Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 01-30-2015, 07:49 PM   #1
abrosk927
Member#: 387507
Default 2015 2.0 Mods
So I traded my 2014 WRX in for a 2015 Impreza base to get low payments and good MPG as I enter med school.
What are some easy garage mods that may make it sound better or any secret "deletes" that may make it a little more fun to drive.
Let me know what you guys think so far, I have de-badging and tinting and some LED bulbs coming.
Any ideas are appreciated!!
Sent from my iPhone using NASIOC
abrosk927 is offline   Reply With Quote
Old 01-30-2015, 08:00 PM   #2
ColdSoda
Member#: 200545
2008 SPEC B
no power mods out there worth investing in, but you can always go to a local exhaust shop and have them cut out the factory muffler and weld in something else, maybe a glasspack or similar.
suspension parts will make it fun to drive and a decent set of tires make a big difference.
Cosmetic stuff is a personal preference, but tint and debadging is a nice start!
ColdSoda is offline   Reply With Quote
Old 12-23-2015, 03:17 AM   #3
aciel78
Member#: 433851
2015 Impreza Sport P
Metallic Quartz Blue
THROTTLE HAPPY TUNE. I've yet to do it, butt I've gotten a reply from him:
[i][/IHey Michael
YEs, no problems tuning the CVT FB20 engine in your car
You only need a tactrix OP2.0 from www.tactrix.com and I can walk you through the software process
My pricing is AUS$250 which at current exchange rate is around US$165 and entitles you to free retunes for life of the car
Tactrix device aproximately $169 (?)
I don't think this is such a "bad" investment..... For a Tune, however this adds up as I'd naturaly like to upgrade suspension and exhaust to match the change in performance. I must say, just the upgrade of 19mm RSB and SSD frontower strut, makes a very noticeable increase in the quality of the ride I literally LOVE driving into turns now stepping on the gas rather than the brake!.
aciel78 is offline   Reply With Quote
Old 01-30-2015, 08:50 PM   #4
Onehunga
Member#: 400927
2012 Impreza Sport
(Cut and paste from something I put in another thread, hope it helps)
There's not much you can really do to an Impreza to up the horse power without spending lots of money (http://www.mrtperformance.com.au/per...eza-XV-MY12-on).
There are things you can try to make it more fun to drive though:
Larger rear sway bar
http://subaruonlineparts.com/subaru-...ay-p-2163.html
replace the stock air filter with a K&N one
http://www.knfilters.com/search/apps...za&engine=2.0L
Put a light weight pulleys on the engine
http://perrinperformance.com/i-13324...x-fa-fb-engine.
http://perrinperformance.com/i-18067...-fr-s-brz.html
Replace stock tires with performance tires from whatever brand floats your boat
Use CUSCO chassis bars to stiffen up the body
http://www.cusco.co.jp/en/catalog/chassis_bars.html
Get a tune from ThrottleHappy
https://www.facebook.com/Throttle.Ha...rofile_browser
http://forums.nasioc.com/forums/show....php?t=2658018
Exhaust wise, it is my understanding that the stock BRZ exhaust fits with only minor modification, this then gives the impression that any after market BRZ exhausts will also fit
http://allwelldrive.blogspot.jp/2013...-from-brz.html
Onehunga is offline   Reply With Quote
Old 11-29-2015, 03:36 PM   #5
DeathEater
Member#: 434476
Default 4th Gen impreza
Are there any cold air intakes that can be put on?
DeathEater is offline   Reply With Quote
Old 11-29-2015, 03:45 PM   #6
flanman
Member#: 421237
Nothing worth the lack of HP gains. Better off with either a K&N or AEM drop in filter.
flanman is offline   Reply With Quote
Old 11-30-2015, 09:43 AM   #7
aciel78
Member#: 433851
Default Rear Sway Bar Install?
Hi all, New here to the forum and just got my first Subaru 2015 Impreza Sport Premium 2.0i with CVT. I originally wanted the MT 5 Speed but wife does not know how to drive stick so had to settle. I absolutely LOVE this car! Naturally looking into minor performance upgrades starting with 19mm Rear sway bar. I've searched thouroghly on the forums on how to install but couldn't find any pics. Any member kindly point me into the right direction on how to install is highly appreciated. From what I understand so far is that the car does not need to be on a lift when swapping the bar. Also what tools would I need? And do they nuts need to be torqed to a certain spec? Sorry for the rant but not too mechanically inclined but I feel this is something I'm capapble of doing if I just know how to do it. Thanks All.
M
Old 12-03-2015, 11:42 AM   #8
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
M
It's really pretty simple. You'll need the car on some kind of lift just due to the ride height, but the car needs to be on the weighted suspension, so you either have to jack and the suspension jack points, or put it on ramps of some kind. Other than that, just look at how the sway bar you currently have is attached (your car should have a 15mm sway bar stock). There are two bolts on each end of the bar that connect it to the endlinks, you'll need to loosen and unfasten the sway bar from these. There are also two retention plates that have two bolts each, which attach the sway bar to the chassis itself and hold the bushings in place. You'll need to loosen and remove these, then you can remove the sway bar. Re-install in the same way you uninstalled the bar, using the appropriate bushings (they and size specific). If you search the 12+ Impreza thread (same basic car) and the "modding the 12+ impreza thread", you should find the torque measurements. They were something like 22 and 24 ft-lbs. Shouldn't really matter in the end as long as they aren't dramatically over-torqued or under-torqued.
Dirt Bringer is offline   Reply With Quote
Old 01-30-2015, 09:26 PM   #9
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Just read all the "2012 Impreza" and "Aftermarket for the 2012 Impreza" threads. Its basically the same car.
CalTech87 is offline   Reply With Quote
Old 02-10-2015, 10:34 PM   #10
SkeletonKing
Member#: 413212
2015 Impreza
So anything from 2012-2014 fits? And I was wondering if I change my rear swaybar to the 19mm and add lowering springs or coil overs will that void my warranty?
SkeletonKing is offline   Reply With Quote
Old 02-11-2015, 03:04 AM   #11
Hoxton13
Member#: 380440
2013 Impreza Wagon
Dark Gray Metallica
Don't see why it would because as far as I know it, the base doesn't come with a rear sway bar. The springs on the other hand might, but it's a simple swap at least.
Hoxton13 is offline   Reply With Quote
Old 02-11-2015, 09:57 AM   #12
ColdSoda
Member#: 200545
2008 SPEC B
you cant void a warranty.... you can only introduce parts that may cause a claim to be denied due to those parts you installed. you cant install coilovers then have one break and expect subaru to replace your coilover... you decide to put in aftermarket radio and amps... dont expect subaru to help if your radio stops working. That wont mean they will not support the other parts you have not messed with. Mod at your own risk. a swaybar change has very little chance of causing warranty issues.
edit: just read this sticky: http://forums.nasioc.com/forums/showthread.php?t=803106
Old 05-27-2017, 10:10 AM   #13
6.4_HEMI_485hp
Member#: 468360
Sounds like some cool mods
6.4_HEMI_485hp is offline   Reply With Quote
Old 02-07-2015, 03:38 PM   #14
condinero
Member#: 396242
2015 Subaru WRX
Im actually on the same page, i had a 2015 wrx couple of months ago but i wrecked the car due to an accident and now i ended up getting the impreza base 5door. Im actually planning on modifying the car, but not putting as much as money. My plans are improving the suspension, getting the exhaust done, and rims. Im wondering whats available aftermarket for it. And what everybody told me is hard to find parts for it and no much of gains. So options are custom made or wait til some parts comes in the future. But i also heard that 2013 to 14 are just the same body with the 15, but i dont know if its true. Im still doing some reasearch about this car.
condinero is offline   Reply With Quote
Old 02-11-2015, 02:49 PM   #15
RockyTop
Member#: 412725
2014 Crosstrek
Orange
Anybody put a turbo on this engine yet?
RockyTop is offline   Reply With Quote
Old 02-11-2015, 05:08 PM   #16
Varls1243
Member#: 369682
2013 Impreza 5dr
Theres a supercharger kit available. Search Raptor Superchargers
Varls1243 is offline   Reply With Quote
Old 02-12-2015, 05:30 PM   #17
IanMAPerforance
Member#: 413358
2014 Impreza Sport
AVO just released a turbo kit for the XV. They confirmed it will fit the Impreza as well.
https://www.facebook.com/avoturbowor...45943388757653
IanMAPerforance is offline   Reply With Quote
Old 02-13-2015, 03:33 AM   #18
mini lan
Member#: 373776
MY14 Impreza GP7
no words needed for my to tell you whats gonna happen next to mine
mini lan is offline   Reply With Quote
Old 03-06-2016, 06:45 PM   #19
2k16imprezasport
Member#: 441994
Default What grille
That grille is that?
2k16imprezasport is offline   Reply With Quote
Old 03-06-2016, 06:48 PM   #20
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Pretty sure its from AVO (Japan). Not cheap.
Old 03-28-2016, 07:13 PM   #21
ozzywrxxxx
Member#: 443567
❤❤❤❤❤love it
ozzywrxxxx is offline   Reply With Quote
Old 09-28-2016, 02:25 AM   #22
karacser0319
Member#: 452857
2014 Impreza WRX 4dr
Did you buy the grille with the red highlight or did you do that yourself? If by yourself what did you use?
karacser0319 is offline   Reply With Quote
Old 09-28-2016, 02:28 AM   #23
TrickNipple
moon moon
Member#: 86213
Originally Posted by Kottosen View Post
finally got the oem mesh grille! Definitely like it a bit more than the cmod but that's to be expected at 3x the price
Those red highlights?
Those are Hella Supertones, they are horns.
TrickNipple is offline   Reply With Quote
Old 02-13-2015, 01:42 PM   #24
vt_scoob
Member#: 404917
12 Impreza Sport
wow, seen any XVs with this mounted up/dyno pulls or the like? I'd be interested to see numbers vs cost, especially without a WRX hatch coming anytime soon...
vt_scoob is offline   Reply With Quote
Old 02-13-2015, 05:46 PM   #25
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
"We saw a 100% power gain on the cars we fit it to overseas, and will get numbers on US gas as soon as we can"
Lol 296hp out of this motor?
foghelmut is offline   Reply With Quote
