Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 01-22-2021, 02:51 PM   #1
basyager
Member#: 518233
Default trying to decide on oil and filter...
yoyo Subie homiezz. my first oil change is coming up and im trying to decide whether to just get OEM black filter or order online something like WIX, or this oversized MAHLE filter. There's also this $11CAD Mobil 1 filter in the "high performance" category.
and can't decide with oil... MOTUL seems to be the "hype". is it worth the price?
Am I over-thinking this?
on an unrelated you guys think I should bother the dealership to do the 4th gear TSB? can't say im excited about the idea of having a stranger tear into it...
basyager is offline   Reply With Quote
Old 01-22-2021, 02:59 PM   #2
tegxsi
Member#: 446029
not another oil thread...lol You are going to hear lots of different opinions...
IMO cheap Mobil1/Castrol/Pennzoil 5W-30 and WIX filter you mentioned is fine. If you want to step up in oil then Motul, Liquimoly makes good stuff.
Maintenance is key....4-6k oil change intervals.
tegxsi is offline   Reply With Quote
Old 01-22-2021, 03:33 PM   #3
basyager
Member#: 518233
So I heard its better to change more frequently than to go longer on the expensive stuff. Just trynna hear some opinions and then mods can delete this useless thread. Btw how is there only 2 pages in this forum? I guess the mods are keeping it tidy
Old 01-22-2021, 03:57 PM   #4
alapilusa
Member#: 424692
2015 WRX
There is much more than 2 pages. You need to update the display options on the bottom of the screen to show more.
alapilusa is offline   Reply With Quote
Old 01-22-2021, 04:19 PM   #5
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
I have 190k miles on my FXT using the OEM Honeywell oil filter about 80-85% of the time and the rest of the time I used whatever comes free with an oil change bundle.
Oil brand doesn't matter, specs matter most. Oils generally perform very similarly when they meet the same specs (GF6 Resource Conserving oils usually become a 20 weight, ACEA C3 oils stay in grade much better, etc.).
People throw out their favorite brands but many brands have many choices, even within the same grade, but they meet very different specs. There are seven Mobil 1 5W-30's, there are seven Motul 5W-30's.
The most robust 5W-30's are the ones that have a High Temp High Shear of 3.5 or higher (Mobil 1 5W-30 ESP, Motul 8100 X-clean EFE 5W-30, Shell Rotella T6 Multi Vehicle 5W-30).
Old 01-22-2021, 04:48 PM   #6
toph
Member#: 78640
19 Tundra
04 STi
We use Motul X-clean 5/30 (used to be EFE now it's Plus) here exclusively for the past 4 years or so and works great. Good analysis from the ones we've done. OEM Filter as well.
toph is offline   Reply With Quote
Old 01-22-2021, 05:22 PM   #7
basyager
Member#: 518233
much appreciated guys.. oil change is coming up no time to nerd up on oil knowledge for now, high temp high shear. is what I need got it. I am still able to find the EFE. its a little cheaper actually
Old 01-22-2021, 06:12 PM   #8
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Old 01-23-2021, 01:44 PM   #9
X49
Member#: 386600
2015 WRX
If you want to use an oversized filter, you can use a Baldwin 7167 or the larger Baldwin B161-S. They have 18% and 42% more filtration area than stock. They have the same 20psi bypass valve pressure rating as OEM. I've used both. The B161-S is tall enough to contact the hood insulation, which melted it a bit.
I like oversized filters especially for winter since they don't go into bypass as easily when the oil is cold. They're also better for longer OCI's.
X49 is offline   Reply With Quote
Old 01-23-2021, 06:44 PM   #10
Comikazi
Member#: 402552
2016 WRX
While I really appreciate that huge oil thread and all the discussions in it, do yourself a favour and don't read any of it.
Choose whatever oil (5w30) and filter is convenient/cheap to get for you. I think change interval is the most important thing with the amount of fuel dilution in these engines.
I spent years reading and trying different oils recommended by people on here and........just wasted my time and money on fancier oils. I just get whatever is on sale now.
Comikazi is offline   Reply With Quote
Old 01-24-2021, 10:17 AM   #11
Rexy18
Member#: 500337
Couldnt resist commenting.. personally i think the choice of oil is most important. Once that is done oil intervals are secondary only because every one of us changes the oil too often 3-5000k and most oils provide protection past 7500k as documented with multiple oil analyses enthusiasts posted for us to see.
Furthermore, why not get 0W30 or 0W40, basically 0W oil for cold temps. You guys are aware that 0W includes or encompasses 5W spec oil temps? So why not go for more protection on cold startup..
There are exceptional 20-25$/5qt oils at Walmart that are for DIT engines specifically.
Rexy18 is offline   Reply With Quote
Old 01-24-2021, 04:28 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Just us the OEM filters and change your oil regularly. Oil brand/type is highly debated, but no one has ever has a single problem due to the OEM filter not doing its job. Although, there are many more worse options out there.
KillerBMotorsport is online now   Reply With Quote
Old 01-25-2021, 12:45 AM   #13
basyager
Member#: 518233
but FA uses black oem filter?
Old 01-25-2021, 11:30 AM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Whoops, edited
Old 01-25-2021, 11:45 AM   #15
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Because most 0W-30 and 0W-40 oils available at Wal-Mart are high SAPS oils which you do not want to run in a DIT. The exception is Mobil 1 0W-30 AFE.
Old 01-25-2021, 01:39 PM   #16
Rexy18
Member#: 500337
Most oils at walmart arent for DIT applications, like 90%+. I said specific oils are. Not sure about one you mentioned because i use a different Mobil 1 oil and a Quaker oil. Former is 0w40 api sn 24$ and latter 5w30 api sn plus 21$, latter actually being slightly better oil as far as my research shows.
Old 01-25-2021, 04:04 PM   #17
X49
Member#: 386600
2015 WRX
I wouldn't use an SN oil anymore. The standard was changed quite a lot for SN Plus, to address LSPI issues, and LSPI is a pretty common killer of these engines. SP is even newer than SN Plus and apparently has some further improvements for LSPI prevention.
Old 01-25-2021, 04:19 PM   #18
rtv900
Member#: 428511
2016 STI
Think about it man, do you think making a 0w-40 oil is just a matter of the guy at the refinery pushing a different button or something????
Viscosity modifiers give that affect, so it takes more modification to get a bigger range.
That's why some people use straight 30 in summer. Because a straight weight oil is always better than a dual viscosity as long as cold temps aren't an issue.
0w-40 simply isn't necessary in normal US temps.
Old 01-25-2021, 04:19 PM   #19
rtv900
Member#: 428511
2016 STI
Also, what is the 4th gear TSB??????
Old 01-25-2021, 04:28 PM   #20
Rexy18
Member#: 500337
Because 5w30 dont use modifiers to be rated 5w30 vs straight 30 and 5w30 which all use is necessary? You gots to stay congruent and objective in your logic and then you gots a point. Then how can you say it isnt necessary in real world, cuz minnesota or montana dont experience - temps? You cant be serious. And yes, i think its a s simple as a push of a button to add the modifiers necessary or pour modified oil.
Having said that how much better is 30 oil vs 5w30 or 0w30? Are we talking 0.5%, 3% or 30% and only within warm-warmed up range.
The point i was trying to hammer home is that 5w30 oil range is within 0w40 oil operating ranges which are wider or on both ends.
Old 01-25-2021, 04:48 PM   #21
rtv900
Member#: 428511
2016 STI
^this is one of the funniest retorts I've ever read
wait, are you White Boy from "I love New York"
Old 01-25-2021, 05:22 PM   #22
basyager
Member#: 518233
So whats the verdict on fuel dillution? People saying its bad on these others are saying if you drive highway it evaporates. Seen a UOA of some guys fa20 and fuel dillution was <2%. Some guy said its a good idea to get 40w to compensate for any dillution. What u guys think, considering how tiny the oil passages are on new engines..
Old 01-25-2021, 05:57 PM   #23
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
The problem with the 0W-40's at Wal-Mart is that they are high SAPS oils which contribute to intake valve deposits and also have high calcium which contribute to LSPI, regardless of the API rating. An API SP oil like Mobil 1 0W-40 still has high ZDDP and calcium.
Many of the standard 5W-30's at Wal-Mart are GF5/GF6 dexos 1 Gen 2 so they do have additive packages in mind for IVD and LSPI. Of course, they also have the operational viscosity of a 20 grade.
Old 01-25-2021, 06:04 PM   #24
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Fuel doesn't evaporate as easily in a DIT like it does in a port injection engine. If the uoa's you were looking at were Blackstone, they only estimate the fuel percentage based on the flashpoint reading but do not actually test for fuel. Look for uoa's from Oil Analyzer's Inc that mention fuel dilution readings from "GC".
Most xW-40's can cause intake valve deposits so you need one that meets ACEA C3 ratings as it will have reduced ZDDP and calcium. This is why IAG Performance does not recommend Motul X-cess 5W-40 in a DIT.
https://www.iagperformance.com/conte...ipping-Doc.pdf
https://forums.nasioc.com/forums/sho....php?t=2882122
Old 01-25-2021, 08:26 PM   #25
Rexy18
Member#: 500337
Mobil 1 fs 0w40. Porsche oem spec oil, good enough for me.
