Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 12-03-2019, 01:06 AM   #1
WolfPk
Member#: 498388
2007 STI
Obsidian Black Pearl
Question all four cylinders misfire after fuel upgrade
upgraded my fuel system to flex fuel and just running the base map my tuner sent me for 91 before we go into e85, car will crank and run for 1-2 seconds very roughly, if i give it gas after starting i can keep it running and the gas is somewhat to pretty responsive but as soon as i try to idle it shuts down. i was giving it that gas to keep it running for a minute and engine light came on and showed up as all four cylinders misfiring, and and PFFFE code or something
AF correction and learn seem to be at 0 which seems off to me.
im thinking it maybe a problem with the tune or maybe even a vacuum leak? but this far ive checked everything and theres nothing that significant. ive had the entire tmic off and it would start and run.
if anyone has any ideas thatd be great
WolfPk is offline   Reply With Quote
Old 12-03-2019, 04:26 AM   #2
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
o2 sensor unplugged? ground wire/strap not attached correctly?
Zmanwrx23 is offline   Reply With Quote
Old 12-03-2019, 09:59 AM   #3
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid 6MT Swapped WRB
What’s your fuel system pressure? Is it dropping after you cycle the key on?
It should hold pressure for several hours should be 43psi or somewhere there in if memory serves
Valarius Starchaser is offline   Reply With Quote
Old 12-03-2019, 12:53 PM   #4
WolfPk
Member#: 498388
2007 STI
Rear o2 is not plugged in at the moment, I had to order a new wideband and I'm going to tap the old signal wire so it reads from. there.
Also I don't have the old sensor from
The secondary air pump delete but it's not throwing the code at the moment, i was thinking it could be changing the timing from limp mode, but it was running fine before. but maybe with the new tune it's throwing it off that much.
Old 12-03-2019, 12:54 PM   #5
WolfPk
Member#: 498388
2007 STI
Could you possibly send a picture of how your ground wire strap is connected? I removed mine and just put it on the chassis where the ebcs bolts on and the other end on the top of my intake manifold??? Could this be my issue???
Old 12-03-2019, 02:48 PM   #6
kopele
Member#: 363007
2008 STI
What fuel components did you change? Are AF correction and learning 0 in closed loop? Do you have a fuel pressure sensor? Log?
kopele is offline   Reply With Quote
Old 12-03-2019, 09:24 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
maybe your scaling is off, what injectors did you have and what did you move to?
subaru_gc8 is offline   Reply With Quote
Old 12-04-2019, 02:48 AM   #8
WolfPk
Member#: 498388
2007 STI
hey guys i figured out the issue, somehow the turbo inlet was damaged and there was a significant vacuum leak. i wasn't aware that vacuum leaks could lead to misfires, but this seems like it was my issue, i wasn't able to tell until i got it to idle long enough that i could go under the hood and listen, heard a lot of air running in a spot it shouldn't have been so i sprayed some carb cleaner and the idle changed consistently.
Old 12-05-2019, 02:14 AM   #9
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Your the man for posting the found issue!!
AliBenn is offline   Reply With Quote
Old 12-05-2019, 02:36 PM   #10
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
I had that happen when I swapped to a vf52. I was doing a quick pull and heard a pop then a check engine light popped up. I limped the car home and knew it was going to be a torn inlet.
ThinWRX is offline   Reply With Quote
Old 12-08-2019, 09:19 PM   #11
WolfPk
Member#: 498388
2007 STI
yeah was super angry that i had just got all these good parts in just for another to give out mustve been a significant change so, atleast i know im moving in the right direction.
