10-13-2008, 08:07 AM | #1 |
Member#: 34670
South East
Vehicle:2016 slowmobile |
Going to do timing belt, do I need all these parts?
13028AA230 Timing Belt ..............$71.96
13073AA142 Idler Pulley .............$59.96 13073AA190 Idler Pulley .............$33.48 13085AA080 Idler Pulley .............$63.24 13033AA042 Tensioner ...............$119.96 21111AA007 Water Pump ...............$75.96 21114AA051 Water Pump Gasket .........$3.06 21236AA010 Thermostat Gasket .........$2.74 809218270 Alternator Belt ...........$11.16 73323AC000 A/C Belt .................$11.16 21200AA072 Thermostat ...............$12.76 I want to do it right, but I don't want to over-spend. Of course if I have forgotten anything let me that as well. What do you guys think? Thanks
10-13-2008, 08:26 AM | #2 |
Floresbian
Moderator Member#: 470
South East
Vehicle:2020 Canyon Denali '21 Forester & '13 BRZ |
I would have it all on hand just in case...but if you are only at 105k and the water pump is dry (no signs of leakage) I would leave it alone, and if the Idler Pulleys and Tensioner are not noisey (take them loose and spin the bearing in your hand to check) I would leave them alone too.
10-13-2008, 01:48 PM | #3 |
Member#: 34670
South East
hmmm, well I am ordering it all as I don't have a local dealer so not sure about sending what I don't use back. Maybe just not order the tensioner and idler pulleys?
10-13-2008, 01:56 PM | #4 |
Member#: 153468
South East
Vehicle:04 WRX Wagon WRB |
Same with the A/C and alternator belts. If they don't look bad don't replace them.
10-13-2008, 02:16 PM | #5 |
Allergic to turbos
Moderator Member#: 181
Your mileage may vary, but I did all of that on my '04 TS last year. With the 35k or so miles a year I put on it, I didn't feel like chancing it. Plus I got a nice deal from my local Subaru specialist.
10-13-2008, 02:30 PM | #6 |
Member#: 120152
Check your tensioner for a good amount of oil on the top seal. If it's leaking, get a new one. If it's not, leave it alone.
10-13-2008, 08:16 PM | #7 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
i concur with Opie.
10-13-2008, 08:24 PM | #8 |
Member#: 34670
South East
Seems like alot of extra dough for the just in case... what's the typical life span of the pulleys? I don't mind paying it if it's worth it.
10-14-2008, 10:32 AM | #9 |
Member#: 34670
South East
Let me look at it another way if you guys will indulge me... which of these parts is easy to change at a later date, and which are easier to change while you're in there (water pump)?
10-14-2008, 11:18 AM | #10 |
Member#: 176960
SWIC
are you twin cam or single cam?
if your doing it yourself id invest in some cam pulley stoppers,they help SOOOO much,and its like a good insurance plan.. only on a twin cam though, single cam is a non interference. |
10-14-2008, 11:43 AM | #11 |
Member#: 34670
South East
I am '03 single cam, I thought they were all interference?
10-14-2008, 01:23 PM | #12 |
Member#: 3
South East
Vehicle:2012 Geeteeeye and 71' VW Gulf Beetle |
I've done a ton of timing belts on Subies and I always do the following:
Timing belt (obviously) water pump oil pump tensioner (if leaking) thermostat and all related gaskets including crank seal. pulleys I've seen have never been bad (even on one with 160k). Sometimes a cam seal is leaking but that will be very noticeable. Is all that required? no. Will you know when it is? maybe... or maybe not until engine failure. I'm cautious. -Mike. |
10-14-2008, 02:44 PM | #13 |
Member#: 34670
South East
Oil pump? How hard is that on a Subie? Never done that on anything other than american iron lol
10-14-2008, 09:04 PM | #14 | |
Member#: 3310
South East
If your belt jumps time and the tensioner causes it b/c you didn't replace it, you are going to kick yourself. Don't half-ass it. I'd also recommend replacing the front seals on the engine as well....cams/crank etc (along with the water pump). |
10-14-2008, 09:30 PM | #15 |
Member#: 34670
South East
See, I didn't even consider all of those seals... what type of job are we talking here?
10-14-2008, 10:17 PM | #16 |
Member#: 8151
South East
Vehicle:2002 WRX Rally Car Atlantic Rally Cup Champ! |
I'd also change out the oil pump while you're in there. I mean, how often do you want to mess with the front of your engine?
10-15-2008, 09:24 AM | #17 | |
Member#: 3
South East
-Mike. |
03-02-2009, 05:21 PM | #18 |
Member#: 34670
South East
bumping me ol' thread
Ready to order parts finally... Will I need special tools, or can we do this without? |
03-02-2009, 06:55 PM | #19 |
Allergic to turbos
You will need the cam alignment tool--if I remember correctly. Hopefully someone will have a part number or lead you in the right direction.
03-02-2009, 07:14 PM | #20 |
Member#: 89233
South East
Vehicle:99 RS Aspen White 2014 Outback SWP |
I'm getting ready to do this on two cars and I am changing everything I can while it is apart. Spend a little more now rather a couple of grand later if the motor blows
03-02-2009, 08:03 PM | #21 |
Member#: 315
South East
I just skimmed this and I think that you guys recommended doing all the seals too.
cam and front main seals are a MUST when doing a timing belt. while you're in there, you know. sjd don't ask how I know...I think 8 years on I'm still bitter about my RS blowing a cam seal a WEEK after I did the t-belt, and got the belt and everything oily. that means new belt. |
03-02-2009, 10:58 PM | #22 |
Member#: 193949
South East
Ok I have a bugeye WRX, and I'm having this done at ~90k with an 08 STi oil pump, and the water pump. Should I er' on the side of caution with the 257 STi timing belt? Or is this totally un-needed? Its stage 2 so slightly modded.
03-03-2009, 08:23 AM | #23 |
Member#: 34670
South East
03-03-2009, 08:27 AM | #24 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
The cam tool is like $60 from Cobb Tuning if they still have one.
I wouldn't do the pullies or the pumps if they aren't leaking. Definately do the tensioner though. |
03-04-2009, 08:05 AM | #25 |
Member#: 34670
South East
The folks at CarterSubaru.com say I won't need that tool, so now I am confused. Has anybody done it with or without said tool? I got a quote for $1500 to have it all done at a dealership, no way possible I can afford that.
Need hand with doing timing belt | bloopsta26 | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 04-01-2009 02:58 PM |
When do the timing belt/water pump need to be replaced? | Bilybobjef | Service & Maintenance | 10 | 07-08-2007 09:52 PM |
End of term and moving, I need ALL these parts gone | t3hWIT | Private 'For Sale' Classifieds | 82 | 05-04-2006 12:46 PM |
Things to replace while doing timing belt? | lag | Legacy Forum | 4 | 04-17-2004 10:28 PM |
Wait until spring to do timing belt? | scubette97 | General Community | 13 | 01-24-2004 11:24 PM |
