Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 12-02-2019, 12:40 AM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Oil pressure sensor setting
I'm looking a sender for the gauge I have. The sender has a warning light set at 11.4 psi. Is this too high?
jeff6666p is online now   Reply With Quote
Old 12-02-2019, 07:20 AM   #2
mooshon
Member#: 431456
No it's better than fine, I set mine to 15 psi.
The oem one is calibrated to 2 psi which in that pressur you can say hello to your motor if you didn't saw it on time.
mooshon is offline   Reply With Quote
