Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 11-27-2019, 03:18 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Valve cover gasket leak
The valve cover on my 06 wrx engine was leaking before and I changed it back in august. The car has been sitting since and just started up for the first time yesterday, I'm pretty sure it's leaking still. I used fujibond to seal it where it said in all data , used oem gaskets and torqued to in the pattern in alldata. Is it normal for it to leak for abit in subarus?
jeff6666p is online now   Reply With Quote
Old 11-27-2019, 03:27 PM   #2
jeff6666p
Member#: 400078
black
Could the breather hose be clogged causing it to leak?
Old 11-27-2019, 03:59 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Could be the half moons. Did you replace them when you replaced the cover gasket?
BlackFighter is offline   Reply With Quote
Old 11-27-2019, 04:45 PM   #4
jeff6666p
Member#: 400078
black
Yup replaced then and used fujibond to seal them. The leak is on the bottom of the cover. I used all new oem gaskets and new half moons since I read aftermarkets can have issues. I used fujibond since it's what's used in the dealer. I replaced the seals on other cars and never had one still leak before.
I didn't replace the breather gasket on the top that's why I'm wondering if it could be clogged causing the new gasket to leak.
Old 11-27-2019, 06:54 PM   #5
jeff6666p
Member#: 400078
black
I checked the hose's they aren't clogged. I don't understand why the gasket wont seal though.
Old 11-27-2019, 09:29 PM   #6
Haevn
Member#: 495950
2011 WRX
did you clean the surfaces good? and in the valve cover
Haevn is offline   Reply With Quote
Old 11-27-2019, 11:11 PM   #7
jeff6666p
Member#: 400078
black
Yup. I used a plastic scraper to remove any gasket left over then put soaked brake clean on a rag and cleaned the head I used a soft tooth brush for the cover then I tried it and put the fuji bond in the spots the manual said.
Old 12-03-2019, 12:35 AM   #8
A.S.N.F.
Member#: 498940
2010 WRX
Lightning Red
One thing that most of time that is not done when repairs are made are to do the repair and then don't run the car for 12-24 hours. I use to always try to do this when I turned wrenches and love that the shop I now take my Subaru to does the same. It lets every set/cure and as a bonus is less likely to have some go into the oil. Your probably just got unlucky.
A.S.N.F. is offline   Reply With Quote
Old 12-03-2019, 12:58 AM   #9
jeff6666p
Member#: 400078
black
I did the gaskets in August. Just started the car for the first time last monday. I do agree with the wait time. I usually wait 24 hours.
