Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
Old 04-30-2011, 03:24 PM   #26
nedalrabadi
Member#: 244358
1996 impreza
orange & black
any idea about the EJ20X ?
it was off a B4 LEGACY STI
i need to know about the head design is it like the EJ205 or the EJ207
the thing is i need pistons and i'm very confused should i get off the shelf pistons like the wrx or custom like the jdm ones
nedalrabadi is offline   Reply With Quote
Old 09-11-2012, 11:28 PM   #27
krishnakodali
Member#: 331936
I am gonna buy Subaru Legacy 2013.
Is it worth buying subaru navigation system ?
krishnakodali is offline   Reply With Quote
Old 12-27-2012, 03:37 PM   #28
faded-a-fool
Member#: 331709
2010 Legacy 3.6R
GGM
Subaru has improved the Navigation system in the 2013's. I think it would be a better value to get an aftermarket nav. If you want to retain the stock look, then it's best to invest in the OEM nav.
faded-a-fool is offline   Reply With Quote
Old 01-21-2013, 10:46 PM   #29
robinhood2688
Member#: 344417
Hello i was wondering i have a 1990 subaru legacy l and i am in need of the clutch cable that goes from the pivot point into the transmission. Its a 5 speed 4 cylinder..i keep finding the one that goes from the pedal to the pivot point but my other one is shot any help with what the part is called or where i could find it? Thanks in advance for ur time
robinhood2688 is offline   Reply With Quote
Old 08-05-2014, 04:07 PM   #30
H6STi80Y
Member#: 398187
Can you please tell me the part numbers to these tailights set on this BH please
H6STi80Y is offline   Reply With Quote
Old 11-22-2014, 01:30 AM   #31
omaid amiri
Member#: 405847
Hello i am looking for 1997 legacy jdm front bumper and complete radiator support
omaid amiri is offline   Reply With Quote
Old 04-09-2015, 10:34 AM   #32
98leggygt
Member#: 412140
1998 legacy gt ltd
I'm in need of a down pipe off of a 1989-1993 legacy turbo. And I can't seem to find any online. Does anyone know of any aftermarket one available? Or it would be easier if someone on here would have one to sell lol
98leggygt is offline   Reply With Quote
Old 06-20-2015, 12:24 PM   #33
ChrisG961
Member#: 423518
I'm in need of an ej25d for a 97 Legacy GT
ChrisG961 is offline   Reply With Quote
Old 05-13-2016, 08:40 PM   #34
j13welder
Member#: 186859
2004 WRX
Java black pearl
I just picked up a 99' legacy sus limited and I'm looking for an aftermarket intake, if anyone can point me in the right direction id appreciate it.
j13welder is offline   Reply With Quote
Old 08-07-2016, 01:16 PM   #35
Brisky
Member#: 148078
2017 WRX Base
Crystal White Pearl
NOTICE: Bilstein 24-101707 46mm Rear Struts have been discontinued by the manufacturer. Get them while you can.
Rear Strut Mounting Bolt Parts (for when it gets cross threaded on reinstall )
Part Description:
Rear Strut Mounting Flange Bolt
Model:
BE/BH
OEM Part Number:
901000177
List Price:
$5.90
Part Description:
Rear Strut Mounting Self Locking Nut
Model:
BE/BH
OEM Part Number:
20550AA010
List Price:
$7.78
Part Description:
Rear Strut Flange Bolt Washer
Model:
BE/BH
OEM Part Number:
900335056
List Price:
$1.73
Side Note:
The link the first post leads to a scammer/virus page thingy. DO NOT click it.
Use this instead:
http://opposedforces.com/parts/legacy/
Brisky is offline   Reply With Quote
Old 11-01-2017, 04:20 PM   #36
shainepepper
Member#: 477020
Originally Posted by xcntrk75 View Post
Model:
1998 2.5 GT Sedan (BD)
Part Description:
Front Hub
OEM Part Number:
28052AA010
Notes/Verification:
Often needed while replacing wheel bearing, this number is for an AT although they *should be the same as MT.
Part Description:
Front Ball-Joint
OEM Part Number:
21067GA050
Notes/Verification:
Direct fit, Right/Left side same.
Part Description:
Tie-Rod End
OEM Part Number:
34141AC010
Notes/Verification:
Part Description:
Front Wheel Bearing (cartridge)
OEM Part Number:
28016AA011NT
Notes/Verification:
Entire bearing assembly, this is for an AT although they *should be the same.
Part Description:
Inner & Outer oil seals, wheel bearing.
OEM Part Number:
28015AA070
28015AA080
Notes/Verification:
Both inner and outer wheel bearing oil seal. One is pressed into hub before bearing, the other after.
Part Description:
Radio Bezel, wood grain
OEM Part Number:
J1310AC020
Notes/Verification:
BD, 2-DIN, Radio bezel in wood grain.
Part Description:
Power antenna replacement mast (rod nut assembly)
OEM Part Number:
86323AC070
Notes/Verification:
Part works great, easy to replace, make sure you don’t loose the tiny screws which hold the motor unit together, also may want to use some additional grease to help with the install.
shainepepper is offline   Reply With Quote
Old 11-01-2017, 04:20 PM   #37
shainepepper
Member#: 477020
Same here
Old 09-26-2018, 04:56 PM   #38
caymansubaru
Member#: 491930
1997 Subaru LegacyBD
white
Default 1997 subaru legacy BD JDM dual turbo automatic
Hello, I am a new member and I have been searching the FAQ and looking around for a few parts for my dual turbo automatic legacy.
I recently replaced the vehicle's exhaust system, replaced the two wire catback o2 sensor with a three wire sensor. large amounts of black smoke are now coming from the tailpipe.
I think maybe the heated 3 wire sensor is throwing the computer off since it may be waiting for the nonheated values to be registered in order to do its fuel management thing. so I am planning to return the two wire sensor If I can find one. t
* Can someone please point me to a two-wire O2 sensor and a source for parts for a JDM Subaru legacy Thanks for any help.
caymansubaru is offline   Reply With Quote
Old 09-26-2018, 06:55 PM   #39
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Do you have the old O2 sensor to try to pull a part number from?
('93-'01) The part # thread Hondaslayer Impreza Forum 189 03-23-2022 12:18 AM
Moderators: We need a sticky part # thread! xcntrk75 Legacy Forum 42 02-13-2006 05:00 PM
