Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 11-29-2019, 12:03 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default ringlands
I accidentally ran my return fuel line to my evap. I took the out for a drove before I realized it and when I got into boost wot there was a bang and it felt like the car had died in it's tracks. The tank showed half full at the time it may of been much less because I found out is was leaking gas out the evap can after the drive. It drove fine after but if i got it of to 5k it started feeling like it was going to do it again. I fixed the lines , put some gas in it and took it for a drive and it seems fine now pulls great. no cel light.
Was the bang likely from fuel starvation? If it blew the ringlands would it sound different? I'm super nervous that I blew it my first day having the car
vacuum reads 18 in hg
jeff6666p is offline   Reply With Quote
Old 11-29-2019, 12:43 PM   #2
alexholl
Member#: 458056
2005 FXT Premium
Obsidian Black Pearl
I don't think it was fuel starvation. It's more likely that the evap line/system was putting too much downstream pressure on the fuel regulator. You had too much fuel pressure to the injectors since there was nowhere for the excess fuel to go. That caused it to run rich and it fell flat on its face. The bang you heard might've been the evap canister blowing out or one of the evap valves on the motor opening up with a high differential fluid pressure which couldve also dumped in some extra fuel.
alexholl is offline   Reply With Quote
Old 11-29-2019, 12:52 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
What car is it, the 98 2.5RS? You don't really "hear" a ringland brake. Fuel starvation also should not give off a "bang". The bang could have been a hose popping off or a canister. It would feel like the car is just not going anywhere while pushing the gas and fast deceleration, almost like someone put the brakes on.
If you are really worried then take it in to a suby shop "not dealer, unless you have warranty" and have them preform a leak down test and cyl compression test
BlackFighter is offline   Reply With Quote
Old 11-29-2019, 01:03 PM   #4
jeff6666p
Member#: 400078
black
06 wrx engine. "It would feel like the car is just not going anywhere while pushing the gas and fast deceleration, almost like someone put the brakes on." That's what happened when I heard the bang. It was like someone slammed on the brakes. After that the car rans fine but when I eased it up to 5k it started stuttering so I backed off.
Old 11-29-2019, 01:11 PM   #5
jeff6666p
Member#: 400078
black
It sounded like it came from the front of the car. It was like someone slammed on the brakes at full force. Is there any where I should check? The cel light isn't on, do you think the engine should be fine?
Old 11-29-2019, 01:35 PM   #6
alexholl
Member#: 458056
2005 FXT Premium
compression/leak down is your best place to start. Your evap system is definitely toast, so delete it and tune or if you're in a state that does inspections, find a part out or junkyard one.
Old 11-29-2019, 06:56 PM   #7
jeff6666p
Member#: 400078
black
If the evap system was bad shouldn't codes come up? I don't have a cel's
Old 11-29-2019, 10:14 PM   #8
alexholl
Member#: 458056
2005 FXT Premium
not always. If its a tank line or a busted canister it may not always show a CEL
Old 12-02-2019, 10:24 AM   #9
BlackFighter
Member#: 193940
2004 WRX STI Black
It also sounds like a coupler popped off. Check all coupler, IC to TB always popes off.
