Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 11-04-2018, 03:05 AM   #1
Pearl_sti
Member#: 493586
Default 2013 sti really weird misfire. HELP!!!
So I have a 2013 sti. Stage 3 protuned. Now one day I was driving and my check engine popped up, didnít think much of it, after a while it started sputtering and shaking at idle so I thought it was because of the heat, after the weather cooled down it still continued. Code p0301 cyl. 1 misfire. Swapped coils, swapped plugs, swapped injectors, fixed all vacuum leaks, and compression test passed. Still getting p0301. This is on and off. Code will pop up and car will sputter and then drive fine for 20 miles and randomly start sputtering at a light. Help please !
Pearl_sti is offline   Reply With Quote
Old 11-04-2018, 11:51 AM   #2
JSR84
Member#: 469585
Originally Posted by Pearl_sti View Post
So I have a 2013 sti. Stage 3 protuned. Now one day I was driving and my check engine popped up, didn’t think much of it, after a while it started sputtering and shaking at idle so I thought it was because of the heat, after the weather cooled down it still continued. Code p0301 cyl. 1 misfire. Swapped coils, swapped plugs, swapped injectors, fixed all vacuum leaks, and compression test passed. Still getting p0301. This is on and off. Code will pop up and car will sputter and then drive fine for 20 miles and randomly start sputtering at a light. Help please !
Nevermind. Best of luck. lol
JSR84 is offline   Reply With Quote
Old 02-20-2019, 05:26 PM   #3
PEARLWHITE925
Member#: 497697
Default Still having this issue? Have you tried this?
PEARLWHITE925 is offline   Reply With Quote
