***FREE SHIPPING to the lower 48 States
10% OFF 04-17 STI 2-piece front rotors (hard anodized)
10% OFF 2018+ STI 2-piece front rotors (black/hard anodized)
20% OFF matching brake pads with purchase of rotors
10% OFF matching replacement rotor rings with purchase of 2-piece rotors
***Apply code "HOLIDAY2020" during checkout. Shipping will begin early Jan for all products sold with 2020 holiday discount.
2018+ STI Front Rotor Specs & Features:
- 340x30mm high carbon cast iron
- Slotted friction face, less prone to cracking vs. OEM drilled rotors
- Direct bolt-on without any modifications
- Fully-floating 2-piece design allows thermal expansion of the rotor and minimize deformation
- 48 curved directional ventilation vanes for optimal heat dissipation, runs up to 30% cooler than O.E. rotors
- Extended rotor and pad life due to lowered operating temperature
- Superior bite, thermal characteristics, and durability optimized for track and spirited driving applications
- Weights 16.8 lbs (7.65 kg) - save 6.4 lbs of unsprung weight per rotor vs. OEM
- Fits vehicles with OEM 6 pot Brembo calipers
- Optional hard-anodized aluminum hats for improved strength and durability
- Replacement rotor rings available at competitive price
Priced starting at $800
> MORE INFO
Why upgrading to 2-piece rotors?
04-17 STI Front Rotor Specs & Features:
- 326x30mm, slotted friction face
- Floating 2-piece design
- Fits vehicles with OEM 4 pot Brembo calipers, Universal fit for vehicles with 5x114.3 or 5x100 lug pattern
- Weights 17.1 lbs (7.75 kg) - save 2.9 lbs of unsprung weight per rotor vs. OEM
Priced starting at $700
> MORE INFO
02-07 WRX Front Rotor Specs & Features:
- 294x24mm, slotted friction face
- Weights 5.2 kg (11.46 lbs)- save 2.4 lbs of rotational mass per rotor vs. OEM
> MORE INFO
Brake Pad Features:
- Manufactured by Winmax Japan
- Superior stopping power and modulation
- High fade resistance
- Consistent performance under high temperature conditions
- Compounds available for street, street / track, and dedicated track applications
> MORE INFO
*Sales tax applicable in California
For fastest response, please contact us via email at [email protected] (mention NASIOC to receive member's special discount!!)
About Paragon Performance:
Established in 2014, Paragon is dedicated in supplying high performance brake products for a wide range of motorsport and sport driving applications. Paragon sponsored the brakes on two Team Honda Research West (THR-W) Civic Type R which completed the 25 Hours of Thunderhill enduro fourth and seventh in a highly competitive class (Class E0). Close and ongoing cooperation with race teams give us a distinct advantage by providing real-world data and professional product evaluation. With extensive knowledge and background in motorsport products and services, we understand customers***8217; demand for street, track prepped and race vehicles.
http://paragonbrakes.com/
