11-17-2000, 06:25 AM | #1 |
Member#: 2771
Vehicle:2003 BMW Z4 Blue |
What probe should i use for EGT gauge
I have already decided to get the Autometer Phantom EGT gauge but i don't know what probe to get these are my different choices
1 HKS EGT Probe $143(not sure if it comes with mount) 2 Autometer Competition Series Probe kit $97.99 3 Autometer Street Series Probe kit $47.95 It doesn't bother me if it reacts really fast as long as it works really good, i need one to tune my s-afc when i get it and most likely will end up using a 4wd dyno to tune it with.
11-17-2000, 09:57 AM | #2 |
Member#: 1271
Vehicle:98 RS ****in Rally Blue |
works really good = acts really fast. if you dont have a probe that acts quickly how are you going to tune from it?
11-17-2000, 11:32 AM | #3 |
Member#: 2771
Then which probe should i get price isn't a matter boomer
11-17-2000, 06:32 PM | #4 |
Member#: 689
NESIC
Vehicle:2005 Outback 2.5 XT Champagne Gold Opal |
Here is a picture of the Autometer probes:
The top one is the 5249 Street Probe, while the bottom one is the 5244 Competition Probe. Note that the Competition Probe has an exposed sensing element - probably the reason why it responds so much faster than the Street Probe. I'd recommend the Competition Probe, as the full length of the probe wiring is protected by a steel braid. Meanwhile, the Street Probe has a short 8" (20 cm) section covered in steel braiding, and then relies on a two-conductor cable with vinyl insulation and crimp terminals. The crimp terminals use cheesy nyloc nuts and bolts for the electrical connections. The heat shrink you see in the picture is intended to be used to seal up the nuts and bolts, but the instructions make no mention of this. In fact, it didn't come with any instructions at all (the 5244 did). -WaC Wayne Edit: added recommendation. [This message has been edited by wac (edited November 17, 2000).] |
11-18-2000, 12:20 AM | #5 |
Member#: 296
The HKS sensor works well.... I have one with my HKS gauge.
I have been told the Autometer Competition Series Probes are good (fast reacting too). Its justt he stock ones that leave a bit to be desired. J. |
11-18-2000, 02:12 PM | #6 |
Member#: 1903
Vehicle:2000 2.5 RS-T coupe T3/04 Link'd 2 10 PSI |
Thats what i dont like about autometer they dont come with probes. You should get an apex el series egt. It has 30 sec playback,temp warning, and it comes with a probe so you dont have to buy a seperate one. Thats the one i have, and its great. |
11-18-2000, 05:09 PM | #7 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
Well, the price of an Autometer gauge & a probe is still cheaper than the other gauges... whether they're better or not is still up in the air, IMO.
11-20-2000, 07:44 AM | #8 |
Member#: 2771
Thanks everone i still got one more ? does the probe have to be welded onto the header or does it just clamp on or what?
11-20-2000, 07:48 AM | #9 |
Member#: 329
You can tap it in, but it may be a little risky with the thin headers. Welding would be the best approach.
What product should I use for hand polishing. . . | last lemming alive | Car Care & Detailing | 1 | 11-09-2009 04:04 PM |
What oil should i use for California winter? | Hyelude | Newbies & FAQs | 4 | 12-20-2008 02:54 AM |
What TMIC should I use for a VF30?? | SoCal ScoobieNewbie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 28 | 09-22-2005 07:31 PM |
What pads should i use for perrin willwood? | Hey_its_Cole | Brakes, Steering & Suspension | 6 | 08-02-2004 06:51 PM |
