Notices |
#2726 |
Member#: 481094
Vehicle:2011 Impreza OBS Blue |
![]() rallisportautomotive sells UEL headers and some other stuff for 2006-2011 2.5i's.
#2727 |
Member#: 505361
Vehicle:2008 Legacy 2.5i White |
![]() 2008 / Subaru / Legacy / EJ253 / 4EAT
Hybrid Intake w/ AEM dry flow filter: Less than ~$125 Infernofab 2.5RS style header w/ high flow cat: $700 Stock LGT midpipe, HKS Silent Hi-Power axle back Likes: It sounds great inside the car. I can barely hear the intake, the exhaust is deep and rumbly. Dislikes: I tried to be cheap and got an ebay intake. I hacked it up and used couplers, it doesn't fit quite right. It works, but I'm not 100% happy with it. The exhaust is raspy. I think the Delta Cams are at fault, it was always smooth before they were installed. I can't really comment on power gains, I'm sure it helps a little, combined with tuning, of course. This will all change in the next few months when turbo bits are installed ![]() |
#2728 | |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 2015 Forester XT, Tribeca |
![]() Quote:
Tuning the ECU could make a big difference though, and make you happier. But be very careful when you start adding boost to an EJ25. My 2000 2.5RS was a bit different with it's MAP sensor, but it's still a big risk. When I added even a simple RB52 legacy turbo kit at 6-psi with a rising rate fuel pressure regulator it made the biggest difference, and 0-60 times up here at 6000 feet dropped from 8+ seconds to 6.0 seconds flat on 93 octane. I didn't stay there though, even after blowing up 2nd gear. With 100+ octane gas and 2 extra fuel injectors in the throttle body run by an extra EFI computer, my 2.5RS was making 233 whp at 6000 feet above sea-level and running [email protected] quarter miles at Bandimere Speedway. I should have stopped there. Then I got greedy and broke the rings, built a 9:1 motor with VF22 turbo kit with AW IC at 14 psi and it was probably at 375hp on 93 octane. It was incredible, except when it got boost creep in the mountains in 5th gear with a friend driving and did the motor in again, along with another trashed stock 5-speed gear set. Then I built a monster 8:1 motor, JE pistons, Pauter rods, knife-edged lightened balanced crank, O-ringed head, Cobb cams, tuned ECU with quad fuel rails and Garrett Ballistic/IHI hybrid turbo, HK BOV, and 6 core AW IC, and dual dump 3" downpipe with about 500hp. And this time blew up 5th gear and the front ring-and-pinon despite having a PAR/Chalak high power gear set that only replaced 1st-4th. The ceramic clutch we installed, after the ACT clutch was slipping, was now grabbing a little too well. We tried installing a Forester STi automatic transmission since it had the same 4.11 diffs as the 2.5RS, and after 2 months of replacing pedals and shifters and drive shafts and wiring, it was stuck in 3rd gear. So 0-60 (4,000 rpm) felt like a Honda civic, but then finishing out 3rd gear from 60-120mph (4,000 - 8,000 rpm) felt like the Millennium Falcon - everything was a blur. After that, my wife said, "it's you or the car, one has got to go" and I sold the motor for $5K, sold the turbo kit for $5K, installed a stock motor and rewired the transmission, and traded it for a brand new 2004 STi. I had to leave the 3" exhaust, Tein coil overs, and Wilwood 4-pot brakes on it, as well as the leather seat upgrade that I did after I bought it. After paying the dealership $1,500 to "fix" the transmission issues, I had $9,500 in trade value on a 36 month old 2.5RS that had cost me $20,000. I think at that point I decided to never mod my car again. The STi was near perfect, although I did do a Cobb tuning access port tune on it. Now I'm in a 2017 WRX and it's only got the STi exhaust and short shifter and no tune - I'm just told old now I guess. So, after hearing this, do you think you might want to just trade that in for a WRX or Outback Onyx XT? |
#2729 | |
Member#: 505361
![]() Quote:
I had considered a Forester XT, but this car has been paid for since 2013.. I'm only going to run a TD04 at 5-10psi, with AWIC and E85 fuel.. should be fairly safe.. relatively speaking ![]() |
#2730 | |
over boosted again
RMIC
![]() Quote:
Your plan is certainly feasible, I just wanted to let you know what you’re in for. |
#2731 |
Member#: 505361
![]() I can’t even imagine how awesome that would be.. recognized by Subaru! Dang
I appreciate the heads up! |
#2732 |
Member#: 443213
Vehicle:2005 Saab 9-2x |
![]() What are the current options for en equal length header?
#2733 | |
Member#: 494393
![]() Quote:
#2734 | |
Member#: 494393
![]() Quote:
#2735 |
Member#: 505361
#2736 |
Member#: 443213
![]() That's what I'm finding out. Since I have an 05 I believe that I'll need the header, cat pipe, and the newer oil pan for it all to work.
#2737 |
Member#: 505361
#2738 |
Member#: 443213
#2739 |
Member#: 505361
#2740 |
Member#: 443213
![]() Last edited by SandmanSaab; 09-08-2019 at 10:19 PM. |
#2741 |
Member#: 505361
![]() Honestly, if you don’t mind the UEL sound, anything is better than the stock behind the pan manifold. That thing flows so bad. A cheap UEL will pick up power.
#2742 |
Member#: 443213
![]() Honestly I already have one. I swear this thing has an exhaust leak I can't find in the header. I'm going to replace it but if I oculd find an afordable EL that's the route I was going to go before getting another cheap UEL.
#2743 |
Member#: 505361
![]() I think your cheapest bet is an OEM 2.5i manifold. None of the other nice headers are under 500, most 700+
#2744 |
Member#: 443213
#2745 |
Member#: 493494
![]() I have a 2006 Impreza 2.5i with an exhaust leak located in the manifold. Instead of fixing it I'd like to go ahead and replace it. I'd like to have UELs but I wouldn't want to have to replace my full exhaust system. Currently my setup is stock manifold and cat pipe with an STI catback and magnaflow muffler.
Would I be able to get rs style uel headers and a cat pipe and have it bolt right up to the catback or would I need a full exhaust for this to work? If that doesn't work than what are some good EL headers that would bolt right up? I'd like to go for a decent sound more than anything, my current setup sounds really good unless I get on the gas and it starts to get raspy. Eventually I'd like to replace the muffler with something a little bit more toned down as well since the amount of noise that comes from my car is ridiculous and I think it's had a pretty significant effect on my hearing as well. |
#2746 |
Member#: 399260
![]() I have a 2004 Impreza Outback currently with a custom made hybrid intake. I’d like to get an exhaust that gives me a little more power, and a slight increase in sound (a little louder and deeper. Just enough to be noticeable and sound nice but not make people deaf). Would this be accomplishable with just a muffler or would it be worth it to go full cat-back? What brands/models do you suggest?
****Official '80s Freestylin' thread****for the old guys!!! | MyRad25rs | Off-Topic | 21 | 12-09-2011 11:39 PM |
The Official "Things I Hate For No Good Reason" Thread. | RaceCarRiot | Off-Topic | 109 | 02-14-2006 11:00 AM |
The Official Pittsburgh's DILLIGAF Racing for Mod Thread | Mancini | Mid Atlantic Impreza Club -- MAIC | 11 | 09-20-2005 11:29 PM |
The official 2005 volleyball thread for NOVA | slim speedy | Mid Atlantic Impreza Club -- MAIC | 57 | 04-12-2005 05:51 PM |
The OFFICIAL no rain/snow for the learning curve thread | Bart | Mid West Subaru Owners Club Forum -- MWSOC | 8 | 03-27-2003 03:22 PM |
