Welcome to the North American Subaru Impreza Owners Club Friday September 18, 2020
Old 04-09-2019, 10:06 AM   #51
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Indeed we are. Every time I see president Dwayne Elizondo Mountain Dew Herbert chump camacho come out onto the tube I expect to hear machine gun fire. By the time the rock or Schwarzenegger becomes president they will be shooting full auto and we will have full gun control implemented on us..
Dadsquatch is offline   Reply With Quote
Old 04-09-2019, 10:35 PM   #52
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 04-10-2019, 10:25 PM   #53
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Here's a better picture.. other one looks like I cut and sewed it back together lol..
Old 08-14-2019, 01:48 PM   #54
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Another update. We had some serious piston slap at cold start that continued through (but quieted down signifigantly) warmup.. We decided to add a turbo and intercooler. My boy just bought everything on eBay.
Bought some cheap pistons that are .5mm over. We are going to bore each cylinder on the mill.
Planning on not going over 8psi until we get a sti block. But it is nice to have a couple of extra ej251 and ej25d blocks just in case..
Will update pics soon
Old 11-08-2019, 10:43 PM   #55
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 11-08-2019, 11:22 PM   #56
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 11-08-2019, 11:36 PM   #57
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 11-08-2019, 11:55 PM   #58
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 11-09-2019, 12:31 PM   #59
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 11-09-2019, 12:34 PM   #60
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
Old 11-09-2019, 07:46 PM   #61
sayunkl
Member#: 302548
2019 Golf R
2018 High Country
Nice work on this project!
sayunkl is offline   Reply With Quote
Old 11-09-2019, 08:25 PM   #62
BoxerLover
Member#: 126131
11 wrx sedan
black pearl
man. keep it coming. love following this build
BoxerLover is offline   Reply With Quote
Old 11-19-2019, 03:52 PM   #63
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
great build! would highly recommend welding a section back into that front subframe or buying a legacy/GC turbo subframe. On my first SOHC turbo build back in 07 I notched the crossmember like you did and ultimately cracked/failed the crossmember.
master c is offline   Reply With Quote
Old 12-03-2019, 05:24 PM   #64
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
That sounds like a painfully mistake master c. Yes, we welded a 4" piece of 1x1x1/8" angle across that cut. I'll throw some more pics up soon. We are in the tuning section right now. Have a from raider. Think we need to upgrade the map sensor to a gm 2bar. It has solid misfires under full boost 5psi
Runs great otherwise. If you slowly step on the throttle the turbo spools and will work. Otherwise no problems. I have a thread out there explaining the problem better. And asking for some help with finding the bypass method for the map sensor. I'll a range pics in a bit when I get more time. Thanks guys!
Old 12-03-2019, 05:27 PM   #65
Dadsquatch
Member#: 458140
1995 Impreza
White, green,
