Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 02-10-2011, 03:51 PM   #1
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
Default How do you properly prime a new turbo?
Hello fellow suby peeps!
I would like to know how everyone primes their new turbo prior to going out and driving after install. I'm replacing my VF40 with a VF48 and I wanna make sure that when the install is done that its properly primed and all fluids are running their proper course. So any input would be awesome. Turbo should be here tonight so I will be checking this until the install.
Cheers!
-Chris-
Black07STiGuy is offline   Reply With Quote
Old 02-10-2011, 04:23 PM   #2
Feign
Member#: 68604
06 STi
Do everything else.
Remove fuel pump relay.
Crank for five seconds.
Replace fuel pump relay.
It will likely try and fire on the first attempt. Either relieve the pressure in the lines beforehand or shut it off right after it tries to fire. Don't let the thing idle.
Feign is offline   Reply With Quote
Old 02-10-2011, 09:11 PM   #3
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
sweet thanks, now where is the fuel pump relay? lol
Old 02-10-2011, 09:44 PM   #4
Feign
Member#: 68604
06 STi
Either in the fusebox under the hood or in the passenger side kick panel
Old 02-10-2011, 10:07 PM   #5
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
thanks much, well ups failed me today so looks like i will be doing it tomorrow.
Old 02-10-2011, 10:17 PM   #6
SeeeeeYa
Member#: 129681
'19 Imp Ltd Wagon
CWP
Maybe it is so obvious and taken for granted no one is saying it... but when I changed my turbo I made sure it was full of oil to begin with. I filled it with oil before I put it on, and I refilled it before putting the fittings on... THEN I primed it by cranking the unpowered engine.
Oil filters are filled before installation for the same reason.
SeeeeeYa is offline   Reply With Quote
Old 02-10-2011, 11:01 PM   #7
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
^^^^ I do the same thing, I use a plastic generic condiment bottle with oil in it.
Did you go front mount?
theotherguy is offline   Reply With Quote
Old 02-10-2011, 11:54 PM   #8
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
yes I did go with a fmic. and a 48. But thanks for all the help tho. I did help someone recently make a big tmic using your outline.
OK so pull the fuel pump fuse, fill turbo prior to installing the oil feed banjo bolt. Any other pointers?
Old 02-11-2011, 12:03 AM   #9
4080wrx
Member#: 68129
Chapter/Region: HIIC
2001 Impreza RSTi
or you can disconnect the crank angle sensor.
4080wrx is offline   Reply With Quote
Old 02-11-2011, 12:04 AM   #10
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
can you dumb it down a bit for me? lol
Old 02-11-2011, 12:42 AM   #11
4080wrx
Member#: 68129
2001 Impreza RSTi
right above your crank pulley is a sensor and plug. disconnect the plug. your car will then crank and not fire up.
from personal experience I have never prefilled the turbo with oil and never had any issues. the exhaust pressure coming from just the engine being spun by the starter is not enough to lock up a turbo do to lack of oil IMO. once you start cranking/priming, oil does however start to cover the internals of the turbo. I pesonally will crank it twice for 10 seconds each and then reconnect the crank angle sensor and then fire up the car. again never had any issues
Old 02-11-2011, 12:57 AM   #12
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
Thanks guys.
Old 02-11-2011, 01:00 AM   #13
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Here...
Borrowed from meatbawl...
Prefilling is just a little insurance, everyone does it different...
Old 02-11-2011, 01:21 AM   #14
usfsfire42
Member#: 242630
.. Flu shot
technician.
I have never heard of putting oil in your oil filter after replacing it? I have also never seen this done. I see how you could do this on our subarus, but lets say were looking at a toyota, the filter on a tacoma is mounted facing up.
usfsfire42 is offline   Reply With Quote
Old 02-11-2011, 02:07 AM   #15
atomicfire
Member#: 136296
2005 STi
I always fill my new filter after replacing the old one. On cars where the filter isn't mounted horozontally, I just fill it halfway or so and spin it on as quick as I can.
as far as the turbo goes, you can also pull the IGN fuse under the dash and it will turn over but not start. I crank until the oil pressure warning light goes away, let it rest a little bit for the starter to cool down, then crank it a little more.
atomicfire is offline   Reply With Quote
Old 02-11-2011, 08:14 AM   #16
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
this. you guys are overthinking the priming. squirt a little oil in the top oil feed opening on the turbo itself. connect the line to the turbo. start the car. done. did this when i did my vf52 swap and everything is good.
424wrx is offline   Reply With Quote
Old 02-11-2011, 12:16 PM   #17
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Don't bother pulling any fuses, you don't need to go through ANY of that hassle.
Floor the gas pedal, and crank for 10-20 seconds (in bursts of 10 sec), then start the car. At WOT the ECU will cut all fuel while cranking, no need to pull a single fuse.
Old 02-11-2011, 07:55 PM   #18
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
im installing a vf43 tomorrow and was going to use a baister or whatever you call it and squirt oil in the turbo before putting the banjo on. will that be good enough?
spec_bg is offline   Reply With Quote
Old 02-11-2011, 08:16 PM   #19
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i used a plastic ketchup bottle from the dollar store. squirt some in the top and spin the turbine some. the flooring the gaspedal technuique as mentioned below is the easiest way to get the oil flowing after the install.
Old 02-12-2011, 06:35 PM   #20
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
keep us updated on the install. the vf48 is gonna feel real nice compared to the vf40.
Old 02-13-2011, 12:26 PM   #21
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Even after a decade and several cars, you learn something new everyday, thanks. I'm gonna have to try that with hydra too.
Old 12-02-2019, 01:42 PM   #22
pokeavice
Member#: 441050
Thanks for that eggroll.
pokeavice is offline   Reply With Quote
how do i safely prime my new turbo? snobord1986 Newbies & FAQs 7 02-06-2009 11:49 PM
how do you know if its a turbo? lowrider89 Newbies & FAQs 14 03-09-2008 09:57 PM
How do you properly dynomat the doors of the WRX Goofy's WRX Car Audio, Video & Security 22 03-29-2005 05:49 PM
how do you properly "torque" a bolt? FullContact007 Service & Maintenance 7 12-10-2004 04:22 PM
How do you know if your stock Turbo is gone? superstud General Community 23 12-07-2004 06:07 PM
