Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 03-26-2018, 01:05 PM   #3151
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Wow I guess I haven't updated this in awhile. Been a whole lot going on (if you follow me on Instagram @dpk_racing I've been updating). Here's a quick recap.
-Samsonas sequential gearbox, along with the new OS Giken diff, is assembled and installed.
-Geartronics paddle shift system is installed, with the actuator mounted directly to the gearbox case
-Header, uppipe, downpipe, turbine housing, and wastegate have been covered with custom inconel heat shields from Advanced Thermal Products
-JRZ RS Pro 3 dampers have been received and installed, along with Swift springs
-The chassis wiring harness was removed and totally overhauled, removing some old wiring mess. All of the paddle shift functions were added, some old stuff repurposed or removed, everything properly termed and booted, etc. It's a huge improvement. We also added sensors for exhaust backpressure, crankcase pressure, gearbox temp, rear diff temp, and provisions for shock pots, steering angle, and wheel speed.
-The engine bay has received some love as well. Added a Boomba 75mm throttle body, swapped silicone i/c coupler for a Vibrant HD clamp, all vac lines swapped for AN hoses with crimp fittings, and a brand new GTX3582R Gen 2 to replace the damaged turbo.
-I am very excited to announce a new partnership with RHR Performance (https://rhrperf.com/). I have been working with them for a couple months on the design and manufacture of a new aero package, starting with a WTAC-caliber front splitter, designed by Kyle Forster, who some of you may know from the "Kyle Engineers" YouTube series. Kyle has moved on to work for Mercedes F1, but his replacement is equally talented and we are still moving forward with more development. We will be starting with the splitter and a temporary wing, to be replaced later in the season with a new multi element wing and redesigned rear diffuser. Along with extensive CFD work, this is going to be a massive difference maker in terms of lap time.
I think that about covers it for now. The car goes on the dyno this Thursday/Friday to do the final setup for the paddle shift system and retune. If all goes well we will be on track next month!
boost junkie is offline   Reply With Quote
Old 03-26-2018, 01:10 PM   #3152
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Old 03-26-2018, 01:12 PM   #3153
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Old 03-26-2018, 07:19 PM   #3154
BlueSTI4Me
Member#: 34361
04.7 STI
Sounds like great updates, but images not viewable.
BlueSTI4Me is offline   Reply With Quote
Old 03-27-2018, 10:57 AM   #3155
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Whoops...I rehosted, they should be all good now.
Old 03-27-2018, 01:37 PM   #3156
BlueSTI4Me
Member#: 34361
04.7 STI
Very nice.
Old 03-27-2018, 05:10 PM   #3157
Scargod
Member#: 260314
2008 STI hatch
Thanks for the pictures! Inconel exhaust but no slip joints? Perhaps it's thin enough and doesn't need them. I am just finishing modding my second set of Full Race headers with Burns 321 SS double slip joints.
I am amazed at many similarities between your build layout and mine sans the V-mount setup. That and your fancier parts (and expense). Just jealous, but I am on the same design wavelength as you. I have some V-banded intercooler piping and the routing layout is similar.
Really nice work and since there are similarities I can't tell you how much I like it!
Scargod is offline   Reply With Quote
Old 03-27-2018, 05:21 PM   #3158
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
The heat shields are inconel, the manifold itself is stainless. I'm not fancy enough for inconel exhaust parts!
Old 03-27-2018, 08:23 PM   #3159
Scargod
Member#: 260314
2008 STI hatch
Sorry. I thought you took mpj_becks up on his offer.
Old 03-28-2018, 10:58 AM   #3160
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
I did, but unfortunately that header didn't clear the dry sump pump so I sent it back and IAG built a custom header.
Old 06-11-2018, 10:21 AM   #3161
02WRX"monster"
Member#: 173100
Do you have any updates for the problems or solutions to them you encountered?
Love the Build! best of luck!
02WRX"monster" is offline   Reply With Quote
Old 06-21-2018, 10:37 AM   #3162
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Should have something to announce by early next week. We're working on a major overhaul of sorts...
Turn in Concepts 2010 Track Car Build Turn in Concepts Press Releases 374 12-30-2016 02:06 PM
My GC Race car build rrsettgast Member's Car Gallery 3 04-27-2010 12:19 PM
Came out to my car... belt on the ground and this (pic). Padge Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2009 10:36 PM
Getting my car closer to the ground BluScopion Vancouver Impreza Club Forum -- VIC 12 02-02-2007 02:30 AM
got car back from the shop, now lights are messed up X2.5RS01X New England Impreza Club Forum -- NESIC 1 02-21-2005 09:41 PM
