Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 11-30-2019, 10:02 PM   #1
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
Default Cylinder 3/4 roughness only in gear at idle?
I'm chasing a cylinder roughness issue in cylinder 3 and 4 on a fresh build.
It only counts up at idle (1k rpm) when in gear or coasting. So coming off the freeway if I clutch in and go to neutral it will count up in 4 and some in 3 until I stop, then it goes back to zero. Car doesn't feel like it's misfiring at all.
While stopped if I put it in gear it immediately starts counting up in 4, doesn't matter what gear. And when I go back to neutral it goes back to zero. I can listen to the exhaust and tell there's no misfire going on.
As stated, fresh build, fresh valves, known good coil packs, have swapped injectors around, running speed density, fresh fuel pump and filter, new spark plugs.
Is it possible it's from mounts or something else? The car has Cusco engine mounts, a kartboy dog bone, window weld trans mounts, and home brew very stiff cross member bushings. I also have a light weight flywheel in there, but OEM crank pulley.
Any advice or thoughts?
subydude is offline   Reply With Quote
Old 12-01-2019, 12:41 AM   #2
A.S.N.F.
Member#: 498940
2010 WRX
Lightning Red
Did you clock the knock sensor correctly? It should be at the 2300 position. Clocking it incorrectly will cause Phantom knocking, roughness, misfire counts.
A.S.N.F. is offline   Reply With Quote
Old 12-01-2019, 08:09 PM   #3
subydude
Member#: 80649
Dusty
So I think I have it narrowed down to the neutral switch. I've swapped everything else and finally unplugged harness stuff until I narrowed it down to the neutral switch. With the switch unplugged it counted right up, with it plugged in it stopped.
Since the switch should be 12v in gear and grounded when in neutral is there any way to test besides swapping sensors?
Old 12-02-2019, 10:50 AM   #4
subydude
Member#: 80649
Dusty
I have a spare switch that I'm going to plug in tonight and test outside the trans to see if that solves it.
Old 12-05-2019, 12:57 PM   #5
subydude
Member#: 80649
Dusty
Following up on this, I tested with another neutral switch and the issue remains. Only counts up misfires in gear at a stop, or when in neutral coasting to a stop, so basically below 1,500 or so rpm at 0 mph in gear or below that rpm coasting in neutral.
Still only on cylinder 4 and 3 really, even after swapping injectors, coils, etc.
I have the factory grounds in place, but did put phenolic spacers in so I was thinking of running a few extra just to test. I also was wondering if an alternator could cause the issue at idle, or the fuel damper at the feed/return. It all seems to be low airflow/fuel flow (sub 1,500 rpm) and seems related to the neutral switch.
Again, still not actually misfiring, so it seems to be a false reading.
