Welcome to the North American Subaru Impreza Owners Club Friday December 6, 2019
Notices
Old 12-08-2012, 03:24 PM   #1
DuckStu
Member#: 124060
2004 WRX STI
Default AVCS cam pulley cleaning (How to)
So my '04 STI engine spun a rod bearing and I had the long-block rebuilt. But then I had to clean the cams, shim the valves, clean the AVCS solenoids and inspect / clean the AVCS pulleys themselves.
Precious little info online.
So here goes.
'04 - '07 STI only has AVCS on the intake cams,.. so here's a walk-through with pictures of the driver's-side intake pulley.
Here's the front side of the pulley with the dust cover removed and the large cam-bolt and the 3 small dust-cover screws sitting in their respective positions.
The backside showing the 6 bolts that hold the pulley onto the AVCS mechanism. THESE BOLTS USE A 5 SIDED VERSION OF A TORX BIT. You will need to order this special tool. They're about $9. I ordered mine from Oakos, who gets them from "Company 23". aboothman below says it's actually a Torx tamper-proof T30. You can see mine attached to a 4" socket extension in this picture.
http://www.oakos.com/Merchant2/merch...Category_Code=
Pulley off.
No more bolts to undo to get the back cover off,... but I had to tap at the edges a bit with a sharp chisel, very lightly,... and it popped off.
Pulling the back cover off the mechanism. Care full with the part my fingers are touching. This is the surface that rides in the cam seal on the front of the engine.
Back cover flipped over.
Press the inner rotor out from the front side with your thumbs. Do not use tools on the rotor itself. It's aluminum and many of the surfaces are of critical tolerance. Especially the top and bottom flat surfaces.
Rotor coming out.
Rotor flipped over. You can see the pin on the rotor (top left of this picture,.. on the rotor-lobe between my fingers), and the socket that it sits in at the bottom of the housing on the right. This pin is hydraulically activated. At idle (I think) or when the AVCS solenoid wires are unplugged the AVCS does not have adequate pressure, and the cam timing is held in position by this pin. Once the ECU wants to adjust the timing,.. hydraulic pressure is fed to the mechanism,.. which raises this pin out of the socket,.. and allows the inner rotor to begin to move.
This is why it's important to NEVER hold the cams when you tighten or loosen the center pulley bolts from the engine. The amount of force required to break loose the cam bolts is enough to damage these pins and their sockets in most cases. There is a good chance your AVCS will never function again properly. Use the belt method or buy one of the AVCS holding tools. The AVCS tool is actually very important to get proper torque on the AVCS pulley center bolt. It's a torque, then degree method,... and the degree indicator resting against the pulley tool allows for an accurate reading.
Company 23 also makes these special tools, (As does AMS and others.)
You can also see the 6 seal-springs and 6 seals that have dropped out. No worry,... these are very easy to re-install. No nightmare here.
Cleaned, inspected and ready to put back together.
Here's a closeup of the seals. (Brake cleaner will wreck your manicure)
DuckStu is offline   Reply With Quote
Old 12-08-2012, 04:36 PM   #2
DuckStu
Member#: 124060
2004 WRX STI
Set the spring into the back of the seal and slide them into the trench in the rotor. You'll do this 6 times. 30 seconds tops.
All done. ready to put the back cover on. On the bottom right you can see part of the pin-socket. I assembled the mechanism with the rotor in the position shown,.. and then rotated it until the pin snapped into it's socket. i just wanted to make sure it wasn't binding somehow. (just for the goof basically). Just make sure to have that pin snaps into it's socket before you button everything up.
The mechanism has a locating pin for the back cover and pulley. So you can't get the back cover or the pulley in the wrong orientation. That same pin also locates the outer belt pulley. SO the timing marks will be in the right place. Fairly fool-proof really.
Remember the two different size bolts? 3 each? The small ones are to be torqued to 45 INCH pounds,... the bigger ones to 180 INCH pounds. I did up the big ones to 100 in-lbs first,.. then the small ones to 45,... and re-torqued the big ones to 180 in lbs. Habit I guess.
Re-installing the cam-pulleys on the engine is more of a headache. The non-AVCS exhaust cams were pretty easy. 72.5 ft lbs.
The AVCS intake cams are not so easy. Torque them to 21.5 ft lbs,.. then tighten them another 45 degrees. This requires a Torque Angle Gauge,.. which I had bought previously for $10 an an auto parts store.
Note,... holding the AVCS tool, the Torque angle gauge and keeping everything straight is really a three hand job. This is easily the hardest part of this job.
Old 12-08-2012, 08:37 PM   #3
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Nice writeup. Subscribed for future reference.
BlueSTI4Me is online now   Reply With Quote
Old 12-09-2012, 11:47 AM   #4
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Very nice!I will do this when my motor gets rebuilt!Is the rubber seal replaceable?
EROCS04SBRUSTI is offline   Reply With Quote
Old 12-09-2012, 01:42 PM   #5
DuckStu
Member#: 124060
2004 WRX STI
Both the "O" Ring on the front and the seal under the mechanism rear cover are replacable. New "O" Rings for the front cover came in the OEM engine gasket set,.. but I have not seen the seals for under the mechanism cover (not something they expect you to take apart I suppose.)
Some RTV could be added to the seal to make sure it doesn't leak,.. but I opted not to.
I hope that doesn't ome back to bite me.
Old 12-10-2012, 10:27 AM   #6
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
This is very useful.
Old 12-20-2012, 08:39 PM   #7
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
The bit for the 5-point star bolts holding the gear on is a torx plus tamperproof t30 BTW.
aboothman is offline   Reply With Quote
Old 08-18-2013, 07:19 PM   #8
KzooBaja
Member#: 354285
2004 Baja Turbo
I ordered a T-30 Torx Plus and it has 6 points, NOT 5 like these bolts are!.... Does anyone have a place and part number to get the correct one???
KzooBaja is offline   Reply With Quote
Old 08-18-2013, 07:42 PM   #9
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
They are a tamperproof torx plus t-30. Hard to find. Company 21 makes one... Rally sport direct sells them among others
Old 08-18-2013, 07:47 PM   #10
Justin V
Member#: 98747
07 WRX
I bought mine at pepboys for $5, I broke one but have only needed the 5 point for this job so it sees very little use.
Justin V is offline   Reply With Quote
Old 10-12-2013, 03:14 PM   #11
Bullit62
Member#: 281311
2009 WRX
Dude, you're awesome! I was wondering how to get the rod bearing residue out of my '09 WRX's nooks and crannies and I stumble across this gem.
Nice writeup and a big +1 on using the Company23 tools! RSD has all the Company23 tools you'll need in stock and it's a lot easier doing the job with the right tools than trying to MacGyver things...
For the record, here's the Company23 AVCS Security Socket
Bullit62 is offline   Reply With Quote
Old 01-11-2014, 07:58 PM   #12
bizarro252
Member#: 336417
2008 STi
Has anyone done this on a dual avcs? The Exh cams have a spring thing in the middle that looked like it was holding the center rotor from coming out but that is not it... I can get the intk ones apart just like in this tutorial but not the exh ones
bizarro252 is offline   Reply With Quote
Old 01-13-2014, 08:52 PM   #13
autoscience
Member#: 353836
Its good to know that there are still people out there that know what cleanings steps need to be taken when a motor goes bad. Good write up, you can get the 5 sided torx right off the snap on or mac tool trucks.
autoscience is offline   Reply With Quote
Old 01-13-2014, 11:46 PM   #14
bizarro252
Member#: 336417
2008 STi
^+1billion
To those of you who spin a bearing in the future and are reading this, I flushed these out several times and on the final rinse STILL saw copper flakes of **** coming out, SO DO NOT OVERLOOK THESE, clean them out...
Old 01-16-2014, 12:01 PM   #15
Markbo
Member#: 376820
2005 Legacy GT Limit
Tagged for future reference
Markbo is offline   Reply With Quote
Old 01-17-2014, 01:22 AM   #16
bizarro252
Member#: 336417
2008 STi
FYI for those of you with dual AVCS... I ended up buying new exh gears, I called and emailed several sources who rebuild them and the exh ones are a BITCH so... I bought new ones and cleaned out the intake ones (intake gears follow exact directions listed in OP)
I bought my gears here, GREAT service, even better prices :
https://www.flatironstuning.com/p-21...cam-gears.aspx
Old 01-20-2014, 11:43 AM   #17
Markbo
Member#: 376820
bizarro did you replace them because you couldn't get all the crud out or did you find something wrong with them?
Old 01-20-2014, 10:41 PM   #18
bizarro252
Member#: 336417
2008 STi
I replaced the exh ones because I simply could not figure out how to get them apart. I called a few subi shops and they said it was a bitch to do I tried flushing them out without taking the rotor out since I could not figure out how and even after 5-10 min still saw metal bits coming out every now and then so I just ditched the idea... worth 250$ to just not have to worry about it
The intake ones came apart ezpz
Old 02-13-2014, 04:01 PM   #19
outfrontmotorsports
Member#: 220204
outfrontmotorsports is offline   Reply With Quote
Old 02-13-2014, 09:50 PM   #20
carlos.danger
Member#: 363268
2015 WRX STi
^ pm sent outfront
carlos.danger is offline   Reply With Quote
Old 02-14-2014, 11:47 AM   #21
Markbo
Member#: 376820
Just a follow up... should that be done if I have to change out the cam seals due to leaks?
Old 02-15-2014, 03:12 PM   #22
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Originally Posted by outfrontmotorsports View Post
Interesting!!
Old 02-17-2014, 12:22 PM   #23
m_foster
Member#: 164945
2004 XTi
Does anyone know where to find replacement security bolts for the back of the gear? I stripped a couple of them during removal. The dealership said they couldn't order them.
m_foster is offline   Reply With Quote
Old 05-13-2016, 03:31 AM   #24
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Default Years have passed
Has anyone figured out the secret to disassembling the exhaust AVCS cam gears? Like the guys above, I can't get the rotor out. And there is no sign of anything that might release it.
My only guess right now is that it might unlock somehow when oil pressure retracts the pin. And with luck, air pressure might do the trick. Haven't tried though.
Old 11-03-2019, 05:40 AM   #25
TApoK
Member#: 371076
2005 Impreza WRX tun
black
I found gasket sets on ebay, who ordered these?
https://www.ebay.com/itm/17378047524...84.m1561.l2649
TApoK is offline   Reply With Quote
