cars in which I leave the stability control on, albeit in the minimal setting, as insurance against an embarrassing and possibly dangerous spin on my hot laps as a result of its sudden snap power oversteer.
mhoward1 is offline   Reply With Quote
