Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 11-25-2019, 09:57 AM   #1
SithSTI
Member#: 508661
Default Cheapest way to rebuild?
Definitely blown head gasket, possibly cracked ringland. Starts and sounds okay it's just a smoke show. 2012 STI
SithSTI is offline   Reply With Quote
Old 11-25-2019, 12:47 PM   #2
bizzlezx10r
Member#: 439586
2015 WRX
ISM
Aside from "Do it yourself" like 90% of people will probably say. I don't think there really is a cheaper option. I feel like any cheap way would put you right back into the situation you're in now
bizzlezx10r is offline   Reply With Quote
Old 11-25-2019, 01:03 PM   #3
shagfagon
Member#: 337836
2002 WRX Wagon
Used longblock, you do the labor. Only viable "cheap" option
shagfagon is offline   Reply With Quote
Old 11-25-2019, 01:23 PM   #4
pepep
Member#: 456363
2007 Forester XT 5MT
Grey
I see people selling supposedly good condition long blocks from $800-$1200 then add $800-$1000 more for timing belt, water pump, gaskets, misc extras, ect, reuse the heads and you could probably get it running for $2000-$2500 but I wouldn't go that cheap. I don't see the point in spending big money and trusting used engines.
The cheapest I'd go is a new shortblock from Subaru for $1900, timing belt, gasket kits, and have the heads at least checked or rebuilt from a machine shop. going this route would be ~$4000 but would be closer to a whole new engine.
That's of course if you do it yourself. Add $1500-$2000 if you pay to have it done by someone else.
pepep is offline   Reply With Quote
Old 11-25-2019, 04:20 PM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
why not buy a short block from Subaru? that is the cheapest with the least depending if your machinist has a bad day or you
subaru_gc8 is offline   Reply With Quote
Old 11-28-2019, 02:11 AM   #6
Drexer13
Member#: 189527
By far the cheapest way to rebuild an engine is to do it yourself and to be watchful for good deals. I'm far from a Subaru expert but I have rebuilt my fare share of engines the latest being an ej205.
To give you an idea here is a parts list of my last build along with prices.
Pistons $210.00 NIPPON RACING
Gasket Set $120.00
Main+Rod bearings $88.00 Race ACL
Timing gear $190.00 Gates
Oil Pump 110.00 Oem 11mm
Water Pump $54.00 Gates
Machining 175.00
So in total I spent around $950.00.
keep in mind the machinist pressure tested the heads for free and i checked the decks and lapped in the valves.
There are also incidentals to think of like spark plugs and fluids, you should also consider replacing hard to get to things like your clutch while the engine is out.
Drexer13 is offline   Reply With Quote
Old 12-01-2019, 12:41 PM   #7
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
It can go both ways. I ended up doing it myself and I spent more than if I would have taken it to shop. That is also because I bought all performance parts including a closed deck IAG engine which is 5k alone. I literally spent over 10k on engine parts, upgrades, etc. I had no prior knowledge of how to even take an engine out when I started, now I could pull a subaru engine easily myself in 5 hours give or take beer breaks and such. In your situation I would probably just get an oem shortblock, your heads reworked, and call it a day if youre on a budget.
ThinWRX is offline   Reply With Quote
Old 12-02-2019, 12:55 AM   #8
subi-T
Member#: 348082
2006 impreza
SGM
Sorry to bust in and steal the thread but...
Anyone here in socal willing to do a side job and build a block?
subi-T is offline   Reply With Quote
Old 12-04-2019, 03:57 AM   #9
Drexer13
Member#: 189527
normally id be all over that. but im a bit backed up at the moment. I have an ej255 on my bench, an LS on one of my stands and a ford modular on the other.
Old 12-05-2019, 02:11 AM   #10
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Let’s say you went through high water
Hydro Locked your engine
You Make a claim with your insurance company
They will pay for a LKQ/used engine every time
“Most cost effective “
Search around your city/region
AliBenn is offline   Reply With Quote
Old 12-05-2019, 08:34 AM   #11
Jay11STI
Member#: 492422
Before you go about spending money on a rebuild, have you done any diag on the car yet?
Has compression and leak down been performed to verify engine health?
Has the engine been checked for oil or coolant consumption?
Has the PCV valve been replaced?
Jay11STI is offline   Reply With Quote
