02-14-2019, 09:40 AM | #1 |
Member#: 190615
South East
Vehicle:2012 WRX Black |
Walbro F90000285 "Hellcat" fuel Pump
Has anyone used one yet? I've had nothing but great success with Walbro in the past, I previously used the 450 and loved it.
Walbro PN: F90000285
02-17-2019, 01:30 AM | #2 |
Member#: 196882
Vehicle:08 WRX |
Looks like an 8% flow increase but takes 15% more current to make it happen compared to the F90000274 (450lph). Without a pump controller that can handle the current (stock wont do it, for very long..) it would have to be hard wired. In which case I'm not sure the extra heat in the fuel would be worth it versus just running an additional switched pump for occasional high demand. Juice may not be worth squeeze. If your dedicated to a hard wired set-up and have decided the additional heat is not an issue than it may be a simple solution if your right on the edge of running out of pump.
02-17-2019, 09:41 AM | #3 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
I think the bigger issue with these pumps, as mentioned, is getting them the amperage they want through the controller. There are some aftermarket controller options, a grounding mod for the stock one, etc...
02-24-2019, 05:57 PM | #4 |
Member#: 190615
South East
I've never had a issue running the 450 without hard wiring.
02-24-2019, 06:32 PM | #5 |
Member#: 163648
Vehicle:2002 WRX V9 6mt R180 Brembos |
Is it E85 safe?
03-11-2019, 09:44 AM | #6 |
Member#: 402592
Can that pump run through the stock fuel lines from the tank to the engine bay without issue or should you upgrade those lines?
03-13-2019, 03:41 PM | #7 |
Member#: 335449
Vehicle:07 WRX 20G 6MT 12 CTS-V Sedan 6MT |
03-14-2019, 04:16 PM | #8 |
Member#: 402592
03-14-2019, 04:19 PM | #9 |
Member#: 395275
RMIC
Vehicle:2012 STi SWP |
I run a hardwired Walbro 450 with all stock lines with no issues. 50 psi base pressure.
03-14-2019, 07:01 PM | #10 |
Member#: 402592
